Everything posted by baccaruda
I've got to say that I'm not a big fan of this idea for two major reasons: One: the car's weight is not balanced in a way that it will be stable and safe to pilot as a boat. Amphibious cars are designed to be stable in the water as well as streetable. You'd have to add a lot of weight to the bottom and rear of the car to add stability while floating, and that will create its own problems. Two: I think it is environmentally irresponsible to drive a street car in a body of water. Think of it as using the lake or river as your own private carwash. All that grease and oil on the bottom of your engine and chassis ("all" subarus leak oil, it's no secret) is going to end up in the water, as well as the exhaust pollutants. Our rivers and lakes are having enough problems caused by callous industrial practices, and I'm sure the fish would prefer that you didn't expose them to this crud. I don't know about the geology where you're from, but Spokane sits on top of one of the world's largest freshwater aquifers, and it is where we get our drinking water. Burlington Northern just built a railroad refueling depot right on top of it, and of course the damned thing leaks like a sieve, so now our aquifer has f#$%ing diesel fuel in it. Of course your subaru is not capable of causing problems of that scale, but the point is that petroleum products and public water resources should be kept separate. It only takes a miniscule amount of petroleum contaminants to pollute large quantities of water. I for one would be one of the people sure to scowl at someone driving their car around in the lake. I hope you don't do this.
well, you have the impreza spindle and ball joint and strut. that saves you a lot of piecing together. the XT6 spindle, the Legacy spindle, and the Impreza spindle all use the same ball joint. you can use the XT6 caliper on any of those spindles to retain the front E-brake setup, as the Impreza and Legacy brake systems have the E-brake in the back. Or you can improvise your own setup. as far as what you've got now... if you drill out the brat control arm it will accept the larger ball joint in the impreza knuckle. you can then keep the impreza strut and put the 2-bolt EA81 strut tower mount on top of it. I have been told to match the spindles, rotors, and axles all from the same type of car for proper fit. You will have to use custom axles because the EA81 cars are too narrow. the EA82 cars can use the EJ axles because they are wide enough. in other words, there's not quite as much piecing together as you might think. so, if you want to use STI brakes, you will have to reengineer the E-brake cables' routing, as that will dictate that you run a rear E-brake setup. You will not be able to use STI axles for the reason noted above. If you want to use STI control arms then you are on the right track with what you're doing, I guess.
what are you doing with the lower A-arm? if you want to put the 5-lug suspension on it, you can supposedly just drill out the Brat control arm to accept the larger ball joint... am i missing something?
and i can also change the rear main seal -just in case- and replace the broken shift fork so I can have a hill holder that works again.
good job staying alive! i also vote to keep the carcass. you'll end up money ahead. and you could sue the driver for negligence as well. i almost got my brat taken out at college today; i rounded the corner of a row of cars and the one on the end pulled out and almost into my passenger's door. I didn't notice her signal but I wasn't looking... and neither was the driver of the other car! it happened so fast I didn't even have time to give her my Inscrutable Gaze of Death.
well I took Brian's extra heads to the machine shop (thanks!) and my head gaskets should be in thursday.. I'm replacing the oil pan gasket while I have the engine out. After this weekend I won't have any more oil leaks in my Brat.. how am I supposed to tell where I've been? I will probably helicoil the exhaust studs.. I might also skip on using the spacers if the Y-pipe will clear. fun fun fun.
