Everything posted by baccaruda
POLL: "Overhaulin" pick a paint scheme
baccaruda replied to BeefaRu's topic in Old Gen.: 80's GL/DL/XT/Loyales...
do #5 with mountains, nice idea! -
can you post rates? Like cost each per quantity sold?
I've had 2 GL10 wagons and I loved the way they drove. If you really want to see a totally different car, chop out the bottom of the air filter box. Leave enough of a lip on the bottom to hold in the air filter. This bypasses the silencer in the fender, which also greatly restricts flow. It also decreases your gas mileage a little and increases the likelihood of getting pulled over.
EA-82 Brake Caliper Question
baccaruda replied to Bratwerst's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes, loosening the bleeder screws will help. If the piston hasn't been turned in much (ever? in your case) then the resistance probably isn't much to worry about. If the piston is rusty or if the boot around it is torn or cracking, then you might consider replacing the caliper. since brake fluid is also an excellent paint remover, make sure you suck a little out of the MC to accomodate for the fluid that will be displaced into the MC. Use a turkey baster, not a straw, for this -
Blown EA-81 during hovercraft race, need advice!
baccaruda replied to DJ_Kuehn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it won't do a whole lot of good, call it a "technical improvement." You can only mill them so much before it affects the alignments of mounting the intake manifold (bolts andports) so keep that in mind. best of luck! hovercrafts are cool is that a hydraulic lifter motor (better of the two, has stickers on the valve covers) or do you have to adjust the lifters? -
i would recommend the same thing; find another impreza tranny, it's built for the larger engine in your car. You can modify the LSD to match your EJ transmission's gear ratio, there are directions in the USRM. good luck with your friend
ej22 disty and carb pics i found
baccaruda replied to LPGsuperchargedBrumby's topic in Subaru Retrofitting
read up 4 posts... -
GAS LEAKING! (Pics) FAST! PLEASE!
baccaruda replied to NewDriverOlderRide's topic in Old Gen.: 80's GL/DL/XT/Loyales...
that little brass/plastic UFO-thing? if that's what's leaking, it's not the fuel pump - the fuel pump is the size and shape of an 8oz. canned beverage - I don't know what that thing its but you shoud be able to get one from the dealer or from the junkyard. You might also consider putting new fuel line under there while you're at it.. -
my H.T.K.Y.S.A. guide didn't help
baccaruda replied to ClutchCrusher's topic in Old Gen.: 80's GL/DL/XT/Loyales...
they might be the "tamper proof" screws whose heads snap off when tightened to a certain point. You may have to drill them out. -
I've done it with the turbo on and with the right front axle removed and I wouldn't do it that way again.
KYB GR2s are nice, and not too pricey. You can find them on ebay, usually for 2WD cars but those sit lower.
Can anyone tell me what happened?
baccaruda replied to jssubie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
good call. similar to what i suggested; the squeal is highly suspect. The only other squeal I've ever heard from the front was in an electric fan that went bad... now THAT sounds horrible. -
hmm. I'd wonder if one of the timing belt idlers has an intermittent seize, and if during that seize, it caused some leakage from the cam seal? pop the side timing belt covers and see if the belts are friction-glazed and see if there's oil leakage in there. -
1/2" is definitely going to be more common. I will offer again here that I know good shops in Spokane for the necessary flywheel work. I know a place that can mill or drill the extra bolt pattern into the flywheels for $90, and a place to balance them for $30, and shipping is ~$17 round trip with US Postal Flat Rate.. this totals out to $137-$145 w/tax.. I would ask for a few $ as one shop is out of town and requires 2 extra half-hour drives to chase the flywheel out and back before work. If you can't find a place near you to do this at a comparable price I am happy to help.
yeah, the work is appreciated by all, i'm sure, but the photos don't enlarge as they need to.
don't forget, you're nuts! -
OK, now that IS cool. nice find!
I just stumbled over some Isuzu turbodiesel stuff this evening. It looks promising..
too small. Your best bet is some sort of 4cyl truck motor or some sort of VW motor. You will almost certainly have to have a lift kit installed in the car or there will be no hope for the hood clearance. A diesel motor is going to weigh over 400lbs, BTW. I am interested in putting a diesel in my Subaru as well. I know that a 1.9 VW TDI will fit inside the engine bay of an 85+ GL but I don't know about how the crank will center up to the transmission. I am also anticipating that I will need to beef up the crossmember as well as the front springs.
Help: Sticking Emergency Brake-- '88 GL
baccaruda replied to morgantruce's topic in Old Gen.: 80's GL/DL/XT/Loyales...
your best and easiest bet is to change the caliper. Change them both as they've been through identical conditions, and if one is sticking, the other one can't be much better.
