monstaru
    14
Everything posted by monstaru
  1. i vote for a welder/generator.and if anyone knows the elctrical end of this i am willing to build it.. i have run into a few plans online,but nothing that i have the patience to read....ie one that is not 75 pages and not condensed. an air pump like the vdub idea might be pretty cool too. cheers, brian
  2. you don't read do you? this is just for the show.i thought the show would be later and i would have time to get it on a frame.which i won't be able to accomplish so, there are things that i neglected to do that need done....so that i can have something to bring(to the show) and rock and roll in:grin:
  3. ok, my moments of insanity are gone. the struts are on the way,shocks will be here soon too. the engine needs a gasket and is ready to go in.then we will see if it fires up. couple other little surprises.cheers, brian i'll get pics when the motor is in.
  4. passive aggressive.......
  5. ask NUG,he id this with a 2.2.and the kennedy adapter kit is about the only way to go.unless you mount it mid engine,then you are fabbing alot obviously.cheers, brian
  6. obviously you have never seen him drive his cars.....
  7. monstaru
    lift blocks?
    jerry did that on his first hatchbrat.and it is alot easier than building a cambered strut top.
  8. but stop leak also gets into the other parts of your engine.and can clog up those vital,don't wanta lose passages tat are smaller in size. these products can kill your water flow and ruin your rig. use the egg if you must,then take the damn radiator out,buy some 50/50 lead solder and get a propane torch.clean the areas around the pinholes and heat until almost red.apply the solder much in the same manner as soldering electronics.this will fill the holes permanently.i have done many a repair on radiators without fail. oh, and start paying attention! my last fiasco was a very large wrench used to turn the motor to top dead center for a valve job that never got taken off. well, i started the engine.boom,clank,chingggggggg onto the ground it went,after it slammed into the radiator.yikes. i double check everything now. cheers, brian
  9. ok....so,i have gotten a dream vehicle,getting rid of the wagon and using the brat.i just like the brat betterr.and have talkedd about making a tube frame eventually. back to it,i have decided that i will be towing the brat down. but, i will not be able to have it on a frame yet. so. i have to make some goals,publicly state them and get goin here we go i would like to do the following get the motor in. do shocks and struts trim a little weight here and there actually wire some things properly and wrap up some secrets that i have yet to reveal. more to come as soon as i can cheers,brian
  10. that"bumper" is made by someone that is not allowed on this board anymore. i suggest that if you get ahold of him you do not trust him from afar.make a deal in person with goods exchanged at that time.cheers,brian
  11. didn't figure you'd mind scott.cheers, brian
  12. are toyobarus allowed? it would be nice to be done with the preliminary build by that point.who knows,i'll keep checking in.cheers, brian
  13. pretty much everything you will do will depend what you want to accomplish.sjr and rollie and a few others are up there in your neck of the woods.......check'em out on there shop nights.i'm sure they won't mind.how far do you want to go?that is the question.
  14. did the smoke freak you out at first?the first time i used it (couple years back) i almost lost it......
  15. monstaru
    Pick my car
    there are a few of us around town with some examples.maybe we can hook up soon and share some info.i also have a wagon you might like to look at.cheers, brian
  16. also look into nissan diffs of the r-180 and r-190 . may take a little different mounting ,but is none the less the same damn diff.
  17. does anyone know this figure?from the tranny seal to the end of shaft. cheers, brian
  18. myself, and others have been running them for a while. most under harsh condition and have had better results with these(gck's)than oem,or others.hence the reason i told you to search for them. experience is the answer here.
  19. yota.i am currrentlylooking into the possibility of using an old school spicer 18 transfer case and and t-90 trans.i have a bellhousing for an old 6 cylinder motor that is just the right size for adaptation to an ej-22.it is pretty crazy actually.extremely stoked about this because the gearing in the spicer 18 is low as ************.i'll get pics soon
  20. got some different springs for the rear,which means now i can move the springs on the rear to the front..just need to get brackets and i will mount them. :headbang:
  21. yeah, that was my first attempt at flames.obviously non-traditional.it was fun.i know at least that i can still swing an airbrush..it will be evn better on this rig. at least for the hood.
  22. marriage?girlfriend....huge difference.
