vintagejoe
vintagejoe's Achievements
Member (2/11)
10
Driver's window falters in the raising mode (only). This happens intermittantly. How easy is it to remove and replace the switch? Or can it just be cleaned? A friend examined the problem - he's sure it's the switch and not the channel for the glass. If replacement is called for, must I do the whole unit - or just the one for the driver's window.
This car has 165K Has begun making groaning sounds from back when I start off at low speeds-- not brake related. Local mechanic said that the rear strut (s?) are defunct. Here's my question: What's the bad news if I try to nurse another 15K out of the car. Is there a danger point? Beyond that it runs fine-- mostly.
'98 Legacy sedan 146K The driver's side rear brake started, all of a sudden, making a grinding noise as I would brake to a stop. I pulled the wheel off and discovered that the rusty, upper edge of the backing plate had broken off and a piece of it was hanging across the disc. So I removed the offending piece and the I also removed the rest of backing plate that was the furthest gone. Now I don't hear the sound and the brakes are working fine. As this is a car to "drive into the ground" please write back and tell me: --Is this a safety issue? --Is the backing plate crucial? --If it is important, can I go w/o it for a while? ****Please write back ASAP as I urgently need the car this week. Many thanks
Thank you so much. I'll print out the message and bring it to my local mechanic. He is the best in our town. Your help has certainly saved me the dreadful trip to the subaru dealer. How's this for a dreadful scenario: if my wife goes to the subaru dealer with this problem--- we're looking at about an $1100 bill.
When car has been driven for at least 30 to 40 minutes, when I slow down--I hear a rather loud metalic noise when coasting---(doesn't happen under braking) from rear wheel area. I had front caliper replaced recently, and mechanic checked rear brakes and gave okay. One other thing, I brought it by him, all warmed up, recently and he measured temperature at wheel opening---120 degrees from both front wheels and 230 degrees from both rears??? Any ideas???
Many thanks for replies No, car never stalls. The check engine light has been on chronically I've had my local mechanic check code 2X also the Subaru dealer has checked code-BUT, it's always been related to "Evap" code and I've paid them , gone on my way, CEL has always come back w/ in a few days. AND YES, I always tighten the gas cap fully. I don't know what to do next, as when I bring it in to the shop, the problem is dormant. So, I'll have the code checked one more time--then, if necessary, I'll go to the dealer.
This is a legacy sedan 2.2 w/ 125K. I'll be driving along and, all of a sudden, the car starts to run very roughly--engine noise level increases, car shudders -I feel vibration through the steering column ,car shakes and then loses power. Usually, I slow down, and have the patience to "drive through' the problem. It usually gets better after 5 minutes or so. This has been going on for 4-5 months. I brought it to the Subaru Dealer---they couldn't replicate it. So far I've replaced the plugs, ignition wires, fuel filter. At times the problem disappears for weeks and then reappears. One local mechanic suggested (back in May) that I possibly got a bad batch of gasoline. My theory has been that when it happens, if I put in a can of fuel injector cleaner, it seems to help. Now I'm not sure. Is there possibly gunk in the tank that dislodges once in a while. Any advice will be appreciated. I'd like to fix this before I have to return to the Sub dealer. I know that'll cost big bucks. HELP!
This CEL and same code has been re-apearing for 3-4 months. I've had it looked at 4 times. A few days after it's been reset, it's back! Periodically, my car has run roughly----but the light appears even when it's running okay. 1. What should I do? 2. Is there a way to test the gas cap before I buy a new one? 3. Has anyone else had this problem?
My Legacy sedan has had the "Check Engine" light off on for the past few months. Each time I took it to local mechanic, he said the code was for the "Evap System" he fixed it but the light came back w/in a day or 2. Most recent glitch was when I was on the highway and it really began to misfire----------------the problem went away and then it came back w/ a vengance----------to the extent that I was feeling vibration in front wheels (I feared I had flat tire. It cooled off for 30 minutes and I cautiously drove home on back roads. I have: got new plugs New ignition wires New fuel filter New air filter ***Finally, this is probably unrelated, but I decided to throw it in. There is a high pitched squeal from front end when I am in reverse. This also happened in drive but local mechanic found small stones in disc area and the "going forward" sound did get eliminated. PS It looks like I'm headed to the Subaru dealer---good bye vacation fund money!! Thank you car has 125K
My Legacy has given me some rough starting during the many days of rainy weather here in the NE. So, I went to the local foreigh parts store and got a new set of plug wires.However, all four new wires are similar to extent that the fittings that go onto the coil(?) at a right angle. The original wires have a "straight" fitting on the left and only the right angle fittings on the right. Should I return them? Should I go to the accursed dealer for these wires.? I fear they'd be too close to the manifold---for some reason Subaru puts a small set of clamps on the right and not on left??
