deiscient
About deiscient
- Birthday 08/23/1968
Location
Boston, MA USA
deiscient's Achievements
Advanced Member (3/11)
10
Thanks for the fast reply, triple7. FWIW, yes, I am on all original suspension save a new steering rack boot about 4 years ago. The "bounce test" shows that all 4 struts still have good damping. Is there some other test for resilience I can try with minimal tools? I put Yokohama Avid Tourings on around that time as well which I normally keep inflated to ~35 PSI (door jamb pressures are bogus!). I was also starting to think that the sway bar links might be showing signs of wear. Possibility?
This has been ongoing for a while so I throw this out to the intelligent community. For a few years I have noticed that my '93 Legacy sways about considerably when driving at highway speeds (65+ MPH). I generally do not have to correct the steering direction much when driving straight. Nevertheless, the car does feel like it is being blown about considerably even on days with little wind. I have been to a few different Tire/Auto and garages inquiring about this and all have said my steering and suspension components look and feel solid. Is there something else I should be watching for that maybe they are missing? Alternatively, is this just a "quirk" of these cars that I have just gotten more sensitive to over the past few years?
In my case I pulled out the oil filler tube. That left plenty of room to swing the ratchet using a 3". And, yes, I too was done in about 1/2 an hour. World of difference between my Legacy and the wife's mini-van. OTOH, her EmPeeVee has a timing chain instead of a belt (no replacing, YESSS!!) and the water pump is located right on top of the engine. I suppose that kinda makes up for the spark plug situation...
You don't know the half of it. Just replaced the plugs on my Mazda MPV. That has a Ford Contour's 2.5L V6 in an engine compartment designed for an I-4 (for ROW markets). You need an 8" extension...and it is almost impossible to line up the socket-extension to fit inside the plug recesses! On top of that, you need to remove the coil pack to get at the rear bank of plugs where you cannot see what you are doing at all. Good thing double plats are called for (60Kmi life) as I am not looking forward to doing that again for a long time.
I was looking for a replacement corner lamp at 1st Subaru Parts. This seems like a good deal for a new part. However there is something confusing going on here. The illustration is supposed to be for the "right" assembly. However, it looks like the driver-side lamp, which would be my left when looking out the front (I need the passenger-side lamp which is oriented the opposite from the picture. How does 1st Sub differentiate right from left; from inside looking out the front or from the front looking toward the back? Please help as I am completely disoriented.
Okay, Googling "Calsonic AC clutch" yields this document for a '93 Honda Prelude. That model used the Calsonic V5 which seems like the same "genre" as our Calsonics if not the exact match. It contains a procedure thus: So, it can be done with some highly specialized pullers and such. The only challenge remains to actually find a part that would fit. Then again, it does appear from the diagram that the bearing is attached to the compressor body on the Calsonic. That is unlike the Bosch model preceding it in which the bearing is removed as well in the procedure. So maybe the bearing is not swappable after all.
The sound is most like an additional radiator fan above the normal engine sound; kind of an upper baritone-lower tenor pitch. It is progressive with RPMs and only noticeable when the AC is on. It is definitely not the screeching associated with slipping belts. I did read the forums on about.com and someone there mentioned a similar noise that they fixed by replacing the clutch and bearing. I have not seen replacement clutches and bearings sold online for the Calsonic but I did for the other brand common in '93s (Kinki-Diesel?). So, looks like I'm stuck following 777's advice for now.
After nearly 13 years of trouble free operation I am starting to notice a grinding hum from the compressor when the A/C engages. It is progressive with engine RPM and only noticeable while the A/C is running although I have yet to do the "stethoscope" test. The cabin air still blows ice cold. Is my clutch/bearing giving out? If so, is the Calsonic C5-15 compressor clutch unit replaceable on-the-car? I would like to get around having to replace the whole compressor and evacuate/r134a retrofit/recharge/....the whole system if I can avoid it. Otherwise, I think it may be time for r465 A/C (4 windows open/65 MPH).
TriBeCa = Triangle Below Canal. Area south of Canal street in Lower Manhattan. Site of old business and warehouse district that, starting in the late 1970s/early 80s, became a settlement area of choice for young professionals seeking to be close to the financial district. More here. Suffice to say; "what a difference a generation makes." So the name symbolizes renewal and gentrification out of decay. If the City of LA can manage similar regeneration in Watts or South Central who is to say what will happen a generation hence?
Actually, if you want to talk about hideous designs I saw Chevrolet's replacement for the Venture recently. They went from a neatly sloped front to one that looks like a bastard cross between a van and a Hummer; that front end is just too bulky looking. We'll see what happens long term. FWIW, I am starting to see lots of the "fugly" new Chev. models on the streets around here. The Tribeca might just end up fitting that mold despite us.
