Everything posted by baccaruda
Adapter Plate Q's
I used two opposing bolts on mine; I helicoiled them as well.
What is the direction of flow at heater core?
also, I would advise that if you flush your heater core, that you completely disconnect it from your engine and water pump because you don't want whatever's flushed to go into your engine
honeycomb with 3rd eye?
how'd the installation go? your grille adjusting will be a little different than Ken's as you have the big chrome badge on the front of your eye instead of the black cover..
broke the solenoid, DOH!
excellent... I nominate for the USRM
Stupid Question
finding parts would probably be harder than working on it.. and probably not too hard with the resources found here.
Question about calipers
no, they don't fit on the knuckles/spindles.
Ghetto Rigged Oil Squirters/Jets
interesting. as long as it's not so small that it just foams out, and as long as you reseal/replace your oil pump first, it might work. How difficult / impractical to install little nozzles for better aim?
high rise console for brat and older subaru on ebay
didn't "clantieri" used to post here?
Brat cosmetics Q's (rear bumper for 83, map pocket)
1) I think they were the black metal rear bumpers only. 2) that might depend on whether the car is a GL or DL.
Lifted GL for Dayly driver
I'm getting very close to having it movable. I have to bleed the brakes, finish the dash swap (not starting it without gauges!) and at least crimp in the EJ harness. I have been itching to show it off for a while! The tire size will cut down on its streetability a little, but I'm not going crazy with them and it'll have the EJ's 135hp and the RX trans so I can kick the gear ratio down a little bit when I need a boost I want it to be not an offroad-capable but a trail-capable car, that is mostly for street use and maybe autocrossing later. I'm willing to compromise on some characteristics to achieve that, and it explains why I'd choose sway bars over suspension articulation. The tires I have on it now are Cooper Discoverer Radial LTs in 215/75 r15... I found them on Craigslist for the right price and may very well choose a different tire and/or size later this year. Plus, I don't want to have to deal with the repair needs of an off-roader - I've never wanted an offroader. I want a traveller. I haven't taken any photos because my garage is too small to get any sort of an angle on it.. plus I've only recently gotten a camera that is worth a darn! I hope to be done with all of the major remaining work sometime in March.
bloody flywheel!!!
Wheeler Industries did mine for $90 about a year ago. Do you have an auto flexplate or an EJ22 flywheel to lend them as a template?
A cool (random) internet picture
I don't think it's a hatch, the rear window and mirrors are wrong, and there's a side marker light on the fender that hatches don't have. Cool pic anyway!
New with a lot of questions!
what are those yellow seats from?
TIRes?
here, look at the sticky posts at the top http://ultimatesubaru.org/forum/forumdisplay.php?f=30 good luck!
Brumby conversion: EJ22, hybrid AWD center lock, SUCCESS!!!
Yes. Nice job! I can't wait to take it for a spin next time I'm in Australia
how to grease and install a speedometer cable (the easy way)
Hi Dave, YMMV is right.. that's exactly what I did and it won't thread. I'm wrapping up loose ends on the car lately and I'll be tackling the speedo again soon.. thanks Andy
My problem is trying to rethread the cable into the transmission itself. The plastic threads will go in halfway and then it'll pop out. I have had no luck with a couple of used cables in good shape.. anyway.. what is recommended as a lubricant for the cable?
Steering rack loose on EA81
did you check the rubber insulator things I described? If they wear, they'll allow quite a bit of wobble.
My lifted 86 GL10 will be a DD. It has a 4" PK lift, XT6 20mm sway bars (maybe run a 19 in the front), XT6 strut rods, 5-lug conversion (XT6), new GR2s all around, WRX springs in the front, EJ22 conversion, digidash>>>analog dash swap, XT6 seats, 15" Legacy alloys w/ 235/75/R15 tires... Not done yet but close... It's intended for traveling and mixed use, rather than only mud or only asphalt.
nice. that 5th pic of the trans crossmember is showing that you double-layered the metal for reinforcement, right?
dremel time...
Hm, I do have some minor clearance issues related to the crossmember. I'm going to address them after the car's drivable though, as I've already "adjusted" the Y-pipe a little bit..
Cargo Baskets for the Stock Roof Rack?
An inflator can be gotten fairly inexpensively.. I'd like to upgrade to one that has the jumpstarter built into it.. Daeron, in the EA82s, there is a little brace that is removable from inside the spare tire shelf/well. It is attached by three screws.. one plastic, 2 metal, I believe...
dremel time...
heh.. I've seen plenty of posts that don't specify what crossmember needs messing so I like to spread the truth around and it's funny but my round EJ mounts didn't have nubs. Maybe I'm just speshul.
if you pack an air compressor/inflator, you can deflate the 185 enough to fit in there and just fill it up when needed. (If you're rolling an EA82, you've probably already removed that shelf in the spare tire well, right?)
"Backyard"/substitute tool thread
don't forget to keep zip ties, cheap mini-tape measure, ziploc bags, red cargo flag, and extras like roll pins, axle nut/washers, electrical tape, and maybe a set of lugnuts on ya! If you want to pack duct tape but don't want the space taken up, grab a clean bolt or something long enough and wind several feet around it.
