steve56
2
Everything posted by steve56
Have 06 Legacy. The heads are recently resurfaced. Resealed the cam plate and put in new cam seals.Started dripping from ds cam seal about one drop every five minutes. Reinstalled a new driver side cam seal and have same leak. There is oil on bottom of seal. I thought the cam plate was leaking because there is oil right below the cam seal where the cam plate and head are come together. Have a couple of pictures, but can't really see the oil on cam seal due to not being able to download a high resolution picture on this site. I'm looking for some direction to determine if its the seal or the cam plate that is leaking. The only thing I haven't done is cleaning the came shaft with fine grade Scotch Bright pad to make sure there's no build up on the surface of cam shaft that is stopping the cam shaft seal from sealing properly.
What is the proper procedure of installing Timing belt on ej25 with engine in car. I'm missing my left index finger due to accident decades ago. When I put the toothed pulley next to last and the lower idler pullet last, always have to fight to get the toothed pulleys bolt started. When I put the tensioner pulley on last I fight to get that bolt started. So I'm looking for a solution for a guy with a compromised left hand.
Hi Tom. Thanks for posting your review icarsoft scanner. I have the autel ml629. It read the srs code on my 07 Legacy. Autel tech support said the ml629 is the global scan tool. They suggested getting the al629 which is the american version and easier to update. Will get the al629 today and will be sending the ml629 back to Amazon. Amazon already refunded my account for the ml629. They said I can keep both scanners for 30 day and keep which ever one works for me. Autel wants me to send in the registration # on the al629 just to make sure it the correct American model. They said there is a Mexican al629 which would have the same potential problems as the global ml629.
I did the re solder of map light and still have srs light on in gauge cluster. The Autel 629 is reading the code but not erasing the code. Could have repaired the map light and the Autel isn't erasing it or the repair didn't work and the Autel is working correctly. Like your idea regarding doing a few drive cycles and seeing if the srs module is looking at some other database before it turns the srs light off.
