12
Everything posted by mikaleda
Your sube is trying to tell you something! Lol, but seriously make sure its not just the light coming on, maybe the vaccume cylinoid is leaking?
Dead Loyale after timing belts broke and replaced
mikaleda replied to TPaul's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'd double check timing marks -
Kia Sephia Sporty
mikaleda replied to Loyale 2.7 Turbo's topic in Non Soob Cars and Bikes Discussion
What a KIAstraphie -
I wouldn't worry about it a whole lot unless your having issues.
Trailer tires on a Soobie/Small car?
mikaleda replied to Subaruist's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would think it might be okay if you were just using them off road if you could find some that had some nice clean out. Aside from that though I could defunatly see issues with handling and on a slick road. it would probably be a recipe for disaster as all year or round tires -
And there is also a forum on here for parts wanted and parts for sale What do you need?
Those are three comon codes that are easy to fix. I would start with the injector, these are a comon failure on these cars. You can buy just one and replace it, thats a fairly simple process. Or you can buy a used fuel rail and just pull the rail on that side and replace it, both methods are on here and both are simple fixes Air control valve probably needs to be cleaned. info on here about how to do this as well also fairly simple. Canister purge valve isnt a big deal unless you have to pass emissions. the valve itself is most likely the problem, one bolt, one connector and a couple vac lines. Its like a five minuet job, its located under the intake on the passenger side follow the lines from the canister and you'll find it. The valve should cost about $5 at pull and save. I have a good one I'll send you with pics of location for $10 shipped I also have a full set of auto injectors for your car as well
List of rims that can be used on older Subarus...
That's true they are fairly small -
It sounds like your trans is in limp mode for some reason, I'm not much on autos so I'm not sure what duty cylinoid b does. Clipping that wire will cause your car to be locked in 4wd, don't drive it ddown dry roads like that it will screw something up. More that likely it was preventing the AWD from grabbing because it was in limp mode and it is probably caused by a bad cylinoid
I've wondered this myself, I have a pristeen 93 GMC and I found a mouse inside it the other day. Sure scared me when I was driving down the road and a mouse jumped out from under the seat. I still can't figure out how the damnd thing got in there, I don't have any holes in the floor and there is grating over the air intake for the hvac, so how the heck did the bugger get in there?
I had a set of cooper weather masters t On my gl that were 185/75/r13 and they had some nice clean out. I buried my gl once and was still able to climb out with them on
