zmarrott last won the day on June 18 2017
zmarrott had the most liked content!
About zmarrott
- Birthday 01/21/1993
Gender
Male
Location
Provo, UT
Interests
Working on the cars, driving the cars, modifying the cars, and the occasional video game
Occupation
Ken Garff Ford Technician
Referral
dont remember. probably google a long time ago
Biography
workin on fixing up my 3 subarus. love the old 80's leone's
Vehicles
1985 GL Hatch, 1986 Brat GL, 1988 GL 4WD
zmarrott's Achievements
USMB is life! (4/11)
12
For over a year now ive been chasing my idle issue on my car. When sitting at temp idling, it will hunt between roughly 1100 to 600 rpm. Occasionally will stumble and have very little power for a split second when i accelerate from a stop. When desceling in gear it will jerk sometimes and other times give no engine braking force. Intake has been smoked multiple times and no leaks except for very small bit before the throttle body around the airbox. Cold start is commonly at 2000rpm amd will stay there for a few minutes until the engine gets near temp. Sometimes the cold start will be at upwards of 2600 rpm too. Things ive done in the past year to try to correct this issue include, new iacv, new tps, new spark plugs and wires, valves adjusted, pcv leaks fixed, broken airbox replaced, new front o2 sensor, cleaned throttle body. Most recent was the TPS and recleaned the throttle body about a week ago. The spec on the tps is to read 0.5 v at closed throttle. My car being non adjustable on the tps sits at 0.6 v. It seemed to run fine when i first put the sensor on and test drove while watching the scanner data, but now has gotten worse again. Throttle plate has been adjusted as far closed as possible too. Any ideas/tips on what could be my issue?
So i already understand the programing process for keyfobs to my car, but im wanting to change the remote. Id like to get a key/remote single piece, like some of the newer subarus have, vs the key and remote are 2 separate pieces on my keychain. Has anyone done this before or know of a key/remote that works with 3rd gen legacy/outbacks? Im not worried about genuine oem at all, just want to know if its possible
Id like to change how my legacy sits, but im not a big fan of spacers or hub adapters like that because they cause extra stress which id like to avoid. My legacy has very worn out suspension, plus it sits the wheels about 3-4 cm tucked under the fender. I ive read somewhere that the outbacks have a taller suspension and ive seen they have a bit of a fender flare on them which makes me wonder if they also have a wider stance. As a personal preference, i like the wheels to sit even with the edge of the fender, so my thought would be if i were to get a full outback suspension setup and then just lower it to where i like, then i could possibly get the stance i like without undue stress from spacers. Any input is appreciated
Im at work currently so cant do anything at the moment but battety terminals are tight and havent been moved in about 5 months. In my mind, battery or alternator wouldnt cause such an audible click like a really loud relay in my dash when the power fails. Ill be doing diag on it tonight when its cool out but i just want to get as much info as i can before hand
So it first happened yesterday when i got to work. Ill commonly shut the engine off but leave the radio on for a few minutes, but this time i heard a pop in the speakers and all power in the vehicle was gone. Lights, horn, radio, dash, nothing had power. It started working again after a few min of me just visually checking the vattery and all my major engine bay fuses. Tried to drive it to work today and it started fine but i got maybe 20 ft and power started flickering with a click in the dash. Got it back parked and it did the same thing when i shut it off, all power gone. So i had to drive the brat to work (sarcastic 'oh no') but where in the dash can kill all electrical in the car? I can do electrical diag some but bad wires are a pain
168k miles. As for use history of car, no idea. Ive had the car for 2 weeks. Bought it from a girl whos selling point was that its a reliable car which to me means she neglected maintenance thinking it didnt need to be done. Though it is a very clean specimen for 16 years old so im assuming mostly city and higheay use. How hard is inner tie rods? Ive done outer on a few vehicles but never inner
I picked up a 2001 legacy gt limited recently, and of all the little issues it has my steering is the most annoying and worrying. At speed on the freeway theres about a 5-10° deadzone in the steering which makes for a slightly sketchy drive at 90. Also while going over any not smooth surface (cattleguard, dirt road, speedbump etc.) I can hear something shaking in the front end. I jacked it up and did a look and it appears that all my bushings are good. Nothing looked very worn nor could i shake any components with the exception of the tie rods. Could just tie rod ends cause such an issue? Or might it be in the rack itself. I also checked the steering joint under the brake booster and it appears solid enough. I manually tried twisting the shaft in the engine bay while leaning on the wheel and it seemed to act exactly like the steering wheel itself; worryingly large dead zone. Any history of the steering racks having a lot of slop in them? Any input on this would be greatly appreciated
