steve56
2
Everything posted by steve56
I think I found the problem. There is a Cclip that normally stops the TC from coming out when removing the engine, is not letting the TC go back in that last 1/2 inch. Its a 2004 Impreza and the Cclip sits about an inch behind the front trans seal. It looks like the Cclip needs to be permanently removed to get the TC back to its proper position. Need to know if that method is the procedure I should use.
The trans never came out, just the engine and TC. The engine was seized so couldn't undo the flex plate to TC bolts. It actually broke a rod. There were pieces of the rod stopping the crank shaft from turning. The problem I'm having is getting the TC back in the trans to its 1/4 inch out position. It looks like the Cclip that stops the TC from coming out, now wont let the TC go back in that extra 1/2 inch.
The oil pan is off. The end of the connecting rod that goes around the crank shaft is broken off an laying in the oil pan. The rest of the crank shaft is jammed up between two aluminium bars that are part of the block. Crank shaft will not turn clockwise with breaker bar or impact gun on crank bolt.
Putting cams, cam plates and valve train back after head resurfacing on 07 ej25. How do you tell which cam, cam plate, and valve train go with which head. Looks like cams aren't switchable. I beleive the valve trains can be used on either head and the cam plates are for the specific head, either drivers side or passenger side.
Have 07 Impreza with two copper washers and a u shaped copper washer that hold the power steering pump hose on top of power steering pump with a bolt. Do the two washers go on the inside or the outside of the u shaped washer? Whatever I'm doing is incorrect because the power steering fluid is leaking from the connection between hose and pump.
