Josh - Thanks so much for your input. You recommended a coolant temperature sensor for my 95 legacy, which I ordered from the place you suggested. I put it in, and the starting difficulty and smoking are cleared up. I also ordered and replaced the fuel filter and air filter while I was at it. I'm afraid I'm back to my original problem though. This morning when I first took the car out, shifting from 4th to 5th, it started chugging and the check engine light began blinking. I pulled off the road and let it idle. After about 20 seconds the engine seemed to even out and the engine light stopped blinking, just stayed on steady. I started out again and everything seemed fine. It ran well the rest of the day. I've still noticed a bit of a gasoline smell when I start the car. One other thing, while I was searching for the coolant temperature sensor I unplugged what I believe my Haynes manual called a camshaft sensor. It seemed to have a clear-looking liquid settled in the bottom portion of the connector. I know next to nothing about cars but it seemed odd that an electrical connector would have any liquid in it. I'd appreciate any advice you or others can give me.
ORIGINAL POST:
I have a 1995 legacy wagon that I bought about two years ago. It now has 174,000 miles. It started chugging a bit going up a hill one day; check engine light came on then went out. I took it to a repair shop and they put in a fuel filter. Next time I took it to a foreign car repair shop and they put in a knock sensor. It started happening more when going up hills, pulling out into traffic, and the idle seemed to go wild after starting on occasion. Took it to AutoZone - check engine light read misfire. A Subaru owner recommended using a gas additive to remove any water and a basic tuneup, plugs and wires, etc., which I did. Next, I took it to a new repair shop close to my home - they kept it for three days but couldn't find a problem. They said engine was in great shape. I decided I'd just drive the poor thing until it really got bad before taking it back. Well, the time has come. First thing in the morning it doesn't want to start at all. It keeps trying to turn over, like a dead battery acts. If I give it a bunch of gas it'll finally chug over and spit out a cloud of whitish, gassy-smelling smoke. It chugs a bit and idles a bit high the first few stops I make. After that it runs great. If I go to start it up again right after turning if off, it turns right over, no need to punch the gas, no smoke. I was hoping to get some ideas of things I could test or replace myself before putting it back in the shop. Thanks for any help you can give me.
