12
Everything posted by mikaleda
Maf is the most likely cuplrit in that list. O2 sensors rarely fail, cam sensors usually work or they don't, injector is possible but less likely that the maf. I would try a used MAF sensors they are cheap and easy to get swap out.
- 21 replies
- 2
- Stumble
- hesitation
(and 3 more)
Tagged with:
http://www.webstaurantstore.com/wd-40-specialist-11-oz-water-resistant-silicone-lubricant-spray-with-smart-straw-6-case/940300011.html?utm_source=Google&utm_medium=cpc&utm_campaign=GoogleShopping&gclid=CNHDqICDw8sCFVKDfgodBY0DQgThis is what I'm using it has a silicon lubricant. I thought of lithium grease, but I'm worried about it catch dirt and stuff. I think I'll try pure silicone spray next time.
Okay, I've got a customer with an ll bean edition H6 outback. They are constantly having issues with their doors. So far I've traced the problem To the outer door handle has a build up of gunk and rust on the inside pivot point which causes it to stick and keep the lock from acuating properly. So far I've had little luck with the method I'm using lasting for long. I've been cleaning the pivit point out with carb cleaner and then relubricating with wd40 silicone. Anyone have any ideas, my next thought is to use straight silicone spray.
I would also check codes and check for vaccume leaks.
- 21 replies
- Stumble
- hesitation
(and 3 more)
Tagged with:
This may be something, are you missing a gas cap? If so I would inspect your fuel, its possible you have water contamination.
- 21 replies
- Stumble
- hesitation
(and 3 more)
Tagged with:
Ouch, sorry to hear about that. I hope you are feeling better, foot injurys are the worst.
Kia Sephia Sporty
mikaleda replied to Loyale 2.7 Turbo's topic in Non Soob Cars and Bikes Discussion
Looks like the thing from preditor vs alien that jumps on peoples faces and lays its eggs. -
Stuck in AWD
mikaleda replied to ln41's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
That makes sense my harbor freight scanner is a can and E obd2 reader I must have gotten lucky when I bought it.- 11 replies
- Torque Bind
- Duty C Solenoid
(and 2 more)
Tagged with:
Stuck in AWD
I used to pull TCU codes all the Time on various makes and models including Subaru with a snap-on Solaris scanner when I was working at the service center. Although its not as common for the TCU to throw codes in the older subies, I have pulled tcu codes with obdII scanners on older Subaru's before.- 11 replies
- Torque Bind
- Duty C Solenoid
(and 2 more)
Tagged with:
I've got a neighbor with a 94 legacy with 450k miles on it and its had a few sets of struts in its lifetime, but never new strut mounts. My moms old 90 went 330k miles on two sets of struts never changed the strut mounts. I have 230k on my 90, new struts original mounts. Same with my grammas 97 outback with 250k. Same with my moms new car 97 impreza 230k. Same with my step dads 97 brighton 240k. I would call B.S. on that statement.
Stuck in AWD
That's funny, my harbor freight scanner does. I pulled tcu codes off an 05 outback with it just the other day.- 11 replies
- Torque Bind
- Duty C Solenoid
(and 2 more)
Tagged with:
Stuck in AWD
98 should be obd 2 and even a chepo harbor freight scanner will bring up your transmission codes. If the at temp light is blinking you have codes- 11 replies
- Torque Bind
- Duty C Solenoid
(and 2 more)
Tagged with:
I seriously doubt that is what's causing this problem. I put a 30k mile engine in my car with my old clutch and it never caused and issue. I would suggest pulling the engine or trans again and redoing your tourque sequence on the clutch disc and inspect everything. If nothing else for the peace of mind.
