gciriani
About gciriani
  • Birthday 08/10/1955
Contact Methods
  • Website URL
    http://www.globussht.com
  • Skype
    gciriani
  • Location
    West Hartford, CT
  • Occupation
    distributor sport products
  • Biography
    lived in Europe
  • Vehicles
    Legacy station wagon 2003
gciriani's Achievements
Member
Member (2/11)
0
  1. Here we are talking specifically of a shift that happens at each wheel revolution (1 turn), and I'm struggling to understand why it happened in the first place, and why it went away by itself.
  2. I went through your whole thread; thank you for giving me the link. It's very interesting, as I can recognize some of the symptoms I experienced. It's not clear to me why the tie rods would cause the problem. You and those who contributed to your thread had sort of an explanation of why the bearings would cause the problem. But there was no rationale for the tie rods being implicated. On page 9-10 of your thread you are still discussing the cause, and then all of the sudden you decide it's the tie rods. Could you please paraphrase the thought process?
  3. KaraK, Yes, the clunk is gone. I even took a long 900-mile trip, and didn't notice anything like that. Could you please tell me a little more about your type of noise? Was it exactly at the same speed as the wheels? And what was done to the inner tie rods? Were they tightened?
  4. It was not loose. The mechanic said it was not as tight with all the torque it is supposed to have according to the manual. Now, the same mechanic is the one who replaced the brake rotors and pads on both sides, and the axle on the side opposite from the side I'm having the problem with, 3000 miles ago. I don't know if he by mistake touched the bolt on this side.
  5. I was watching him as he was doing it. It was the center bolt, the one for which one has to use an extractor (at least it was a large cylinder he was using).
  6. Update: the mechanic said that last time I took the car there an he put it up on the hoist, he tightened the bolt on the disc. He hypothesized that this might have eliminated whatever source of play was causing the vibration.
  7. GrossGary, I was thinking this over. How would the behavior you are referring to explain the noise I detailed in this post? Specifically a precise location during the rotation of the wheel at 1 mph the clunk would last about 1/10 second then there would be an interval of 1 second (about the time for a a full 360-degree rotation of the tire, and then again, clunk
  8. Grossgary, Thank you again for the suggestion. I'll bring it to the mechanic, and we'll try it.
  9. MarkJW, Did you experience anything as I described during acceleration? With robust acceleration the clunk went away as well?
  10. There is no more noise now, I'm trying to diagnose what could have caused that for 4-5 days and then all of the sudden went away. But yes, applying brake pressure was making the noise go away, and so was constantly accelerating. The noise was at max while going in neutral, or with a very, very slight gas pressure. So it was torque dependent.
  11. The mechanic, and I was there watching it, couldn't hear any noise turning it by hand. But I suspect that at that point the position of the suspension (hanging) made the difference. My further hunch is that spinning the wheels while hanging changed position of whatever it was, that was causing the noise. I'm still hunting for a rational explanation, and try to confirm it with some test, because something definitely was not right. The fact nothing feels wrong right now, only means that that "thing" may be lurking and wait to happen again. The boot I think it has a cut somewhere.
  12. The mechanic replaced both rotors and pads. I probably didn't explain the axle replacement well. Only the right axle assembly was replaced, and it was done at the same time as both brakes (rotors and pads), probably because the bearing or the joint had started to be noisy (I have forgotten the reason, but I trust the mechanic since I have along term relationship, and he often does stuff at no charge). The noise was periodic, like: clunk, clunk, clunk at the same speed as the wheel. It didn't sound like a caliper sliding on a surface. When it happened I could even hear it in the parking lot going 1 mph, standing outside the car and my wife driving in a circle. At that speed it was like: clunk, ... 1 second, clunk, ... 1 second. That is the clunk would last about 1/10 second, then there would be an interval of 1 second, and then again, clunk. So it was definitely in a particular position and it didn't seem caused by something sliding.
  13. Thanks for the reply. I do not understand though why you are suggesting a tire rotation if the problems resides with the brakes or the wheel bearing. The brakes (rotor and pads) where replaced 2-3000 miles ago as was the right-hand-side axle. The left-hand-side axle is still the old one, as it was judged to be still good.
  14. Hi, I've read some of your replies regarding axle problems and I thought you might have some insight on my problem. I wonder if you can reply to my post. Thank you for your time,
    Giovanni
  15. Hi, I've read some of your replies regarding transmission and axle problems and I was impressed by your knowledge. I wonder if you can reply to my post. Thank you for your time,
    Giovanni
