Everything posted by baccaruda
convert wagon to a brat but with 4 doors
baccaruda replied to 78TurboBrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
there's a brand new brat slider on ebay for cheap right now, FYI. -
Weber question: DGEV vs. DGAV
baccaruda replied to lepetitprince's topic in Old Gen.: 80's GL/DL/XT/Loyales...
don't mind if i do! *post* -
Spokane/Fairchild AFB
baccaruda replied to chef_tim's topic in Meet n' Greet. Your USMB Welcome Center
I'm game. I'll have to see about the schedules for my job and for my mom's wedding though. august is busy so far! -
Project RX: Not Running... What went wrong?
baccaruda replied to Subarutex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
didja check your spark plug/coil wires too? -
hey hey hey http://www.ultimatesubaru.org/80s/specs/ecucodes.html -
there's some model of weber that has the choke on the other side, perfect for subarus. don't know the designation. -
15w50 Mobil 1 synthetic.....in what??
baccaruda replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
so should I perhaps try this in my wagon's RX trans if all the gears are generally sticky and the reverse grinds? -
do they make vent visors for brats?????
baccaruda replied to beachbum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
no problem! I like their looks too, BTW, but some things are not meant to be... -
i think those work best on cars with framed windows, otherwise they sit too high so they can clear the glass when the door opens/closes.. otherwise you'd have to roll the windows up and down 2 inches every time... -
check your plugs too, if there was no/low spark, they might be all wet and nasty? what about that uh, thingy that grounds off of the coil, about the size of a half roll of dimes? i've heard it's prone to problems, and while you're at it, remind me what it's called -
AAARGH my skin is pale sickly green from jealousy!!! all these cool one-off custom subarus running around and the general public has no idea, heh heh what about a smaller master cylinder from a different car, or relocating the battery to the back for weight?
you could snag a 17mm front sway bar from a loyale sedan and a 20mm rear sway bar from an XT, that might help push it in the corners too.
Updated oddcomp's MS n' EDIS fuel/DIS
baccaruda replied to a topic in Old Gen.: 80's GL/DL/XT/Loyales...
that is extremely slick. i'm curious about having the trigger wheel mounted/welded to the front of the crank pulley to solve the clearance and water pump problem? Also, if anyone's interested (heh heh) there's a JY in spokane called Bill's Fords Only Auto Dismantling. Who knows what he might have sitting on a shelf so you don't have to go dirty your tools in the domestic side of the JY I'm sitting in the middle of a disorganized mess with no phone book in sight or I'd list the #, but it's somewhere on the interweb, i'm sure. good luck and again, this is extremely cool stuff you guys are doing! -
I Have Done The Impossible
baccaruda replied to freeldr's topic in Old Gen.: 80's GL/DL/XT/Loyales...
RESISTANCE IS FUTILE; YOU WILL BE ASSIMILATED! -
WOO!! Updated pics of lowered Brat!!
baccaruda replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
heh. no, i just follow offroad rigs on the highway so their extra mud blows onto my car and makes me LOOK hardcore. -
when i turn my car off it shutters
baccaruda replied to sethpistol1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what part of spokane are you in? i'm living up on the north side (pacific park) starting next week. -
Coolant temperature sender
baccaruda replied to higgnoid's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had to dissect the CTS harness on my turbowagon (CTS itself was fine) as the wires had separated from the clips inside the plug. soldered on a couple inches of new wire and soldered those to the stock clips, reassembled the plug, and GTG. might check that, good luck. -
Idea for a Subie Support Network
baccaruda replied to [HTi]Johnson's topic in Old Gen.: 80's GL/DL/XT/Loyales...
"so!" -
vacuume "Vs" center diff
baccaruda replied to suberdave's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hmm. some center differentials use a switch-operated vacuum mechanism to lock or unlock. -
that looks pretty cool. -
Call Whitey's Wrecking in Spokane. (509) 489-3850 They have a brat in their yard though it's been a while since i've seen it. I don't know what their policy is on chopping out sections like that, but I'd hope for you that your fix will look as good as possible, and original Brat metal is probably the best way to go. You might ask Jerry (bratsrus) about the welding for it; he lives in Yakima and is a whiz. good luck!
