12
Everything posted by mikaleda
external to internal regulator
mikaleda replied to Uberoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Single wire alts are best in tractors wich stay at a steady rpm range higher than a cars idle -
No the hill holder is part of the clutch also and the return spring for the clutch is connected to the hill holder. O.p. is the cable from the clutch to the hill holder still connected? That could be part of the problem if that cable is frayed in the sheath
Sorry to here you bad luck, new heads on an old block can cause higher compression making the old rings fail like you mentioned, I would worry about throwing new rings in there without new bearings since the new rings will result in even better compression putting more force on the bearings, you could always inspect the bearings with a plasti gauge and hope it would work, but it'll still be a chance that the engine might fail farther down the road.
Why are you putting a whole new clutch kit in? Just get a new throw out bearing, a better quality one at that. My dad owned an old Mazda and a ford pinto for a while, subaru is definatly more reliable over all, no offense just don't give up on subaru cause of one bad apple. Ummm wait a minute you said the noise went AWAY when you pressed the clutch in, that would not be a throw out bearing, when your clutch is completely engaged the throw out bearings is not moving, unless the clutch is improperly adjusted wich would wear that bearing out quickly.
Purge control solenoid valve
mikaleda replied to 1990loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If its anything like my first gen Legacy, its a simple control valve that controls when the fumes are sucked out of the charcoal canister, usually opens when crusing at a steady speed. Go to a junk yard and get one, I got mine for $5 I don't think it will make much differance though unless you have emissions, my Legacy ran like that without any problems for a long time. I don't know where it's located on the loyals, but it was located attached to the underside of the intake on mine. It was an easy fix on mine -
Sometimes sealed head lights will crack around the seal and allow moisture in, wich in turn washes the reflective coating off making the head light dim. Changing the relays would probably make a big differance if the head lights don't. Also there is write up in here by gloyal that shows how he rewired his headlights, might be worth a search.
- 29 replies
- 1
That's a good question, I don't know, it's probably best to just get another pump, it sounds like its worn out and let the ball slip out.
The ball bearing is part of the filter bypass, yes that ball bearing is important.
If its a wagon it will have a latch in the middle of lower seat, it may take some fealing around, if its a hatch the seats have to be unbolted
It sounds like you have the 2.5, check the overflow for air bubbles as well, that is another way they fail and sometimes on some years they leak oil externally I'm not sure which years. Searching should give you all the info you need, look for engine code on the passenger side of engine near the front of the block next to the p.s. pump it should say either ej22 or ej25, ej22 is 2.2, ej 25 is 2.5
Ea71 with HLAS and points?
mikaleda replied to mikaleda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Correct, but that was only in the ea81 autos IIRC -
Need EA71 distributor with points
mikaleda replied to cnc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've got a coil setup for parts I'll take a look and get back to you. -
Dang, I relay hoped this would be an HLA motor -
Makes sense, just a side note here but your going to need a resistor also to wire to the coil to make the points work correctly -
Why would you want to retrofit points on an ea82? The electronic module is really simple and almost never fails, the main part that fails are the bushings in the distributor. Why not just keep a spare electronic disty for your car, it would be easier to find. -
I'm going to pull the valve covers off and see for sure what I've got, I couldn't do it yesterday cause of the rain, but I'll try and find some time today.