What could be a better tow vehicle than a brat?
baccaruda replied to 75subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
that's what i get for opening my mouth right after getting up in the morning. aside from your points, ken, look under the trailer in the first pic; there's a blurred section that screams photoshop.. and in the second pic, you can see jackstands or something under the front of it in the shadow. i do like how they revved the truck's engine to produce the exhaust though. -
hm, what makes you think it's fake? i have to say that it would be pretty unsafe for that dodge to haul that monster at anything faster than 5-10mph; it doesn't weigh nearly enough to stop it effectively. same sort of goes for your brat/trailer but i understand that you weren't on the highway or anything -
Don't send a RX bodykit via UPS From VA to WY
baccaruda replied to Nug's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yeah, i sent one fedex to someone (i think it was russ) and it was equally horrific. i guess it's worth knowing ahead of time what you're committing to, if you want to buy one. -
I got a laugh from the dealer parts guy
baccaruda replied to pyromanic's topic in Old Gen.: 80's GL/DL/XT/Loyales...
snap ring pliers: $10 CV boot clamp pliers <$10 for either style; i have both axle grease: $4 ($.75 per boot change) axle boot and clamps from dealer: $15-$20 (spare cage, ball bearings, and axle cup from junkyard: $10 or find a cheaper junkyard) once you start fixing your own axles you will never go back to scrounging the junkyard. why spend twice as much time disassembling plus driving? You can even leave the axle on the car and change boots but it's a great time to inspect your wheel bearings and shoot some extra grease in there if you take the entire axle out. -
went to the junkyard, pulled the crank pulley, A/C belt tensioner, and center timing belt cover off of a motor in an Impreza. Finished up, realized that it was an Impreza, and sure enough, it had an EJ18 instead of the EJ22 I assumed I saw. Please tell me that the parts I bought will work for my EJ22?
i put a remanufactured XT-4 PS rack in my wagon and it bolted right in.
Have you seen this insane gl-wagon video?
baccaruda replied to reddevil's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it's gnarly and sick and all that, but it's also FUNNY. GL wagons are not supposed to tear up the streets like musclecars and it's hilariously absurd to see that. i love it, don't get me wrong. i thought this was going to be another reposting of fossil's jump. -
Not cool....whoever just bought the RX in spokane..
baccaruda replied to pwoens's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i've always been under the impression that verbal agreements are legally binding in washington state, but good luck proving it without a recording -
what year are the harness and computer from? I have an electrical FSM for 1990..
that's great, thanks Josh. I have FSM #6 for the 1990 Legacy so hopefully I'll find a car that likes the diagrams I already have ????..... so if i get a 90-91 MT harness, should I grab the IAC (wiring diagram says "bypass air control") off of the motor to match? or should I grab ALL the sensors and injectors, as they're different? (what's the MT/AT difference anyway?) If it's a 92-94 I will grab the engine sensors regardless. thanks again!
call Emily at http://www.ccrengines.com/ and ask about a 1995 2.2 liter swap. she could also advise you about the suggestion you mentioned.
Looking at 2.2 swap parts on Friday, have some questions
baccaruda replied to AKIRA's topic in Subaru Retrofitting
you also need the gas pedal/throttle cable from the legacy. swap them into your brat (i'm assuming that's the recipient?). the adapter is not hard to make... take the bellhousing off of an EA82 motor while you're at the junkyard. get a piece of plywood that's roughly 13x16". (line up the bottom edges by standing them up on a flat surface and..) whack the back of the bellhousing behind each of the two bottom bolts. your plywood is now marked. drill out the holes and slide the plywood over the studs. if the alignment pins are in the engine bellhousing (do yourself a favor and make sure they are) you can use the sledgehammer trick to tap their indents into the wood and drill their holes. keep the pins for your donor transmission. trace the inside of the engine bellhousing (it's the same shape as the inside of the trans bellhousing). When you get your EJ22, place the plywood over its bottom bolts. (make sure your previous outline is faced to the engine..) it is hard to trace around the engine in some spots. here's my trick. get the sledgehammer again and tap on the board all around the outline of the engine enough to impress the wood. trace it with a pen/etc. worked beautifully. you can mark the top holes by applying some paint around them on the EJ22, and on the EA 5sp when you get it, and facing the template up to the marked holes. it will leave an outline for your holes to be drilled. i cut my template with a scroll saw; i think i have access to a band saw to cut the aluminum when i get it (this week!) notice that in subarino's pictures, he seems to have tapped the top holes in the adapter. MTFBWY!
