12
Everything posted by mikaleda
We used to have a really good hose at the service center I used to work at. It was nice and thick, but still flexible, I think it was harbor freight it looked just like this.http://m.harborfreight.com/38-in-x-50-ft-premium-rubber-air-hose-61939.html?utm_referrer=direct%2Fnot%20provided
Yep just swap the y pipe out and use the intake manifold that goes to the car your putting it in and all will be good.
- 6 replies
- 1
- engine swap
- automatice trans
(and 1 more)
Tagged with:
The injectors are a side feed style and when the o rings on the injector start to leak it will cause it to leak fuel into the cylinders causing flooding. When you are opening the throttle to get it started your putting the ecu into a clear flood mode and then it takes a while to clear the excess gas out. The easiest fix is to swap in a set of used injectors with rails and all.
Is there a FWD light on on the dash? Not sure if this model has it, but some have a fwd fuse that when inserted puts the trans into front wheel drive mode. Is there any flashing lights? Is the check engine or at temp light on? Does the rear end catch up if the front end slips for a bit? Sometimes there is a delay in awd engament, which can be caused by old fluid or I believe your model year people have had good luck with trans-x additive treatment.
Should be a hub assembly. It shouldn't be to hard, but then again that also depends on how rusty it is. I've had to use a puller and a BFH to get them out sometimes. Then again most of the time I've been able to get them out with little effort. They are definatly not the notoriously hard bearings of the older gen Subaru's.
I run a 5ah battery and Ive had it for about a year and charged it three or four times. Before I bought this one I would have totally agreed with you, but this one has seriously impressed me. I just used it to do a rear wheel bearing on a 97 impreza and it pulled the 32mm nut off like it was nothing and presssed the bearing our like it was nothing. Oh and that is another tool I highly recommend now that I've tried it out is OTC's hub grappler. Awesome tool makes doing wheel bearings a lot easier.
