Everything posted by baccaruda
OK, the wiring harness connectors looked clean and are now full of fresh dielectric silicone grease. I pulled the panel off of the cargo area interior and the grounding point was clean and tight. I just read Mikevan's Thread of Agony and I have to admit that I can't find my good multimeter and I'm not very experienced with them to boot. I was hoping that my digital copy of the 2000 FSM would have a vacuum line diagram but alas, it does not. I'm wondering if the Drain Valve and Fuel Tank Pressure Control Solenoid share a particular vacuum line or something that might be cracked. I also might "borrow" an ECU from the wrecking yard and throw it in this weekend...
digital dash conversion loyale
baccaruda replied to Subruise's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The digital dashes look cool... But they're hard to read in the sun, their gauges are less accurate, the digital elements in them can burn out so part of the gauge doesn't work, and it's really complicated to swap dashes.. you have to change the sensors that feed the gauges, and the wiring is sort of complicated to work out. Some people have swapped their digital dashes out for analog dashes but nobody swaps analog for digital. If you want to get a feel for what you're looking into, run a search for DASH SWAP in Older Generation and Retrofitting. -
How many Soobs have you owned twice or more?
baccaruda replied to ezapar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
x1000 -
Probably one of Brian's.
OK... I replaced the drain valve and the fuel tank pressure control solenoid (both used parts from a non-coding car) and it fixed these codes.... but now they're back! This car lives at my dad's place and spends most of its time sitting, if that's at all relevant. Has half a tank of gas. I'm hoping that there's something ELSE in common concurrence with these two codes that doesn't involve changing all of the rubber lines under the car... anyone know? thanks, Andy
EA81 - I want to add Power Steering to my BRAT
baccaruda replied to dec0y13's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hi, welcome to USMB! The power steering swap has been done many times and is simple. Let me show you a couple of things about the board - first, at the bottom of any topic's page, you can see related posts - they may be for-sale posts but check them out in case they have a list or a link to one. Second, give our search a try. It doesn't like words of 3 characters or less so try "power steering swap EA81" but not "add power steering to EA81." Good luck! -
There's an outside chance I might ride over there.
Hope you have a fire extinguisher.
Take the dead clutch disk to the parts store with you.
Its a shame.... what do I do...
baccaruda replied to biffanyus's topic in Historic Subaru Forum: 50's thru 70's
You bought a car sight unseen and didn't have an impartial third party check it out. You also posted: If he can't or won't chip in for the repairs then it's probably best to consider your lesson learned and quit tarnishing his name here. How do we know your mechanic knows what he's talking about, for instance? Don't get me wrong, I'm sorry the car isn't running and I hope you can get it back together soon, but you supposedly don't think you got ripped off, according to your post I quoted, so unless you have cause to drag someone's name through the mud, you probably shouldn't. -
Best bang for buck Subaru...
baccaruda replied to idahohay's topic in Old Gen.: 80's GL/DL/XT/Loyales...
EA81Ts can be problematic when you're trying to find parts. I love the way they run smooth, though -
Only front wheel drive models...
Good call passing on that POS. Post in Wanted and consider coming up to the PNW to buy something.
SpoVegas here
hahahahaha
WCCS 12 Site and Location are Set
baccaruda replied to WCSS's topic in Meet n' Greet. Your USMB Welcome Center
That's because WCSS12 stuff hasn't happened yet to post on the website. -
need thread for gen I brat lift 6" HELP!!!
baccaruda replied to Idaho_Dirtball's topic in Subaru Retrofitting
Whoa. Hurry up with those pics, Rob! -
If this is the Griz, check it all over for leaks, and look for anything fresh on the exhaust. Definitely check the brakes too.. you've done a lot of work to it in a short amount of time; this means you have more to double-check. Oh, and make sure the tires aren't rubbing anywhere such as the undersides of the spring perches.
Importing those would probably cost more than machine work to drill rims or hubs, and the safety issue IS a bit of a wild card. China does make their own cars and such though. I'd try to get them spec'd out if you get some, to make sure they're safe... it's your money
barn find EG33 RX BUILD
baccaruda replied to subaruguru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nice find! Funny that those sedan spoilers are harder to find than LSDs -
EA-81 Pressure Plate Placement?
baccaruda replied to nitsuj80's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Most here will probably tell you it's not a big deal. If there aren't any factory markings on the flywheel and pressure plate that correspond to each other, then try to match up the patterns of dirt, surface rust, etc. that may be present. Also, download a copy of How To Keep Your Subaru Alive here: http://www.worldwidecm.com/HTKYSA.pdf and peruse the clutch section. Good luck! -
The Boomerang (Mountain Grizzly) Returns....
baccaruda replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
haha. Quit selling the Griz! It was meant to be yours -
I'm suspicious of the quality based on the lack of a brand name and how cheap that gasket set is.
