steve56
2
steve56 last won the day on September 13 2018
steve56 had the most liked content!
Gender
Not Telling
Location
Seattle USA
Occupation
Real Estate
Vehicles
I Love My Subaru
Recent Profile Visitors
steve56's Achievements
Subaru Fanatic! (6/11)
15
Bought a 2009 Impreza with 109k miles with engine problems. Owner said it was blowing cloud of exhaust out of the tail pipe. Had my Subaru Tech friend stop by. He didn't see any evidence of head gasket failure or bearing failure. I pulled the engine, did a leak down test and all the cylinders had less than 5% leak. However cylinder #1 has oil residue on the exhaust valves. He thinking its a ringland failure on the #1 cylinder. He is coming back in a couple of days, redo the leak down test and probably pull the #1 piston. I was wondering if anyone had experienced ringland failure.
Update. My Subaru tech friend came over with the Subaru code reader. I had eight stored codes in my Actron meter, but the Subaru meter showed just one code. That was for the oil temp sensor. I had forgotten to swap that in to the head I was using. I have no idea why my Actron meter was showing eight unerasable codes. The other procedure to erase the codes which I tried yesterday was what he called a cap discharge procedure. Thats with key out of ignition the positive and negative battery cables are clamped together for 5 minutes while holding down the brake pedal for 10 seconds.
Installed a 2010 jdm engine with original usdm heads and intake. It runs fine but still has error codes P0026 and P0028. Looking for the diagnostic flow chart and any other suggestions for clearing the codes. Got this code clearing info from Foreign Engines of Lynnwood. Does this sound like sound advise. Method number one. 1. Turn car off. 2. Disconnect positive battery cable. 3. Turn headlights on. 4. Touch positive cable to negative terminal. Method number two. Look under dash for two green connectors. If they are plugged in, disconnect them. I looked under dash and did not see the two green connectors either plugged together or unplugged.
