smartin
About smartin
- Birthday 10/19/1954
Location
bethpage
Occupation
driver
Vehicles
I Love My Subaru
smartin's Achievements
Member (2/11)
3
Sorry this update took so long. When I finally got to it I had some one hold the latch release up while I played with the hood. Had to actually pry up slightly with a screw driver but it popped up. All gunked up and just stuck. cleaned lubed now seems to be working fine.Thanks to every one that commented. if that cable had broken or come unhooked this would have been a night mare.
I haven't had time to get into it yet but it looks tricky. If the problem is at the pull lever it will be easy if it is any where else ouch. If you look at the picture this is a hood latch from a 2006 outback I am willing to bet they are basically the same. The problem is the cable protector on the right side. It prevents reaching in through the grill and just pulling the cable outback hood latch _.html
Any ones thoughts on this issue welcome. When the temp is below about 72 the ac works great. From about 72 to 82 it will run for 10 to 15 min. and crap out. Over about 82 it is doubtful it runs at all. I checked the gap and it was at top of specs. removed one shim now right in spec. same issues. removed other shim no gap same problem. The clutch attempts to engage spins a little and stops over and over. This leads me to believe the electromagnetic coil is shot and when it gets hot doesn't have the power to engage the clutch?? I found and bought a whole new clutch assembly. The clutch plate comes right off after that not sure. read some are pressed on others slide right off. In the event it is pressed should I be able to use my gear puller tools to remove it?? Also when putting it back on does it help to heat the coil and freeze the shaft. Any one experience's would be welcome thanks.
Would like to hear any ones thoughts on this issue. When the temp. is under about 72 the ac works great. From about 72 to 82 it will run maybe 10 to 15 min. and then shut down. Over about 82 it may or may not run at all. I checked the clutch gap and it was a little over the recommended max. I took off the clutch and removed one of the shims this put the gap right in spec. Had the same issues, removed the other shim same problem. When it isn't working the clutch spins a little and stops over and over it is trying to engage. I now believe the coil is shot and when it gets hot it loses the strength to engage the clutch. I was able to find and buy a new clutch mechanism in it's entirety. I have no problem removing the clutch plate after that I'm not sure. I have read some clutches are pressed on some will come right off. In the event it is pessed I have assorted bearing pullers should I be able to use these?? Any ones experience with this please respond. Also when replacing it would heating up the coil and cooling the shaft help it to slip on easier? Thanks
Radio out
smartin replied to smartin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Who ever said there isn't life after death. After three days I started up the car and sure enough the radio came back to life. -
Today as I came off the expressway there were some bad pot holes I hit one of them and the radio of my 2008 Outback went off. Seemed like it had to be hitting the pothole that was the cause. The only thing I have checked so far was the fuse. It was good. I would welcome any ones thoughts on how to proceed trying to figure out where the problem lies. Thanks
