Posts posted by scooby454
Update. Took care of the relay, wasnt that. The pump isnt getting power. I had someone start her and i didnt hear it turn on. Got the pump today so im going to switch it out tomorrow when i have time. If that doesnt solve the problem what could it be?
If this doesnt work.ill bring it out there. Towing is just a hassle , ha
Even if i get her running id still like to get you to look at her and tell me what im sitting on.
Okay so its with the mother fuses. I thought it may be under the dash. The help is appreciated!!!
Check your fuses.
Also did you turbo the car? If not the thread title may be very misleading to people. The 2.2 didn't come in a turbo version in the US in 97.
Hey, would you know what fuse it is. I searched on line but only found info on off topic wiring problems. Thanks for the help!!
You can probably count on doing many other changes on that thing. DIY turbo kits are usually ticking time bombs.
What else would you recommend looking into?
The previous owner turboed her. Im going to check all the fuses when im off work tonight. I went ahead and ordered a new pump. Shes at 150000 miles so it cant hurt to change it.
I'm looking for a little help here, hope to find it. I have a 97 impreza and she was running rich. I went to accelerate then she completely died! Im thinking o2 sensors. The other strange thing is i went to check and the fuel pump and it isn't turning on. I'm running a scan Friday so i wont no codes until then.
I gave him a call earlier today, he gave me a great advice on what parts I need and where to purchase them. If I wasn't working on this myself I would take it to home without a second thought!!!
Its a 1995 impreza l. I'm going to run a compression test tomorrow .I've been looking up only but haven't found any compression test results.what should my compression be at? Thank you very much for the information its a big help.
So I am having a similar problem. My crank pulley came loose and I have replaced it but now my car won't start. Any ideas will help
97 impreza 2.2 turbo
Posted
Well shr started.up.after the.instal. Thank.you for the intel. General disorder i would.lile to.grong it to your.shop so.you.could look.her.over. .....thanks
