wakingtowinter
Everything posted by wakingtowinter
Looks like my A/C compressor is toast. It makes a terrible grinding/growling noise when I turn on the A/C. Took the belt off and the clutch spins freely but the main bit turns roughly, like it's catching on spots. Idler pulley doesn't feel great, but spins freely and doesn't feel like it's near seizing. I've read that once a compressor bearing goes bad, all kinds of metal debris can be introduced into the system, thus the need for a flush before the new compressor is installed. Is this really necessary? I don't think I can do the flush myself--looks like you need compressed air and I don't have that. I was hoping to just toss in another compressor and charge it with a can from the store. Is it necessary to replace anything else like the condenser or drier?
wtdash - or anyone else who has done this work around: which is the IAC hose that needs to be T'd into? I plan on using my EJ18 EGR intake on the non-EGR EJ22 that is about to go in. The IACV looks a bit different on the EJ18 and from wtdash's write-up I can't quite tell what to T into:
Yeah I've installed the whole system, but I guess there's always the possibility that I got a bad actuator or switch or something. These were all junkyard parts...So what I'm hearing is that I really should get a computer from a 93-95 impreza with a manual transmission, is that right? It couldn't be from a 95 legacy with a manual transmission? Aren't those both the 5MT?
I have a 95 Impreza L wagon that I have added cruise control to. It's an EJ18/5spd. But I haven't been able to get it to work and I'm not really sure where to start. I was wondering if anyone can tell me if the cruise computer is specific to the model and/or trans (manual vs auto). I have tried a couple different computers. With the first one, I would press the cruise button on the dash and the orange light would turn on, but no response when trying to actually set the cruise. I tried another computer, and the orange light wouldn't even turn on. Is it possible I have the wrong computer?
OK great, thanks guys. My car already has stock WRX wheels so I'm good there. and yeah, I'm talking about rear brakes only.
I've searched and can't find a clear answer on this. I want to do a rear disc conversion on my 95 L wagon and one guide I read says that anything up to 2001 will work, whereas I've seen other people using WRX brakes in the back. There's a guy selling everything I need off a 2002 WRX, including the parking brake cables, which is one of my questions. First, will these knuckles bolt up on my car? Second, will the parking brake cables be of appropriate length?
A couple months ago I had trouble getting a vehicle to pass emissions and I used the CRC "guaranteed to pass" stuff that is available at most auto parts stores. I also dumped in a couple bottles of Heet fuel line antifreeze, since I read that works well too. Not sure if all that was overkill, but I definitely passed that time!
what does this connect to?
wakingtowinter replied to wakingtowinter's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No, I ended up finding it in the giant pile of parts sitting in the back seat. -
carb'd ea82 into 89 SPFI wagon?
Just a note for anyone who might come across this situation in the future, the tip about timing was right on the money and I couldn't have gotten it running without Gloyale's advice. I had a no start for three days. I had spark and fuel so I was sure it was timing and I redid the timing belts to no avail. Then I remembered this advice and tried putting the distributor in at about 20 degrees after TDC. Had to redo it a couple times to get it right on but now it runs great. With timing set at 0 TDC I could not even get a sputter. -
I ended up figuring it out. It is the solenoid valve that hooks up to the throttle body and EGR valve. -
Anyone? -
Awesome, thanks -
I have a carbed ea82 that I want to put into my 89 wagon. From my research it's my understanding that my spfi intake will bolt on and I just need to plug the EGR ports down by the exhaust ports. I see the carbed engine has slightly lower compression but not enough to make much of a difference. So that is all OK but then I read this thread on nasioc: http://forums.nasioc.com/forums/showthread.php?t=1286747 This guy toward the bottom insists that the cams are different enough to cause problems. Do I need to swap in my old cams or should I just toss it in as is?
Help- I need a picture of something
Those are good pics but they don't show the part I need to see, the end of the cable just underneath where the clutch cable attaches to the clutch fork -
ea82 with flat drive belts?
Ok, got the answer to that question. Did some more reading and found that the work would be similar to an EJ swap so now I am leaning toward swapping the SPFI heads onto the new block and going from there. Can this be done with the engine in the car? Just dropped it in on Sunday and now I find this out. -
The heads are definitely mpfi. Dual ports, so yeah my old intake will not work. I looked in one of the spark plug holes and the pistons are the regular non-turbo pistons. Reason for swapping the engine is it had no oil pressure and sounded like it had piston slap. Then the clutch fork went so I figured I'd do it all at once. If I get an mpfi intake are there any issues with hooking it up to my existing harness and plumbing? -
What should I take photos of? Just the pulleys? -
oh this is just beginning to get interesting, isn't it...I was planning on just bolting on my old intake (SPFI). is that not going to work? -
Swapping a used ea82 into my 89 GL. Came with no intake, PO said it was carbed. All the pulleys on my old one were for V belts but the new one has pulleys for the flat, grooved style belts. I would just swap all the old pulleys onto the new engine but the old crank pulley is stuck on (I tried a 5 foot cheater pipe) and it got cracked somewhere along the way anyway. Now I will also need a alternator pulley for the flat belt since the new engine came with no alternator. I've looked on rock auto and every application I looked at between 1985 and 1994 uses a V belt. So what year/model used a flat belt? Would I just be better off getting a new crank pulley and swapping the old pulleys onto the new engine? Either way I have to hunt down a pulley, although I'm guessing the V belt crank pulley will be easier to find than the flat belt alternator pulley.
ea82 oil pump questions
I have another question about this job, figured I'd post in here again. I see a lot of people saying that they leave the t-belt covers off with no problems, and I was wondering if this is still going to be OK for a wagon that's going to see a lot of snowy and icy conditions.
