12
Everything posted by mikaleda
Rtv silicone!
Dual range electrical wiring question
mikaleda replied to subaruman5's topic in Transmission, Axle, and Brakes
It looks like you know where all but two go I would just plug it in and see what happens I don't see how it could hurt they all go to lights -
mikaleda replied to subaruman5's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1984 GL wagon [1800] Troble downshifting
mikaleda replied to ajp's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Depending on what kind of driving you do a clutch can last a lot longer than 100k if you take care of it. Defiantly try adjusting the cable first and see what happens -
Cracks? Did you have the heads crack checked? That could be the whole issue you may need new heads, but if it is blowing smoke you should have been able to see them.
Does the smoke smell sweat? If not it is probably oil. How many miles on the engine? Did you check the piston tops when you did the heads could be a cracked piston. Check around your air filter for oil. Check your oil see if there is water in it. How did your valve seats look when you replaced the head gaskets. Also could be ATF lol check you gas tank last resort to see if someone didn't pour some ATF in your gas. I know oil smoke is usually gray
EA81 Heater Control Valve
mikaleda replied to kabarakh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No it's not I have messed around with my heater lines a lot because of previous owner -
It's been removed then I just assumed it was like the later modles. Glad I found this out, now I know where to get a valve -
My 80 gl wagon doesn't have a valve just saying -
I don't think Subaru uses a valve I am pretty sure they use a flap over the heater core -
Sorry about this back again had over heating happen again but weird part was it did it coasting into my driveway replaced cheapo cap with a Stant no problems since and have driven a tankful of gas through it and pushed the engine to its limits climbing the hills around here no sighns of even getting hot. I will double check with a block check when I have money but I doubt it was the head gasket
3at problem 1985 gl 2wd
mikaleda replied to desertsubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Have you checked your vacuum? make sure it is running at the right psi, I think it's around 15 psi. make sure you don't have a vacuum leak somewhere. -
2005 Struts
mikaleda replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Good idea! -
2005 Struts
+1 I bought a set of those for $50 online they work great
