14
Everything posted by monstaru
We use Miller products at work.It really depends on what thickness you want to cut, your power source, and how big of a compressor you have. cheers You can buy a brand new Miller spectrum 375 for about $1300 here locally. If you look around used,make sure that you get one WITHOUT an internal compressor.Those do not blow worth a ************.. The 375 will do up to 3/8ths.Don't really have experience with tables, but it is likely unless you go pretty big, you will have to buy another anyway. cheers http://www.millerwelds.com/products/plasma/
Les Schwab most likely won't touch it as it is modified. Did you look at your driveline?Ujoints will cause intermittent vibes. Your front axles would likely pull to one side or another, I am betting wheel bearing though. Put her up on jackstands and wiggle the entire wheel(tire and rim)If loose feeling there ya go.And I mean wiggle, not jerk back and forth.You need to be able to "feel" what your wiggling for. It will be obvious if and when you feel in comparison to another wheel that is proper. Also retorque your spacers.I never had to retorque mine, but I also torqued minbe to 100 ftlbs the first time I mounted them. It is possible that some of th estrut mounting bolts are loose. Go through and check ALL associated lift nuts and bolts before you go out again. With no luck there, bring your car down to OLy and we'll check her out. cheers
This type of mod has been mulled over a million times.It will not work with consistent success. The only way to go down this road successfully is to utilize another hub and lockout entirely.Scott did one once.I imagine he stopped because it was not reliable.Or maybe that was just his welds.:-p:popcorn: Regardless, the hub was not designed to be used in this manner.You may think that it wil work from your own experience.But , it won't.Using an axle inside the spindle like that without bearings will give absolutely no consistent results.There are wear spots.period. You are not treading on new ground here.others, including myself have done tons of research and R&D.IT WILL NOT WORK the way you have it layed out. cheers
Two words. Stand alone....... Second, awesome project. cheers:clap:
Pics or it didna happen
Way to stay on topic ......
The way to search is to type in whatever brand name you are looking at and google will do the rest.I mean really, specifics?I have used probably 12-15 different sanders in different configurations.Much less how many years have passed in between, models change like socks in that ever changing world 'o' tool.. For all sorts of different things, from wood to fiberglass, and everywhere in between.I prefer Porter cable, but really like my new Makita. Technically, you are looking for a random-orbital sander... Go to a body shop and ask what they would use if it were electric, instead of air. If you really want to do it right, use hand boards to finish it. A little round orbital is going to remove alot of material,no matter what grit is used ...Just food for thought. cheers. PS.Like I said before, ALL of the major brands are made by like two manufacturers now...
You need a spacer between the tophat and bolt.It is making noise.
Buying cheap may not be the bestest.IE Harbor Freight Once you have a tool, it seems that you end up finding purpose for it.(If your ol'lady doesna find it first!) I say plan to go quality.Almost all of the major box stores are going to have several names made by a couple of manufacturers. I have had Porter cable(used extensively professionally),Makita(home use for just about everything), and my father has had Dewalt, Black and Decker,and Milwaukie.My best friend swares by Bosch. You can pay anywhere from 40 to 200 for different sizes. Why do you specifically want a round one? cheers
proportioning valve + rear disk swap (WTB: valve)
monstaru replied to belacane's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I drove my Brat all over the NW with no prop. valve.And let it just be said that I drive my rigs pretty hard,and NEVER, I meanNEVER had an issue with brakeing.... Also never used one on Lilly, and have helped install at least three others that didna use it....... cheers -
quitter....:-p block the tires..DOH!! cheers
I'd like to make it up before I, but don't know if I can....Would be fun to hit her in the mud again.... cheers
we could meet in Tahuya ....... cheers
leaving to go out there now. Gas powa!!!!!:-p Got an extra bike and gear Jessie? ( I only have helmet and gloves) Kidding , kinda cheers
Been setting this up to get into bikes.have an old school friend wanting to Take me two trackin!!!!
Suppose toi be riding bikes up there, but may be driving my car.:-p I know, so definitive. Anyone down? cheers
:-ppost pics or shut your trap... What bar? I drink at bars.... cheers Oh yeah.. Looks good dawg.Want pics of your wife on the hood..)))))) kidding..kinda
congrats :-p
Jeffrey got bunches, but crashed his computer or something on Sat. night... :-\
86' 3 Door Coupe Off Road Conversion Project
monstaru replied to BlackBoot's topic in Old Gen.: 80's GL/DL/XT/Loyales...
kkep it a coupe..... find something else to offroad. -
This is my next set of exploits..That looks Hella fun :-p
told ya If we can find a tire groover we can revamp them and make'em betters, for the butters.:-p
Just weld it...
