StapleCheese
Everything posted by StapleCheese
Your dealer was right, your problem is in the transfer clutch. And his quote might be a little high, but not much. Hey, if we wanna drive the old stuff, we've either gotta be D. Trump or Mr. Goodwrench, right? Just keep thinking about how you don't have one of those fancy car payments, and that should get you through the struggle of writing the check. I don't mean to sound harsh -- I hope it works out well for you. Keep us posted.
Sorry to be the voice on the other side of the fence, but I work at a Subaru dealership, and I have to say, if the parts departments at the dealerships had to depend on the 80's subaru nuts (myself included) to make their livings, they'd be screwed. I mean, get the big picture - read some of the other threads here. We certainly *only* look to the dealership once we've exhausted other, cheaper options like junkyards or USMB. Subaru dealers sell parts from Subaru. Believe it or not, Subaru has scaled waaay back on the EA82, etc. parts they manufacture. Just a fact of life. And that fact of life makes those parts more expensive. I know there are some greedy parts managers out there, but let's face it -- you're not gonna get the tensioner bolt by itself. The service and parts departments at the dealership have their hands full supporting their new car and warranty customers, and I can count on one hand the number of cars we've worked on since I've been there that are older than 1992. So the parts we have in stock are for newer cars, naturally. Add to that the number of orders we place for older parts that never get picked up, because someone found a 'better' deal at a junkyard, and you'll see why we just don't spend too much energy on the old stuff. A final thought: I'll bet a dollar and a half that the employees at the parts and service departments that get under your skin are paid commission only. Think about it. Not trying to be mean, just trying to give a balanced viewpoint from the other side. Thanks for your time. Cliff PS - Is it possible to be a Subaru fanatic and use the racist phrase 'cheap Jap steel' at the same time?
85 Wagon wont go over 30MPH
StapleCheese replied to sregor13's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I beg to differ with Skip... I *own* a 1985 GL10 wagon (2wd, AT, non turbo), and it's MPFI. I'll send pics if you like. :-p It's got one fuel filter, under the hood on the driver's side, and an external (not in-tank) fuel pump. See my other posts for notes on that little gem. -
85 GL10 Fuel pump / filter question
StapleCheese replied to StapleCheese's topic in Old Gen.: 80's GL/DL/XT/Loyales...
OK... I've learned a couple of things, here... first of all, there is a filter screen on the inlet of this fuel pump - just look down the inlet side (the tube on the right side of the pump in these pictures) and you'll see an inverted cone-shaped screen. It wouldn't really come out, so I don't think it's replaceable, but I was able to tap quite a bit of rust/metal out of it, so it was probably clogged. Second of all, when a car doesn't start, and people start asking "Is it spark, or fuel?" don't assume it's not BOTH. The distributor on my car is also bad (well, actually the pickup coil/ignition module is bad, but who's splitting hairs?) so it was actually a spark AND fuel problem... both intermittent (yes, I'm now bald). Fortunately, there is such a thing as USMB, and I've located a replacement here for purty cheap. If your car is like mine, which is the only one I can speak for, it has the late model Nippondenso distributor in it, which has the internal ignition module. This distributor can be identified by two wires exiting the distributor body (the two that attach to either side of the ignition coil primary), one yellow, one black, and both terminated with ring connectors. If you disconnect these wires from the coil, the resistance across them should be 130-190 ohms. The resistance between either of them and the distributor body should be infinite, i.e. open. If not, you need a new pickup coil/ignition module assembly, which can be removed without removing the distributor, with a little care (just dont drop the circlip that connects the vacuum advance unit down into the distributor!). Removing the distributor requires #1 BTDC (as most of you know - I didn't, I'm new to this), so it behooves you to 'leave it be' if you can. What a great resource - thanks for all of your help, guys! -
Alternator/Voltage Regulator Questions...
StapleCheese replied to oobnuker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You'll need to wrap the pulley with a few shop rags to protect it, and then get it cranked into a big bench vise. Then, as is mentioned above, an impact wrench is ideal, but if you're feeling mighty, a big breaker bar might work. Instead of the rags, maybe a belt that's a little too big (so it sticks out past the diameter of the pulley) might work? This is the way I've seen it done... hope this helps! -
Yeah... for obvious reasons, I'll be putting a filter in between the tank and pump when I put it back. It doesn't make sense not to protect a $130 pump with a $5 filter. I'll probably put a shutoff valve inline back there somewhere, too... Thanks for your help, guys. I'll update as I learn anything new. -
Well, I was able to pull the fuel pump from the car last night, although I pulled the whole bracket instead of just removing the pump. I'm gonna take it by the Subaru dealership (I have pals in the service department) and see if: it works (FI fuel pumps have to develop substantial pressure) they have a replacement (if I can't talk GravelRX out of some parts... hee hee) If you're reading this thread as you consider tackling a similar problem, here are some caveats: You're probably addressing this problem as the OEM part fails - by this point, rust has taken over this vulnerable location. There are three bolts holding this bracket on - I broke two, even with WD40 and patience. All is not lost though; it should be relatively easy to remove and replace the bolt remnants. If you're addressing this problem (like I was) in a public area like a grocery store parking lot, HEED SUBIEMECH'S ABOVE ADVICE!!! MAKE CLAMPING OFF THE HOSE FROM THE TANK YOUR FIRST STEP!! Vise Grips won't do unless they're clamping two blocks of wood to either side of the hose, and even then, you'd better do a dry run first. Nothing sucks worse than lying on your back, under a car, in the dark, in a pool of gasoline and holding your thumb over the end of a hose that you can't let go, waiting for some jackass to drive by and flick a cigarette out the window. I was able to clamp AND plug the hose appropriately, but my imagination painted a clear picture of what it would've been like to be unprepared. The next time I do this, I'll seriously consider siphoning the tank dry first, and letting the remnants drain into a gas can. I went at this with a half full tank (ugh!). You're STILL going to get gasoline on yourself. Dress appropriately. It WILL run down your arm as you disconnect the hose. I might be superparanoid, but I'm still here: I disconnected the negative battery terminal before I started. I know it sucks to reset the clock and your radio stations, but somewhere in some hospital room, I'm sure, lies some burn victim who'd much rather be resetting clocks or radio stations right now. And if you live through an exploding fuel tank to be a burn victim, consider yourself lucky. Part of the procedure here does involve unplugging an electrical connector, and a spark is all it takes. (Yes, there SHOULD be no juice at the fuel pump with the key off, but I NEVER assume while I'm troubleshooting.) OK, sorry... I'm through being everyone's mom. (But I like you guys, and want you to stick around a while.) So, here's what I pulled: I still didn't see anything like a filter or a strainer. Is it part of this fuel filter assembly? Thanks in advance for any insight! -
Thanks! She's stranded at the grocery store up the street, so I'm gonna go pull that wheel and see what I see. I'll let you know. cliff -
I've got an 85 gl10 wagon (EA82, MPFI) that won't start. We've narrowed it down to a fuel problem by spraying starting fluid in the air pipe. The filter under the hood was just replaced, so I'm wondering: is there another filter at the back - you know, with/in the fuel pump? This car sat for quite a while, so I think it's a good possibility that such a filter (if it exists) might be toast. Anybody have any good, bad or ugly experiences with the fuel system they'd care to share? Thanks in advance for your help!
