5
Everything posted by Dee2
Metal scraping sound near pulleys
Dee2 replied to Tony Cortado's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yep, sounds like a bearing squeeking. If one of the timing belt idlers or tensioners is going out, probably time to change them all. -
Sounds like a timing problem. Double check to make sure you have the spark plug wires connected correctly. It's an easy mistake.
- 19 replies
- 1
- distributor
- timing
(and 1 more)
Tagged with:
Update on resrticted exhaust issue
Dee2 replied to kmpdx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There's something you don't see everyday. -
I agree white smoke is not normally burning oil. If you're getting low compression, did you try doing a wet/dry test ? I also recommend a vacuum test to check to confirm if the low compression problem is rings or valves.
Have you done any tests on it -- Compression tests? vacuum tests ? Is there a lot of smoke from the exhaust when you drive or a pool of oil in the driveway ?
It's probably a leak around the oil filter or pump. The air blows it up into the engine compartment. I had an oil filter leaking one time and had oil all over the engine compartment and even into the air filter.
Maybe this will help. How to test an alternator. Diagnosing Alternator problems If the alternator checks out and the battery is still going dead, then the likely culprit is a parasitic drain and there are more videos for tracking down that problem.
Weird squeal when disengaging clutch under load
Dee2 replied to Nickoli's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You can see many examples of how to do it. Check youtube or google it. -
A squeal is usually a fanbelt -
The mystery rattles and the short term smoke
Dee2 replied to Paperscale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had a weird rattle like that one time. Turned out to be a loose bolt on the alternator. Look around the engine compartment for any loose bolts on anything bolted down. -
fuse ?
Did it run properly before the repairs ? If you just leave it idle, will it stay running ? What have you checked/changed so far to resolve the problem ?
Search this forum. That has been asked and answered before. May even find photos. There are a couple of tricks to getting the dash off .
They are prone to solder failures on the circuit board. Easily repaired. Many posts and photos on the problem.
I'd let it dry out some more then see if it starts.
You may have a cracked head.
For color, look at Rustoleum "canvas white" and see if you find that close enough.
The old "my car won't idle" thread again
Dee2 replied to rae houghton's topic in Old Gen.: 80's GL/DL/XT/Loyales...
+1 Put a vacuum gauge on the brake booster line and get some actual diagnostic data - can't hurt. -
+1
What happened? (Shifter linkage, U-joint, ?)
Dee2 replied to subinubi's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I don't see this car worth $500 with all those problems. If you decide to do this project, i would offer substantially less. I would start with offering to haul it away at no cost to the owner,
