joenovosel
Everything posted by joenovosel
  1. I've got an 84 gl wagon. Just trying to upgrade these old seats. What years/makes/model seats will fit in here?
  2. Never mind. I opened my eyes and found it. Problem was my new one didn't have the bracket attachment tobhook ot on so its just sitting there
  3. Ice looked everywhere. Where is the flasher for the turn signals located. I've taken off the fusebox. Looked everywhere. Help please
  4. First off wondering if there is much in the way of aftermarket air filters for these cars to help it breathe easier? Has anyone used cherry bomb mufflers on them? How well do they work/sound? Will seafoam or anything help cleanup the carb and up the mileage better? And last...2inch lift kits. Does it mess up the front end alignment much? My car is used to drive about 70-100 miles a day but I want to lift this beast. Not if it will tear up tires though. Thanks for the help.
  5. im lokking to get different rims so i can find beter tires. What size rims fit the gl wagons? And is there any cars that rims fit say in 14-15 inch rim sizes? The 13 inchers are too tiny.
  6. Would the fusible link not being there mess with it starting now? It has a wire there now. It started at first then died. Now won't start.
  7. I haven't had a chance to try that yet. I will try starting fluid. The fuses are all good Yes it was the red one in the center..
  8. I haven't had a chance to try that yet. I will try starting fluid. The fuses are all good
  9. I have to have one ordered. I checked it seems I've got juice to the coil and coil wire at the cap. It still doesn't fire. It will crank but not turn over. Possible fuel pump?
  10. Ok it is a fusible link blown. I thought those were just pieces if wire haha. I put a piece of wire on it and it fired up then died and now will crank but not fire. Does it have to be a fusible link to run?
  11. No power at all. It acts like there is no battery in it.
  12. Also the rectangle box behind the battery was acting weird I bumped it and it made a click then I had power. The lights came on. I held it down just a little and it clicked then there was power. Now there is nothing no matter if I move the box or not.
  13. My Subaru died on me. I replaced the battery accidently letting the cables touch and spark on the wrong terminals. Since this I have no power. No fuses blown. Lights don't come on. When I turn the key I get nothing at all. Cables are tight and correct.
