12
Everything posted by mikaleda
From what I understand about the inline filters, in 91 there was a TSB on the trans coolers in the radiators getting clogged and causing problems, so they added an inline external filter. I was told by the parts store was its a magnetic filter because of high amounts of metal shavings in these transmissions, and since the phase 2 4eat'a came with a spin on filter I would think this to be a fairly common problem, but obviously it doesn't look that way.
1979 GL brake question
mikaleda replied to sjschlag's topic in Historic Subaru Forum: 50's thru 70's
Your probably right, but it still doesn't hurt to ask. Sometimes the people behind the counter may know of a place to get them, even if they need to be custom made, it's worth a try. -
I wouldn't worry about them unless either 1. The rubber is cracking or 2. The hard lines look like their very badly corroded. I'm not sure where you would get them, I would try napa or your local auto parts store. -
Windshield Washer Fluid Pump
mikaleda replied to rdweninger's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Lmao! That's a good story, what a way to find out your washer pump isn't working. -
It should be on the washer fluid tank for the front washer. -
80 Brat strut options / jump seats
mikaleda replied to vwBrat's topic in Historic Subaru Forum: 50's thru 70's
Nope if the bottom is differant then you have the other style subaru used, so McPherson struts won't work. -
Need to replace a 78 Brat engine
mikaleda replied to BLUPRNT's topic in Historic Subaru Forum: 50's thru 70's
Just FYI on the external reg. alt. to internal reg. alt, the red wire with the white chase that goes into the voltage regulator is the charge light wire. -
Yep that's how you test it, if it doesn't pass replace it.
No problem -
No problem
Pics Of the p.c.v valve on my 80 ea71 (1600) It should be the same on most of the ea series engines. I hope this helps.
It's on the intake manifold, I'll see if I can get a pic of the one on my 80.
Yes, they should look exactly the same as the black strut in my pic, but as long as the bottom mount is the same they should work. -
Junkyard or you could buy them new, I doubt your springs are bad that's not to common of a problem. Also I believe rock auto would be a good place to find new springs, if they are the same as pictured above order them for an 84 to ensure you get the right part. -
No problem I hope you figure out your problem.
Post it in the new gen section, that way it will be seen by all the subaru gurus and is thus more likely to be answered correctly.
Welcome to the usmb. What kind of subaru do you have?
