shanonsf
Everything posted by shanonsf
flywheels same for ea81 & ea81T
shanonsf replied to shanonsf's topic in Old Gen.: 80's GL/DL/XT/Loyales...
here's the deal I have a ea81T on stand that came outta a project with a RX 5spd D/R & ctr dif & LSD. (yes, I have the tranny/lsd on ice) Turbo motor won't be going in any time soon, nor 5spd. Turbo has a flywheel easily accessible (exposed) and was thinking of having it turned and lightend for the 4spd and later for 5spd when ready will this work? thx shanon -
HeY Q- what this upgrade about....? pls explain ASAP before I order anything/ thx shanonsf
hey all, getting ready to do my clutch and was curious if the flywheels were the same from a ea81 and a ea81T?? I have ea81T on stand, thinking on having it's flywheel turned and ready for my ea81 clutch job, it be very convenient......... thx shanonsf
hey russ, cool, can ya get me a quote for a clutch kit for my 82 GLW (4spd 4wd w/ d/r)? I'll try an give you a call later today, would like to order ASAP......... also, maybe we can take care of thar rear bearring project if & when we hook up?? thx shanonsf
hey all, need to order clutch kit for the wagon (82 glw w/ 4spd D/R). any recomendations and sources?? thx shanonsf
hey all, my bro sent me this link to an Ebay sale...... someone from here has to get this one, a true collector:headbang: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2467472903&category=6467 -shanonsf
West Coast Subaru Show is set!!!!
shanonsf replied to Qman's topic in Meet n' Greet. Your USMB Welcome Center
props for the effort fellas, should be a blast NV Zeno, charge your AC! ha ha, it's toasty thru NorCal & central oregon that time of year!! but hood river might be cooler do to location by water......... might be tuff for me, not location wise, but my wedding aniversary is the 26th................................ hopefully my Xmas present will work it's magic and grant me this road trip... let's start lining up the NorCal caravan! -shanonsf 82 GLW "Snow White" -
can a 6ft4in guy fit in a sube?
shanonsf replied to rallyruss's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i think we have a new contest catagory for wcss6! "how many 6'+ fellas can stuff into a GL!! " think of the foto op!! BTW: I'm 6'2" in a 82 GL w/ gl10 seats, fit fine, but I find brats a bit tight......can't lean back as far -shanonsf -
yeah, my ea81 82 GLW has gotten a lot worse since I pulled the stock air clearner and some hoses/lines. Sure is alot prettier and great access & chrome!! looks like a V8, ha ha approx 275mi p/tank to 175 mi per/tank....bummer not sure if the plugged Vac lines are the cause, but stills runs solid. Mileage suffer'd greatly after my cool new air cleaner set-up & emissions excavation...and tired clutch? has: 8" air cleaner, Accel coil, 1.75 exhuast to turbo muffler, new CAT & emissions crap, forked plugs (Bosch?), 7.5mm wires, blah blah. and a lead foot in the hilly, congested, big city............ -shanonsf
oh yeah, its a 4spd D/R............. :-p shanonsf
hey folks, the clutch on my 82 GLW is on the way out (starting to slip) and I think I have adjusted properly (any advice appreciated). So i am seeking/sourcing clutches and am curious if the clutches are the same for the EA81 carb'd and Turbo motors....?? gotta ea81T on the stand that probably won't be ready before clutch goes.......... looking only to buy one clutch and put turbo motor later this spring......... thx always, shanonsf 82 GLW manipulated
hey all, anyone got the phone 0r URL for CCR?? thx shanonsf
first issue with the webber
shanonsf replied to one eye's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hey all, curoius if you guys are running the electric or water chokes.....? just rebuilt one and converted it to electric.....better cold starts? shanonsf 82 GLW -
hey all sounds like the 4wd EA82 clutch & PP are the way to go. Kinda confused, how is the XT6 kits & PP different? Ideally, which is best and most compatable? thx all- shanonsf
thx folks sounds like i should find/source a XT6 (EA82 4wd) clutch kit and PP. Anyone have thiws stuuf lying arounf per chance?? might need the flywheel too............ props all!! shanonsf
thx for the replies everyone, gonna put the Weber on 1st, to complete 'phase 1' (82 GLW) -work done (phase 1) Accel Hot Coil 7.5mm wires 1.75" exhaust from CAT back to Turbo Muffler KYB suspension RX/xt? 22mm frt sway bar vented frt discs rear discs -to do (phase 1) 32/36 DGEV weber RX/xt? rear control arms w/ sway bar phase 2 (got everything except time curently, ha ha ha ) -refurbish/install EA81 turbo (hhmm, maybe w/ some aircraft bits?!) -Full Time RX 4wd 5spd w/ D/R & ctr Dif & LSD I guess I'll have get Snow White into the Gallery, she's real pretty!! cheers shanonsf
thx all, learning here, I have the full time RX 5spd D/R w/ ctr dif & LSD. I believe the splines ARE different in which I will have to go the with custom axle set up & EA82 steering knuckles & brakes....... didn't know that there are different configurations of 5spds thx again shanonsf
hey all anyone have an idea of the Hp from a weberized EA81 and EA81 turbo........ rebuilt a Weber 32/36, got a EA81 Turbo on stand (needs work) ..............hhhhmmm thx shanonsf
thx Q, EA82 clutch & flywheel, check. I didn't see anything regarding CV/axles & splines....are the stock ea81 CVs compatable..? I thought the 5spd had a different spline count. i got a custom set of CVs that the original 'pioneer' used on his set-up (from donor car). he also put in ea82 frt brakes. is that why he had the custom axls done. Do I have to convert the frt brakes to ea82 also to complete conversion or was that just another 'upgrade'? gracias, shanonsf
right on people!! pics are worth 1000 words!! USMB rocks! shanonsf 82 GLW (manipulated)
thx miles, but didn't completely understand your reply. use an EA81 clutch and flywheel or a basic EA82 clutch & flywheel? and bit of grind on the bell housing..... take a peek under half the boards rides (gallery?) what axle/spline set ups did you guys use?? stock EA81? thx shanonsf
hey all, building up nerve to do a 5spd conversion and have some Q's BTW: 82 GLW w/ EA81 w/ all the bits 1) Clutch assembly, is there a preferred clutch/flywheel set up?
