12
Everything posted by ferp420
1988 Subaru gl how to lift
ferp420 replied to Jdog2004's topic in Old Gen.: 80's GL/DL/XT/Loyales...
lifting it should be pretty easy but you do have to know how to build a lift kit then you need to find the right angle to correct your alignment for your rig and the amount of lift you want usually between 15°and 20° if your alittle off it's not the end of the world I'm sure there's still guys around selling lift kits maybe contact sjr on here maybe he's still doing them i built my own 5-3 kit about 15 years ago Im still running the napkin lift on the rear of my Impreza it's still not a bad way to go on a budget -
the ea82 turbo has a tendency to crack the heads especially when you give it the beans and dont even try to add the turdbo to the na engine it will pop the first time you get in to the boost
i was hoping to use a ej clutch but it sounds like way to much work ill just make the stupid adaptor plate and drill the flywheel and run the ea duel range box and be happy about it lol thanks for packin the pipe on that dream lol
Driveline angles 81' wagon
ferp420 replied to Silverbull3t's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i agree it sounds like a cv axle try swaping axles personally i would figure out a way to get the rear cvs in and out easily and weld up a stock diff i ran like that for years -
1987 Subaru GL Wagon 4wd: Which struts?
ferp420 replied to kanurys's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it wouldent be that hard to mod a standered shock to work as a strut you just need something to slip in the pocket that can be clamped down on to you can fab up a spring purch with out to much work ford tempo springs and your in buisness ive never actually installed the vw struts i just know they fit i asume you need the loyale top hats i could get some pics and mesurements if your interested in going that route i have a loyale and a superbeetle sitting next to eachother i do have tempo front springs on stock struts up front and 300zx struts on the rear of the loyale with stock springs right now -
superbeetle front struts work on the front of the ea82 they might be easyer to find there not as strong though you can use ford tempo springs on the stock ea82 strut if you just want stiffer or some spring lift if you dont want to lift it and just have stiffer spring cut a coil off ive used nissan 300zx front struts on the rear of my loyale and they not ony have more traval but a larger shaft so there alot stonger than ones made for the ea82 i want to say there the same ride hight as the stock fwd rear struts but im not 100% sure -
how much compitabulityis there between ea and ej transmissions or what i really want to know if i can use the transfer gears and low range from the ea on a ej i wont need to shift in or out of low and i dont really need 2wd ether so i would be ok with it locked in 4wd and low range what whould be needed to do that i know i can buy a ej duel range trans case and use ea82 guts but there not exsacly easy to find ether
the lego springs dont give any lift at all the outback strut has more traval than the lego strut and the spring is bigger the outback spring on a lego strut will be close to full exstension of the strut a lego spring on a outback strut will be at the bottom of the struts traval you would.bottom out alot like that the best lift was outback struts with forester springs but the differance was maybe a 1/2 " at most not worth the extra work or exspence the outback struts give the lego about 1 1/2" of lift a bit more on the impreza but not a true 2" lift note our 03 lego with 2" lift left the rear alignment out of specks we had to buy white racing adjustable rear links to keep the rear from eating tires not a big deal you could also use the drop brackets from the outback to keep the rear alignment in specks xt springs are stiffer than standerd outback springs and the 6 cylinder springs should be stiffer than those
that po420 your car is stoned code sucks ive been fighting it for 20 years on varios subarus i use a spark plug defouler inline with my 02 sensor i got mine at oreallys fixed it everytime i do need to remove it before smog though or it wont pass visual inspection it still pops up every now and again and goes away it always comes on after a long down hill run coming out of the mountains to sea leval then a few day at a stable elivation the light goes off the car still has the original cats on it there over 20 years old and still working fine
if you cant do the head gaskets your self then i would find out how much there gona cost to have done thkse 2.5 single overhead cam engines like to drop there beadgaskets at around 150-200k so you most likely wont need to do them again we payed 3000 to have our head gaskets done at a shop on our 2003 if your payin 3k for gaskets and 2k for the car it dosent look like such a good deal but with the price of used cars today that might be good i dont know for what its worth i just did the head gaskets on my 2000 imp it had 290k on it when they failed they were real easy to do at home and even surfacing them went smooth alot of labor though it took days of sanding to get the heads flat again but thats the way it goes lol heres the start of the surfacing before and after sorry its kinda blurry i glues a peice of sand paper to a granite slab and went to town
check your carier bearing that would be affected by heat and load it could be torn half way through but still wouldent be obviose at a glance and its the lowest point of the drive train vary easy to snag or smack it on something a simple push pull test should tell you if theres a problem down there pretty quick if it moves more than a 1/4 of a inch in any direction thats probably the problem
HELP! 89 subaru EA82 SPFI will not start.
ferp420 replied to Heater's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i have a ground wire conected to it so i never had that problem ill have to take your word for it -
i wouldent consider that a failure but yes these cars seem to have horable grounds ive never seen a car so sensitive but ya any loose ground reeks havoc on the system -
yes you can pulse the spark on the distributor manualy if you just want to test to se if you have spark just disconect the power or maybe its the negative lead ether way one will triger the spark discharge the ignition system on the loyal isent much different than a vw after installing the electronic ignition modual the fuel injection and the ignition dont have alot to do with each other if you dont have spark its usualy ether the coil mostly the coil or the electronic pick up inside the dizzy -
i second the ground wires these cars are so sensitive about there ground wires every ground needs to be good and have a clean conection the body needs to be grounded to the engine and the transmission and to the battery directly also the motor needs to be grounded to.the body and the transmission and the battery the battery needs to be grounded to.the engine the body the battery your left foot and atleast one pubic hair or the car wont run -
Front axle compressed length over spec by 1/2"?
ferp420 replied to azdave's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i reboot and regrease my new aftermarket axles too it doubles the cost of the replacement axle but it doubles the life of the axle also the last axle i bought they forgot to install the clip inside the boot to keep the cage inside the cup so i went to install.it and the damb thing litterally fell apart in my hands -
there definitly differnt style of joints the one with the cutouts use 3 roller bearings inside the other with no cut outs uses balls and cage inside the joint honestly it looks like a custom axle rear diff to front hub to me but i have seen differnt styles of joints used with ea82 axles also extremely differnt shaft sizes and joint sizes theres even a telescoping axle for the front of the ea82s lol from what it sounds like from what the op sead they will both work you can install it then check for binding while the strut is disconected if your worried about it -
i think all ea82 radiators have those ports if you can even find one for a ea82 at all it dosent make sense to manufacture a 2 different radiators for 1 vehicle especially one thats a rare 80 modle disposable econo box
i wonder if anyone has tryed ceracoating the pistons and exhaust ports to help with the extra heat there caracoating diesel pistons to stop piston melt down on n/a diesels with big turdbos like mine lol i know it wont help with the ringlands but might help stop the head from cracking maybe lol
9 i do agree with you but the belt isent a stright line it has atleast 1 90 in it wich will eat up most of the slop minimizing that effect to almost nothing and like you sead a degree or 2 wont effect the performance of a ea82 enuff to be noticable and with the huge power gained way outways the performance lost is there more on the table yes ask ram engins they used to make one hell of a ea82 and reliable too ram has a full machine shop they make there own parts they have engineers i use hand tools and best guesses and my parts arent neer the quality of theres but i did steel some of there ideas like the intake spacers trying to build a ea82 is like polishing a turd even when shinny its still a turd but if you enjoy building engines theres a fun platform to play with cause subaru left so much on the table it gives us something to play with
