Everything posted by baccaruda
digital dash conversion loyale
The digital dashes look cool... But they're hard to read in the sun, their gauges are less accurate, the digital elements in them can burn out so part of the gauge doesn't work, and it's really complicated to swap dashes.. you have to change the sensors that feed the gauges, and the wiring is sort of complicated to work out. Some people have swapped their digital dashes out for analog dashes but nobody swaps analog for digital. If you want to get a feel for what you're looking into, run a search for DASH SWAP in Older Generation and Retrofitting.
How many Soobs have you owned twice or more?
x1000
The Beast: Straight Axle swap Begins!
Probably one of Brian's.
2001 OBW codes P0446 and P1400
baccaruda replied to baccaruda's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks! I did load up the acutal sensor-to-harness connectors with dielectric grease, and they were in clean condition besides. I'll chase down the other connectors and maybe the ground points for it.
baccaruda replied to baccaruda's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK... I replaced the drain valve and the fuel tank pressure control solenoid (both used parts from a non-coding car) and it fixed these codes.... but now they're back! This car lives at my dad's place and spends most of its time sitting, if that's at all relevant. Has half a tank of gas. I'm hoping that there's something ELSE in common concurrence with these two codes that doesn't involve changing all of the rubber lines under the car... anyone know? thanks, Andy
EA81 - I want to add Power Steering to my BRAT
Hi, welcome to USMB! The power steering swap has been done many times and is simple. Let me show you a couple of things about the board - first, at the bottom of any topic's page, you can see related posts - they may be for-sale posts but check them out in case they have a list or a link to one. Second, give our search a try. It doesn't like words of 3 characters or less so try "power steering swap EA81" but not "add power steering to EA81." Good luck!
Any of you lifted guys going to...
There's an outside chance I might ride over there.
WTF SPFI swap ran yesterday now no start
Hope you have a fire extinguisher.
im clutching confused
Take the dead clutch disk to the parts store with you.
- 4.11 into 3.90
Its a shame.... what do I do...
You bought a car sight unseen and didn't have an impartial third party check it out. You also posted: If he can't or won't chip in for the repairs then it's probably best to consider your lesson learned and quit tarnishing his name here. How do we know your mechanic knows what he's talking about, for instance? Don't get me wrong, I'm sorry the car isn't running and I hope you can get it back together soon, but you supposedly don't think you got ripped off, according to your post I quoted, so unless you have cause to drag someone's name through the mud, you probably shouldn't.
Best bang for buck Subaru...
EA81Ts can be problematic when you're trying to find parts. I love the way they run smooth, though
Shoulda
Only front wheel drive models...
Shoulda
Good call passing on that POS. Post in Wanted and consider coming up to the PNW to buy something.
Northwest folks.
SpoVegas here
ok, here we go again: part deux
hahahahaha
WCCS 12 Site and Location are Set
That's because WCSS12 stuff hasn't happened yet to post on the website.
need thread for gen I brat lift 6" HELP!!!
Whoa. Hurry up with those pics, Rob!
smells like wires burning, but it's something else...
If this is the Griz, check it all over for leaks, and look for anything fresh on the exhaust. Definitely check the brakes too.. you've done a lot of work to it in a short amount of time; this means you have more to double-check. Oh, and make sure the tires aren't rubbing anywhere such as the undersides of the spring perches.
Chinese Pug Replicas
Importing those would probably cost more than machine work to drill rims or hubs, and the safety issue IS a bit of a wild card. China does make their own cars and such though. I'd try to get them spec'd out if you get some, to make sure they're safe... it's your money
barn find EG33 RX BUILD
Nice find! Funny that those sedan spoilers are harder to find than LSDs
EA-81 Pressure Plate Placement?
Most here will probably tell you it's not a big deal. If there aren't any factory markings on the flywheel and pressure plate that correspond to each other, then try to match up the patterns of dirt, surface rust, etc. that may be present. Also, download a copy of How To Keep Your Subaru Alive here: http://www.worldwidecm.com/HTKYSA.pdf and peruse the clutch section. Good luck!
The Boomerang (Mountain Grizzly) Returns....
haha. Quit selling the Griz! It was meant to be yours
Rx Head gasket
I'm suspicious of the quality based on the lack of a brand name and how cheap that gasket set is.
How Hard Is It to Replace a Headliner? (86 GL wagon)
Depending on how picky you are, there should be lots of options for gray headliners. They will come in either vinyl or cloth, and in a few different shades. If you hit a big enough junkyard, you should be able to find a good one in some shade of gray... removing it from the wagon will teach you how to remove yours; re-installation should be obvious after that... good luck!
