5
Everything posted by Dee2
If it happens while driving, it could be the wheel bearings. I used to get a "rubbing" sound from front end of my car and it was the wheel bearings. Were the bearings redone recently ? If not maybe they're due. If they were, sometimes they need to be re-torqued after driving for a while. If it happens at idle, then it might be the idler bearings for the timing belts.
Take the distributor cap off. For each plug contact in the cap clean with very fine sandpaper or emery cloth, so there is no oxidation on the metal contacts. On the rotor, clean the metal contact also. Carbon fouled Black, dry soot on the electrodes and insulator tip indicates a carbon-fouled plug. This can be caused by a dirty air filter, excessive driving at low speeds, too rich of a fuel/air mixture or idling your vehicle for too long.
There's a chart in this thread
Burning up alternator belts
Dee2 replied to Ionstorm66's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A burned belt will slip. A new belt should be fitting down into the V. Sounds like you may be buying the wrong size of belt width. -
Many things could cause the problem you are experiencing.... Did you buy gas just before the problem started ? When were the fuel filter(s) last changed ? Have you checked the air filter ? Try cleaning and sharpening the plugs before spending money on replacements. Have you checked the distributor to make sure the contacts are clean and the rotor is in good condition ?
After you finish the repairs, you can clear the codes and the light will go off until another problem is detected by the computer.
Starts; but let the key go to run position(dies)
Dee2 replied to mickytrus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This sounds more like an electrical problem than a fuel problem. If the fuel supply were cut off the engine would likely sputter for a while then die. Sudden death seems more likely to be electrical. -
A lot of folks replace their ignition with a push button. I found this There a re probably many more articles to help. -
Better valve cover grommets?
I've had good results with Altrom products -
Vinyl dye/paint on the interior
What's the name of the paint/dye stuff ? -
Check the easy stuff first. --Was it running properly before the repairs ? --Are the plug wires hooked up correctly ? --Are the timing belts installed correctly ? --What else was disassembled during the repairs ?
Picking up a Loyale- things to look for?
Dee2 replied to Hex1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You should fix the oil leak before you get a fire...... -
Right pull persisting after alignment+tires
You can also tell if the bearings are bad by simply checking for wheel movement. Raise the wheel off the ground a few inches. With your hands at the 6 and 12 o'clock positions rock the wheel by pushing and pulling. Any clunking or free play will mean the bearings are gone. -
By chance, did you buy fuel just before it stopped running ? It's rare but you may have gotten some bad gas. Or possibly gas with too high of an ethanol level ?
That's a wagon
Something's not right, so you have to keep verifying until something is found.... Once it's found then we can figure out why....
There are four things needed to fire an engine -fuel -spark -air -compression Do compression check. If there is still no fire then your timing is way off. Check to make sure the plug wires are in the right order. Check the timing belts to make sure they haven't slipped.
87 XT idle issues. Dies when in gear.
Dee2 replied to SiriusBlack's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Have you checked your transmission fluid ? May also be the vacuum advance is not working.- 82 replies
- idle issues
- 87
(and 2 more)
Tagged with:
here's a link for reading codes. I'm not sure where the test connectors are located on your vehicle. https://www.troublecodes.net/subaru/ searching this website for ECU codes/connectors may bring up more specific info- 82 replies
- idle issues
- 87
(and 2 more)
Tagged with:
Since you are still probing for clues, I would do a fuel pressure check. The tank may have sludged up the feed line to the pump. Also, when the engine is idling, I would stick a vacuum gage on it and see if you can learn anything.- 82 replies
- 1
- idle issues
- 87
(and 2 more)
Tagged with:
Maybe a fuel pressure problem (?)- 82 replies
- idle issues
- 87
(and 2 more)
Tagged with:
if it's been to two shops and they agree there is a pull, they should be able to tell you why and give you an estimate for repairs. If it's not the alignment, we can only guess at possible causes. It could be tires, brakes, accident damage or ?? Only an inspection can really solve this problem. -
who did the alignment ?
