Everything posted by Subeast-EA81
you can also check for low spots as follows: Your going to need some "decking paste" or use Ford, Lincoln Mercury disk brake wheel bearing grease (only because its blue and can be seen really well like the decking paste) apply grease or paste liberally to head and or block surfaces, than take a ruler or any other item that you know for sure has a true edge. ( i use a piece of 1x1x6 bar steel that i machined true) then pull the tooled steel across the entire surface while applying minimal pressure. (make sure the tooled steel or ruler spans the entire width of the surface your checking. the residual grease will indicate the low spots if you have them. (learned this from an old Diesel Mechanic) be sure and remove the grease or paste when your done so the head gasket will seal properly, i recommend using brakleen since it doesn't leave any residue. Make sure that the surface is Sterile. hope this helps!
my wife watches to many Ken Block videos to have a WRX! its an 07 basically stock except the stereo system. I figured it was just a fancy deck until after i bought the car, than i looked in the trunk!. So Far the nicest Subaru i have ever owned, and the first Impreza. Although I'm not sure that the tail lights are stock.
EA82T woes, need help
Subeast-EA81 replied to Subeast-EA81's topic in Old Gen.: 80's GL/DL/XT/Loyales...
OK, so i had a guy who works at an import performance shop come have a look because i am completely stumped, it ran for 1 minute and we both deduced that the turbo seals where out,... so i called my friend that owns the car, found out that he used Cheep conventional oil in the car when he did the tune up, he also said that the car ran fine for a day or so then stated acting up. so now i will be in search of a new turbo!! (will post add in wanted forum) -
Re-Blacking Wiper Blade Arms
Subeast-EA81 replied to Subarule's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i used some bumper and trim paint on the ones on my 84 wagon, just scuff it up with some scotch-bite and shoot it! the beauty is than you can shine it up with amor-all on any trim dressing. i did the same on the wheels so when i blacked the tires i would hit the wheels and they would shine like new! -
sorry for the dry spell fellas, we had the sickness blow through the house, so i haven't been able to tinker with it, and on top of that my Explorer took a dump so i had to fix that first! I'll update when i get back out in the next day or two -
yeah he did the cap and rotor, would the rotor sinning out of sync cause it to run inconsistently? just a thought. How do you know the little tid bit of knowledge? -
no clue as of yet on the timing, ill check it wensday when i get back from out of town -
no i haven't checked the gap, it seems to be more serious than that to me, but i could be wrong. -
Ok, checked all the hoses and clamps, their tight. here is the newest data -idle is choppy -with foot on floor it will run up to 1000rpms -pumping the throttle gets you 2000rpms -has typical top end clatter -after holding my foot on the floor at 2000rpms the turbo and down pipe turned cherry red in under a minute -unplug MAF, car dies -unplug TPS, car idles up 200 rpms -after i saw the cherry red turbo i shut the car off and herd bubbling noise from right side head. -comp check 120,120,120,175. -even with bad battery, car starts easy -wires, plugs all correct -vac lines all hooked up -runs the same with down pipe off (not a blocked cat) what should the fuel pressure be? i guess i should run a pressure check, with the hot turbo and what not, it must be running lean right? i got all the tools and the know how, i just need pointed in the right direction, this is my first turbo wagon to work on. plenty of ea81's some 82's under the belt and a EJ25, but no turbo business. -
keep the ideas coming! i haven't checked the timing, he says that he didn't adjust it, everything looks good at first glance other that the ability to just idle. filter is going the right way, checked that! ill have a look when i get home from work. -
i'll have a look tomorrow and re post -
not that im aware of but i can have a look, damaged MAF? ill do a resistance test. -
my buddy wants me to un-doo what he did, 88 turbo wagon. he did a tune up (plugs, wires, fuel filter, oil and filter) he took my advice and used Genuine Subaru parts. Now the car will only idle, and do none else. at WOT it will only rev to 1000rpms slowly, and it idles @ 500. all his work checks out as far as getting the plug wires in the right spot. manual trans. any ideas? I cant find my book.
which pulley? if its an intake pulley, you can remove the intake manifold and use a flexible neck LED inspection light and see the valves quite well, also while doing the belt you can rotate the cams to that all valves are closed and listen with a piece of hose down thw intake port, you will hear air bleed past the valve (this is all done with the timing belt and intake manifold off) i have done this on my 98 OBW, works good.
so, during my recent timing belt/everything but a major over haul! i realized that i failed to purchase a Chilton's book, so some time spent online i found this site called Alldatadiy.com, its the same information that the dealers use, so for 20 bucks a year i have everything i need, including expanded parts views, step by step procedures , and factory part numbers to use at the parts store,I'm not just talking about the big parts, I'm talking every little part! just thought i would pass that info along, and if anyone has a 1998 OBW i can also pass along information from the site if you need,
OK so i got it all tore apart, and this is what i found,..., Timing belt has already been replaced, heads have cometic gaskets installed, newer oil pump with tight screws, however the timing looks like it was off one tooth on the left intake cam, (all marks lined up except that one!) is it possible for the EJ25 to run like this? i have a new belt and will re-time it according to the factory service data I'm just trying to make sure I'm not crazy:banana: nipper: called Subaru in Vancouver, got factory wires, they look so much better then the bendins. hopefully that will help a bit.
yes the plugs are NGK, wires are beldin super conductor, as far as when it comes to doing the timing belt and all that before mentioned service you describe gary, would it be easiest to pull the engine and put it on a stand? i know that on my old 84 waggon it was a prety quick task to have it out if you have a friend to help.
