In the past week a noise on the front left wheel side started becoming every day more prominent. It goes at the same frequency as the wheel is rotating. The vibration can be felt on the steering wheel as well. Any suggetsion as to what it could be?
The mechanic said it could be the axle CV joint, but probably not the ball bearing; it could even be the transmission in his opinion. The first time it was hoisted, moving the axle by hand didn't show any significant play. So we thought the CV was improbable. He injected some grease in the booth of the axle to see if this was going to change anything, but there was no change.
Eventually we decided to try replace the axle, but as he started taking down the wheel and extracting a couple of pins, he became more convinced that the axle was OK, so he recommended that I take the car to the dealer to diagnose if it was indeed the transmission.
When I left the mechanic's garage the noise had disappeared, and never came back by the time I reached the dealer. So I didn't go through any diagnostics as it would be wasted money.
Any suggestion on what this could be, and what to check? The car is a 2003 Legacy SW with 118,000 miles on it, 2.5 L engine.
This actually was the second time the mechanic had put the car on the hoist to check it underneath. He examined treads, brake rotors and axles. What I also asked them to do the second time was to turn on the car while on the hoist, put it in gear and spin all 4 wheels to at least 30 mph. First they spun the incriminated side without the wheel on; then because it was almost not moving (the differential transferring most of the rotation to the other wheel), they mounted the wheel back on and they spun all wheels again. I'm wondering if this has something to do with a problem in the differential that the uneven rotation hid away.
I wanted to add further piece of the story which may or may not be related to what's going on right now. About a month ago a grinding noise started on the other side (front right hand side). It was at the same frequency as the wheel, and I thought there was something caught in the brake rotor, but nothing was showing after taking the wheel down. It appeared at the beginning of a 100-mile trip, and the next day was not there anymore. It had the same period as the clunking noise, but just grinding this first time. I could tell that it was metal on metal, and not with a lot of energy dissipated, but it was definitely there. The next day I went to the mechanic, and we couldn't find anything.
