iceageg
3
iceageg last won the day on April 30 2017
iceageg had the most liked content!
About iceageg
- Birthday 08/02/1977
Gender
Male
Location
Denver, CO
Occupation
CAD Manager/Shop Manager
Vehicles
86 GL 2dr Wagon
Recent Profile Visitors
iceageg's Achievements
USMB is life! (4/11)
40
The Redline Webber does cost more, but other than waiting for the JB Weld to dry it can be on and ready to drive/tune in under an hour (provided you prepare properly before starting) and as we both pointed out, all of the missing parts can be swapped from one to the other in minutes. The OP asked if there were any kits available. This is the closest thing that I have found or seen mentioned anywhere on the site. There are lots of other options that vary in complexity, cost and long term maintainability but this is the only option for a "kit" and that is worth noting.
When I finally got mine out I found that it was completely coated in a thin, clear rubber/silicon film. It almost looked like somebody used a clear RTV to lubricate the O-ring during assembly instead of an appropriate o-ring grease. The pump would spin but I think that film was acting like a suction cup and preventing air from sneaking in to fill the space that the pump was vacating as it was extracted. If you can try spinning the pump as you pull on the bolt that you tapped into the pump. Or like DaveT said you may have to drill/cut the thing in half while still in the block. at least enough to get it to collapse in on itself. Use EXTREME caution if you go that route though. Very last option.
It hasn't flown yet. When we took the cowling off we discovered a massive crack across the front that somebody had covered with bondo to hide it without repair. So the cowling is off for composite work. But it should be a fantastic performing little plane. We do have a Cruismaster owner interested but he has not pulled the trigger yet. Most of the standard kit will bolt right on but we'll need to get creative with the ductwork. The Cruismaster has a very different setup for the frame that holds the nose gear components than the Viking. Which Vortechs are you using for this? We have stopped using V1's and use V3's for all of our new installs above 360cid. Unfortunately belts are a must for us as they eliminate the potential of a failed supercharger from mechanically damaging the engine in flight. While the belt can not be considered a designed failure point we did demonstrate during testing that if the blower seized the belt would slip until it fell off without damaging the engine. So much destructive testing that you will hopefully never experience. Anyway, more pictures and updates please. Loving this.
Mmmmmm, superchargers. Just finished putting one on a Bellanca Super Viking today. Where did I put my popcorn!
Can't go wrong with the Weber. If you do split the block the Delta torque regrind is a great deal for the money. That combination got me alot (by EA81 standards) of low end performance. Even if you add the SPFI pistons and do all the other stuff that has been tried here you will still struggle to get to 100hp though. So keep your expectations realistic.
I had the commercial counter at Advanced Auto source me a set of Fuii Heavy gaskets. Not sure what the front counter would have given me but we order a fair amount of stuff through them and the commercial guys in the back of the store have always done a good job of seeking out the parts we needed or telling us strait that they can't source it.
Same thing happened to me. Mine was leaking from a visible crack in the pump before I attempted to replace it. After removing the bolts it basically fell into pieces in much the same manner as yours. Here is how I got it out. 1) remove the grill, radiator, etc. to get a clear line strait at the pump. 2) stuff a small rag or paper towel in the holes that access the oil system. 3) drill and tap a threaded hole in the stuck portion of the pump (NOT all the way through). The wide flat internal surface at the 06:00 position worked for me. 4) thread a bolt into the newly tapped hole. 5) use a combination of pliers and pry bars to wiggle it loose and pull it out. After much swearing and wasting of time this is what eventually worked for me. YMMV. Good luck.
Wanted: EA71/EA81 & Gen 1 & 2 BRAT Decals
iceageg replied to HawaiiBrat's topic in Historic Subaru Forum: 50's thru 70's
The decals are fairly easy to reproduce these days provided you have a sample that you can take a picture of holding a ruler next to it. If you can't source any you might try that route. -
1990 Loyale turbo in jy, 90,000 mi CO
iceageg replied to sparkyboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Rear disk breaks intact? -
Ea81 hydraulic lifters.
iceageg replied to Strutmaster801's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Delta Cams can also recondition them. -
Russian spam-bots have been mucking up the site for a while now. They get banned and their posts deleted. All is quiet for a while and they come back. Pay them no mind and certainly don't click on the links. Keep up the good work!
EA81 exhaust... so this happened...
iceageg replied to Knucklehead Saloon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Different benefits and drawbacks, usually decided by space constraints. In a nutshell, would the extra routing and twists needed to fit equal length headers end up less efficient than unequal length for a specific application. It's usually not an issue but there are still plenty of examples if you go looking for them. Mercedes has done some unequal length headers in their cars in the past. Talking outright power, their 2015 F1 cars had unequal length headers and dominated that season. Mercedes also did some strange stuff with them way back in the day on airplane engines like having slightly different compression ratios on the left/right cylinder banks to account for the different exhaust efficiency on each side. You can also find them on high end sport bikes like some years of the Aprillia RV series. Of course you can't ignore the obvious example of how well they have worked on Subaru's for so many years. Bottom line is companies with huge R&D staffs full of brilliant engineers have proven that unequal length headers can be a better and more efficient choice in certain applications. Equal length certainly have more power potential but that is not always true when considered as part of an entire chassis design. Besides, as you pointed out they always sound better on 4 cylinder engines and that counts for something too. Glad to hear you are happy with your result. -
Ea81 increase in power
iceageg replied to YaBoyKingsley's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I just did the webber and cam replacement on my rebuild a few months ago. Made a huge difference between 1500-4400RPM. Above that it isn't noticeable. I will eventually open up the exhaust a bit (it does need replaced) but I haven't got there yet. I didn't take the time to source SPFI pistons but I am still happy with the result. As I understand it the head design is the main limiting factor. For all the improved air in and exhaust out work you can do, the heads are still the roadblock to performance on this engine. Polishing the intake may actually hurt your performance. The way the theory goes, you need a thin layer of turbulent air to keep the fuel from sticking to the walls of the manifold. Like the dimples on the outside of a golf ball. If your engine was fuel injected and only air was passing through the manifold then a polished intake would undoubtedly be effective. Something to keep in mind. Do share the results if you decide to polish yours though. -
You might be able to use a rear break pedal or gear change lever from a motorcycle. I have seen them with splined holes and an allen head bolt to clamp them down on the input shafts. Might have to do some searching to find one that was the right diameter but it would definitely be metal if you found one. It's a long shot and certainly wouldn't look original, but it may be a functional alternative.
