12
Everything posted by mikaleda
I have seen some threads on this before, I think some year ford escort seats will fit. I can't remember for sure try searching this site with google since the search function on this site is overly complicated, type your key words the type link:ultimatesubru.org in google.
new cv axle shaft vrs reman
mikaleda replied to ivantruckman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So far from what I have seen from my new c.v. That I replaced my napa reman with seems to be good and hasn't given me any problems even with the front jacked all the way up. -
Need to replace a 78 Brat engine
mikaleda replied to BLUPRNT's topic in Historic Subaru Forum: 50's thru 70's
Ya that makes sense, especially since he has the parts car right there. -
P.c.v valve is a Positive Crankcase Ventilation valve and its just basically a one way valve and if it gets stuck open it sucks oil into the intake and burns it. Rings rarely fail on these subarus unless its been badly abused.
I run 10w-40 in my cars, smoking is usually because of a bad p.c.v valve. P.c.v valves are cheap and easy to replace and I've seen subies with 300k plus that don't smoke.
80 Brat strut options / jump seats
mikaleda replied to vwBrat's topic in Historic Subaru Forum: 50's thru 70's
If they look like the the pic above they will work. No need to pull them just take the tire off and look. -
Also I found out theat my oil pump hasn't been filtering the oil since before I got this car so this p.o.s ea71 is going to get thrashed when I go mudding in the near future. Ea81 and a dual range trans is in the future for this car, along with rear disc breaks.
Sway bar that's what it is I think, should be fairly easy to do them. I'm not to worried at the moment since I just tried driving this car to town and my pos cheapo Stant t-stat started messing up
Bump! And I found out why my front end is making noise, it's bad bushings on the stabilizer bar? I guess that's what you call it, but I was crawling around under there and grabbed one and heard it clunk so I checked them out and their definatly hard and deformed. Not sure when I'm going to fix those, but I'm not in a hurry.
Corosion in cylinder
mikaleda replied to the sucker king's topic in Old Gen.: 80's GL/DL/XT/Loyales...
+1 the slight indentations from the rust could be honed out possibly, but boring it out and using over sized rings would make it a good engine again. -
I have done it on my 80 (pics in the link of my sig page 3 or 4) i have a 95 impreza alt in my 80. it is not hard if that's all your doing but he is already replacing the engine, lets not make it more complicated than need be. -
I think where you get your fuel is more important than octane, I only have thee gas stations I go to because they have the better quality gas than the other places. Example: less water in the gas, newer tanks, car responds better. Another thing to look at now because of the ethonal, how many people use the gas stations and what kind if fuel is most used, I know I will not get mid grade from the stations around the lake because nobody buys it and so it sits in the tank and degrades.
Pull the covers on both sides, it might be hard getting the bolts out but just be patient. Once their off use a remote start switch to turn the engine or you can do it by hand but make sure you rotate the engine enough to see the whole belt. Look for cracks, chunks missing fraying, or teeth missing. If you see any of that change it. As for the clunking, I would jack the front end of the ground and do an inspection of the c.v.'s, ball joints, wheel bearings, ect...
