20
Everything posted by wtdash
FWIW: I replaced the BPT - back pressure transducer - that sits on top of the EGR valve and has 4 vacuum lines connected to fix my p0400. These are readily avl. on most EGR subarus from the '90s and Toyotas - I used a (used) Toyota version on my '96 Legacy w/the 2.2.
- 1 reply
- 1
I'd be reading up on this generation. Any turbo'd Subaru is a gamble, IMHO. These had suspension, headlight bulb, along w/the turbo engine issues - Ringlands, VF40 turbo failures, etc. If you like to work on your cars - and can get parts in AK - they are a fun car...but maintenance intensive. They also had an HVAC/ICE/stereo integrated system so no easy HU upgrades.
Hi, There should be many posts on here about the Duty C - used to be a daily/weekly topic on this forum as some of the mid-90's suffered a failure/issues. start here: It's located in the tailshaft (?) end of the transmission but can be replaced w/out dropping the trans, but is a project. Don't know your budget for the driveshaft, but I'd be OK buying used as I haven't read about this being a common failure. Should be the same part from '95/96-'99 for the Legacy - all Automatic (not manual) models.
This shows '99 only but AT and MT use the same: https://parts.subaru.com/p/Subaru__/Engine-Control-Module-ECM-Engine-Crankshaft-Position-Sensor-Bracket/49232072/22611AE510.html I'm not sure about the '99 being MAF or MAP based? If it has the MAF by the airbox then it's likley a one year only ECU, since I believe the '00-'01 EJ22 were MAP. Here's one on Ebay: 22611ae510
Please review the posts that you stated you read, " I read several times you can plumb the EGR tube into the IAC hose". It's basically: Run the EGR hard line/pipe into the IAC's hose or the Intake. And plug the HEAD's EGR port. Edit: Bottom end? I'm not sure what that is - except on traditional 4 cylinders the head is above the block /bottom end. On this forum it's usually 'short block' and 'long block'. Long block includes the cylinder heads; the short block does not. If you only replaced the Short block and re-used your heads, then the EGR port is still there as it's in the heads - not the block. But my guess is you meant Long block which includes the heads.
'90 and '91 5-speeds used the metal MAF - like the '91-'94 EJ22T(urbos). '90-'94 Automatics and all '95-'98 (and '99 EJ25D) EJ Subarus used the same green label plastic JECS/AUTECS MAFs - only dif is whether they're Japan or USA-made. So, yeah - limited availability on your year. I'd check w/the used auto parts yards for one, too. And try Car-part.com. Lastly and this may not be a viable option, but do some research on swapping the ECU/ECM to a '92-'94 Legacy as the 5speed and Automatics used the same MAF. Per this pinout diagram the only diff is the 'barometric pressure sensor': https://www.surrealmirage.com/vrg3/ecupins/ But, IIRC, the IAC and injectors were also different on the '90-'91 model. But may still work w/the newer ECU? Just a (bad?) thought. For more old Legacy info check here: https://bbs.legacycentral.org/
How much time/miles on the new struts, etc.? There is a settling period when you replace struts and springs. 2" does sound like a lot, but if your rears are sagging a bit due to age it'll magnify the front 'lift'. Verify the p/n on the strut? I confirmed those are the right KYB's per RA's site. Aftermarket axles are also 'suspect' - but if you bought OEM then I'd consider that a non-issue.
I've not done this on the Phase 2 - '99+ engines - but if you can find a hose that is not directly carrying oil vapor it should work, in theory. If you use the PCV or breather tubes, my guess is you'll get (blue - oil) smoke out the exhaust like I did on my '96 when I did the workaround you're referring to (and I wrote up 🙂 ). But that may not matter for inspection - they don't care if it smokes, as long as there are no codes, correct? Found this other workaround: lmdew Posted October 25, 2016 This is what I did. Ran fine, no codes.
If you're still working on this: That VIN is for '97. Also, if it has the screw-type valve adjusters (vs. HLA) it'll be the interference version. The valves are likely bent - even if there was no noise. I read that you're dependent on your mechanic friend - hopefully they know (or know of someone that does) about Subarus and the engine interchange options. Note: If s/he doesn't know how to put a Timing belt on a Subaru -please get another mechanic friend. The 'good' news is any '95-'98 EJ22/2.2 engine will work ('95 needs a dual-port exhaust header). Put on a new Aisin Timing belt kit and run it for another 100K. Also, that VIN shows it's an OB wagon w/the 5-speed. If you have to 'move on' to another car, your car is popular (and it's rare) w/the Subaru crowd - I don't know FL's Subaru scene - but if it's otherwise in good condition in/outside, it's likely worth as much with running engine as a non-running engine.
Just a heads' up - if you ddin't already know: The '90-'91 harness has round plugs vs. '92-'94 square where they plug in by the battery. Also the cam/crank sensors don't have plugs at the sensor like the '95+ models. IIRC, they're hard wired into the harness. Can you retrofit the newer style? Been wondering that myself.
Any of the '00-'04 seats will bolt up - nothing newer - from a used/salvage/auto parts yard. All OB driver seats were electric/powered. Those w/the cold weather package were heated. - Cars101.com - for reference. The GT and L models will also fit, but may not be powered, nor heated. You could likely - although it may be a lot of work - swap the cloth seat covers to yours -but no experience. Something to note: Your VDC (and LImited) model may have side airbags; non-VDC and/or non-Limited may not. If you swap seats and don't have a plug, you'll likely get an 'airbag' warning light. That may be tough to find - non-leather WITH airbags??? Can't help with part #'s but there are numerous online Subaru parts dealers that might - but also may be discontinued. Also, there was an OB sedan (VDC?). Front seats should swap, too.
