steve56
2
Everything posted by steve56
Didn't know I needed a couple of drive cycles to turn off the srs light after repair. After watching MrSubaru code 26 YouTube video, I thought the srs light was instant off after the problem was corrected. I haven't done any drive cycles. Maybe mine is fixed and I just need a couple of drive cycles for light to turn off.
I thought r1 thru r4 were the resisters. Are you saying r1 thru r4 are just the resisters for the bulbs. D1 and r1 thru r4 test results are on the paper to the right of map light. Where are the resisters that I should be testing with the meter. Sorry for all the questions. I'm a novice at this srs problem I'm having. To clarify. The number in the boxes on the paper next to the map light are ohm measurements from my multi meter.
Yes I did the solder repair on map light assembly once with no luck. Will check the under drivers seat harness. There is supposed to be an eight pin connector under the dash by the steering wheel column that is an srs test connector Haven't found any info on line regarding how to jumper the pins to get srs codes. I know the error code for the map light assembly issue is 26. Would like to verify what code is actually turning on the srs light in my gauge cluster.
