Everything posted by baccaruda
Anyone have EA81 Lift Install instructions?
baccaruda replied to gadberry's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've never heard of that brand and searching this site shows that you're probably the first one to talk of it. Spread it out and post a picture of what you have and we can probably help you figure it out that way. There have been several different lift kit manufacturers but all lifts are similar in enough ways that it shouldn't be too hard. -
Flat towing a FT4WD with diff lock
baccaruda replied to capn_r's topic in Old Gen.: 80's GL/DL/XT/Loyales...
he probably searched for "tow" and got stuck on the 4-letter minimum. I hate that.. -
overnight battery drain....arrgghhh
baccaruda replied to monstaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think I found the problem right.... here. -
I personally don't feel the adapter plate is a big deal (and it's kind of cool to brag about ) Basically then this will let you make a "phantom" 4.11 FT4WD RX transmission.. because you're stuck with whatever center section matches the pinion shaft you use (because the pinion gear is welded to the shaft). So... why not just import the 3.9 or 4.11 locking-diff center sections instead of the whole thing, and save a boatload on shipping? BTW I searched for threads started by Phizinza (and all of them look useful ) but this is the thread in question where he built his: Brumby conversion: EJ22, hybrid AWD center lock, SUCCESS!!!
Better vote that one up up up!
Awesome, I could totally see her driving that one too aaaand here's where I geek out: That has DL headlights but the dual range and the Fun Tops mean it's a GL. What gives?
I'm "interested" but it's not practical right now for me. Thanks for your efforts here though.
Now there's something you don't see every day.
You're one of us now, lad.
I ditched the hood latch and the stock bumper and the little strip that runs between the headlights/grille and the bumper. I have two stock EA82 electric fans in front, wired "backwards." I welded cylindrical stock from the hardware store to the front of the radiator support, with captive nuts welded on the back of the radiator support; they suspend the fans at uniform levels in front. I would like to box in the sides of the fans and probably weld their shrouds together into a single unit and then explore reintroducing a hood latch; I have hood pins installed now. I don't have pics now and it's dark but I'll try for some soon.
you still haven't installed that trailing arm i sent you? Good luck getting your money. It sounds like the frame is boinked.
As seen at WCSS! Thanks to Tex for manufacturing them for me ORDER HERE! http://worldwidecm.com/stickers.html They're $4-$5 each with $1.00 shipping USA for as many as you buy. All are original size except for the smaller "Brat 4WD" sticker which is about half-size.
what gear ratio(s) are these?
good timing here, B. My OBW does the same thing and I'm planning to chase it this weekend. -
Mmmm.... Another one (or 2, hehe)
baccaruda replied to The Beast I Drive's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'd say you picked the right color for your Nice rig Those wheels are killer too! -
My 87' 4x4 EFI TURBO WAGON
baccaruda replied to 87wagonman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
in before GD... Place a want ad here and haunt eBay; eventually someone will have a nice fresh head or a set of them. You might also consider swapping in a 2.2 EFI (nonturbo) from a Legacy. You will find much info regarding the merits and required parts for such (and the detriments of the older turbo motors) if you search our Retrofitting forum for EJ22 SWAP. Good luck! -
New Thread: EJ wire strip class at WCSS11
baccaruda replied to RAugur33's topic in Meet n' Greet. Your USMB Welcome Center
You didn't miss much; it was mostly people sitting around peeling tape and electrocuting themselves with multimeters. -
I love that shot of my car, Rob, thanks the others aren't bad either
FYI all, I don't always have the same expression on my face; he fired off like 8 shots per second at a bunch of us
This should be interesting.....
My car has the stock front bumper replaced with a tube bumper; it doesn't use the fan too often either.
