12
Everything posted by mikaleda
rockauto.com wants $65 a piece for front struts for my gl. i'm not going to spend that much on it i guess i will just have to do some educated guessing.
cool i will look into that i just don't want to spend a whole lot of money on this rig really. i am trying to save up enough money to buy the parts i need to do my head gasket on my legacy and this car keeps eating up my money:popcorn:
this may sound dumb, but i am new to struts. my 1980 gl needs front struts really bad. i want to get some out of a junker but, i don't know if they will be any better than what i have. is there anyway way to tell if the struts i am getting out of the junker are any good?
it sounds like a bad connection under the dash, possibly a ground.
ea81 locking flywheel what to use?
mikaleda replied to mikaleda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
box end wrench worked good! thanks everyone for the tips. -
distributor timing on 87 carbed ea-82
mikaleda replied to djellum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if it is that far off it is probably a vacuum leak. i am not familiar with the ea82 do they have a vacuum operated spark advance? if so that is where i would start. your timing should be somewhere around 8 degrees. -
my 1990 subaru legacy 5 speed
i have owned this car since 5/25/12
work i have done on it:
new radiator and thermostat
new head gaskets soon
i noticed the ticking at first but now that i have replaced the front oil seal and ran it (and also got rid of the rats nest in muffler ) they quit ticking and the engine defiantly has pressure now. this car has sat for three years so i have a project ahead of me i need a new muffler, ball joints and to finish the weber swap someone didn't finish and it will be a runner.
strut swap
mikaleda replied to cohophysh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
don't mind me i am just posting so i can keep track of this thread. i have a 90 legacy too and i would love to get some more clearance out of it. :cool: -
update. i went online and ordered a rebuild kit for my oil pump (it only took five min. to rebuild) and re installed but ended up being front oil seal. thanks to everyone for your help. p.s. i think the oil pump needed to be rebuilt anyway because as soon as i replaced after rebuild it actually built up enough oil pressure to start spraying oil everywhere (that's when i figured out it was the front seal).
thanks to every one for tips i will post what i use to torque down the crank puly when i am finished -
good idea i was worried about stuff breaking off like you said. i like the box wrench idea that should be flexible enough to bend before it breaks and i could really torque on it too. oh ya 987687 the reason i didn't try the starter to take it off i was worried about damaging stuff if the wrench slipped.0 i did try an impact to get the bolt off initially but it was an electric one and was not powerfull enough -
i used a punch in one of the holes in the flywheel to break loose nut when i tried to torque back down it snapped. -
i would try ultra copper rtv. that is what my parts store had in stock for the pump to block surface.
thats what i tried at first but i was using a cheapo so i might try a better one. i thought of a screwdriver to but the holes in this flywheel are so small a standard Phillips head screwdriver would not fit in the hole. am i just not looking hard enough? are there bigger holes than the ones i am seeing? -
cool i will try that thanks for the tip. -
i just replaced a front oil seal in an 85 brat. i locked the flywheel through one of the holes, but the holes are so small i can't get anything substantial enough in them to lock it good enough to get the right torque on the crankshaft puly bolt. i keep breaking whatever i put in there, does anyone have a suggestion of what to put in these holes to lock it up good enough to get at least 40 foot pounds of torque on it?
