blurat
Everything posted by blurat
I havent changed the ignitor tho I do have another in my box of stuff. My test light is in the back but when I poke around all the hot spots are hot and it starts again.
Got the van on the road again with the newer motor, harness etc. Drove a few places on Sunday, 50 miles or so. No problem. On the road this morn got 3 miles and dead. Fired righrt back up went 2 blocks and dead again. Key in on position I can hear the fuel pump for 2 seconds. Cranking and no starting with the same little burp when I turn the key to off. Picked up some aligator clips to make the test lights at the relays and various points.
I dont know if this has been asked before but I couldnt see where it was. A 94 position sensor is 250 to 300 bucks. A 95 is 25 dollars. The only difference I see is the 94 has the pigtail attached and the 95 has a socket for a plug. Does anyone know if I can buy the 95 and just solder the wires to it and it will work? Just checking, Thanks
Would I not get a check engine light for either of these conditions? Is there a way to check the o2 sensor? Thanks for reply. Appreciated.
Hi. I put 94 legacy n/a into my Vanagon a couple years ago. My first trip to Washington and then south to San Diego yielded mileage of 18-21 per gallon. I took a trip to Sacramento yesterday and got 12 . The van ran strong and seemed to run as usual. I only noticed the fuel wasn't lasting too long. My wife drives the van mostly around town and is always filling up, I figure because of all the stop and go. My idle only seems a tad slow but it has always been that way. I pulled the plugs and did a comp check, 150-160. The plugs looked a bit lean but not like they get hot. I can run at 70 all the way to Sac but generally keep around 60 - 65. The only oddity I see is my first water reserve goes low and doesn't push water into the overflow tank.
Ive been putting new carpet in. Thanks for the replies. It was actually the knock sensor. Checked it from the ecu like the tps. Funny, the only other wire I lengthened and managed to get a shield wire into it also. The only good thing is it didn't take long to find it. On the other side of the coin, I drove for the first time ion 8 months and the van ran great. No CEL, I drove till the temp guage quit rising, about 1/4 the way up.A few more little odds and ends and back on the road. Thanks all for the help. Chris
Now I cant get the light to turn offr. I disconnected the battery for a couple hours, started the motor and the CEL came on again. Put the green connectors together and turned the key on.......light stays on, doesn't blink a code. When I connect the green test mode and the black read memory mode plugs together and follow the clear memory procedure from the FSM, I get code 22, knock sensor. Do you suppose this is an old code? Either way, I will check it out tomorrow, now that I know how these things work.
No, I tested with the tps unplugged. I put the harness together to fit the vw. Tho its possible that the wire is shorted, I don't think so as I soldered all the connectors and used shrink tube on top of that. I don't get continuity from the red to the body ground when I test at the unplugged b group at the ecu. Thanks
Thanks for the reply, I found some info on a site that cleared up some of my confusion. The throttle sensor tested ok when I was following the ohm readings. When I went to voltage I find I have no power coming up the red wire from B3 at the ecu....No power at pin 3 of the ecu. I checked this by scraping a little insulation off the red wire a few inches from the ecu. I got 0.11 volts. Since there is power in on the B connector I figured I cant test by unplugging the connector and going straight for the pin on the ecu. I checked all the power in to the ecu and all looks good.
HI, just got this beast running after 8 months work. The engine from a 93 Legacy started right up and idles fine. I get the check engine light and it points to the tps. I have checked all continuity to the ecm and all is good. I have checked the sensor and it seems ok. When I start the motor the light comes right on. Takes maybe 2 seconds and that is without touching the throttle. To sum up.....wires to ecm all good to tps. Light comes on immediately after startup without touching throttle...With throttle closed the 1-2 post at the sensor is open like it should be Im lost.
Hi, just got an ej22 from the boneyard. It is a complete engine and I am going to put it in my Vanagon. I see where they steamed it off nicely but when I took all the external tubing, hoses, etc off I see buildup of past leaks. Got the heads off and the cylinders have no ridge and there is no sign of oil passing the rings. My thought is to have the valves done and change all the now exposed o rings. I dont really know how many miles are on the motor but it rolls over and feels tight. I think the biggest job is getting it in the car, hooked up, and running. If I got even 20k miles out of it then that would be a few years for me. Any thoughts on this subject? Thanks
ej22 parts
blurat replied to blurat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I am thinking stock parts but have read that the 25 has coated pistons and solid lifters creating less friction. Is it worth thinking about changing the heads and do have they upgraded the pistons to a coated version? Thanks -
Hi, I tentively bought a 95 ej22 complete with the harness and ecm to put into my Vanagon. I live in Ca so will need to pass smog. I thought I read somewhere that the early 95 motors had obd I system. If not is it a problem to use this 95 motor for my swap? Never mind, I just found a 93 complete.
ej22 parts
Its going into an 87 Vanagon
