Everything posted by baccaruda
Need Opinions--EJ20 vs. EJ25
baccaruda replied to swisscheese's topic in Old Gen.: 80's GL/DL/XT/Loyales...
well, the 2.5 is infamous for head gasket problems due to the open deck design, but a N/A motor has better low end torque for offroad use. the 2.0 is a closed deck design so its head gaskets aren't vulnerable to defective design, but may be to how you drive with a turbo .. and if you truly mean light offroad use, then it won't matter with the turbo. if it were me and the 2.5 did NOT have the HG issue, i'd choose that for offroading, otherwise i'd choose the 2.0 turbo as i don't think it'll affect what you do too much. -
take some pictures if you can find it again! maybe ask the owner if you can photograph the h3ll out of it.. we don't have a lot of good convertible pics.. tell the owner about USMB too.
are there any size differences between EA81 strut rods? will EA82s fit? (doubt it)
axles are specific between turbo cars and non turbo cars. also different are 2WD vs 4WD but they fit, they're just different sizes. manual and auto axles are the same.
EA82 86 OHV Carb -> 88 OHC SPFI
baccaruda replied to singletrack's topic in Old Gen.: 80's GL/DL/XT/Loyales...
well, your carbed block has a lower compression ratio than your SPFI block, for one thing. that will translate to overall less power... -
give this a shot, lots of that going on. good luck. http://www.ultimatesubaru.org/forum/search.php?searchid=15917
just saw a 1970 360 on ebay current bid $1
baccaruda replied to 1979BratOwner's topic in Old Gen.: 80's GL/DL/XT/Loyales...
get the one on ebay for parts, and buy wagonsonly's! -
Five lug conversion question
baccaruda replied to SubaruRichie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
those are what we tell people to look for! -
right
http://www.ultimatesubaru.org/80s/specs/ecucodes.html
i love that video. the sound that car makes while it's flying thru the air...
EA82 Power Steering rack into EA81....
baccaruda replied to GeneralDisorder's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i think i'm going to go to napa and/or spaldings and look at a couple side by side. -
how much do you charge to build hatchbrats?
GD, do you have any update on this swap? -
Wiring Fogs to brights
baccaruda replied to subestyle18's topic in Old Gen.: 80's GL/DL/XT/Loyales...
haven't seen your car (or its owner!) in a while, skip. what's up? car looks sharp. -
drivers side lower control arm swap
baccaruda replied to dustyrider's topic in Old Gen.: 80's GL/DL/XT/Loyales...
no, the ball joint holes are smaller on your stock control arm, and they're aligned a little differently. why does your hatch need its control arm switched? -
So... I replaced the alternator... now
baccaruda replied to Seahag1978's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check for clean and intact connections at the battery. you might also need a jumpstart (or a new battery). -
swap EA82 rear crossmember into brat?
baccaruda replied to baccaruda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
are there some EA81 models that didn't come with torsion bars at all? it would be far easier to swap EA81 xmembers with each other instead of wrangling an EA82 xmember in there... -
Hey Zapar - whatchu talkin 'bout?
baccaruda replied to P K's topic in Old Gen.: 80's GL/DL/XT/Loyales...
YEAHHHH! -
I'll send him a PM and report back here then *salute* -
baccaruda posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've been thinking about putting EA82 rear control arms in the brat, so i can have a sway bar. I've also been interested in rear coilovers but I understand that (especially in a brat) they can be a bit much when coupled with the torsion bars. To deal with the rear coilovers, I'm interested in: removing the torsion bars - are they necessary if coilovers are installed? -OR- swapping in an EA82 rear crossmember - I'm sure it would have to be narrowed; would it then be a matter of putting EA81 brackets on it? -
dibs on the champagne! *pop*
so... if you need $6k to build your GL10's engine, and you don't like the RS that you could sell for $8k, then the solution sort of presents itself, don't you think?
that's only for the front wheel drive + dual range trannys. the RX has no FWD and is a rally trans all the way. it likes abuse!
oh yeah. i like to treat it as a six speed. start in low, go 1-2-3-4-5 and then go 5-high.
