19
Everything posted by wtdash
1. Yes, if you plan to replace the ENTIRE harness, it MIGHT work. 2. You likely will have wiring, sensor and all kinds of other headaches. Have you been doing swaps for years and can do it in your sleep?Although everything should bolt together, the wiring is way different, both ON THE ENGINE, ON THE TRANSMISSION and between the ECU, TCU (trans computer), and DASH harness. 3. Likely won't pass emissions testing. 4. Likely will not run correctly. 5. It's just a bad idea. 6. Main issue is you're 'crossing phases'. '96 is a Phase 1 Subaru electronics; '04 is Phase 2.
HI...again, I didn't notice (or you've updated it in the last year) that you're in the UK.....so not something us Yanks know much about. Google: Transmission TZ102ZA5AA - Subaru Impreza 1997, 1998, Subaru Impreza, Outback Sport (Station Wagon) 1997, 1998, I think this for the 2.2. vs. TZ102ZR5AA SUBARU IMPREZA 2,0 4X4- 1998 Did the UK get the 2.2 AND the 2.0 - NON-turbo engines?
- 13 replies
- Outback
- Transmission
(and 5 more)
Tagged with:
MYSTERY MISFIRE ISSUES ... 2002 Legacy Wagon 5sp MT
wtdash replied to PDX Bryan's topic in NA Fuel Injection Engine Tech
so...What was the 'missing link'? My guess is/was the CatCon.. -
We're responding to this comment....if you put in a VehicleSpeedSensor (the correct one for your car), this wouldn't be an issue.
- 7 replies
- transmission
- speedometer
(and 5 more)
Tagged with:
Look on NASIOC and legacyGT.com for more info. I looked into this same swap on '98 Forester turbo project, but never got it done. 2005 GT 'should' be a 4.11 (OB XT was 4.44) and should match your stock rear diff...( the GT had VLSD). Very good trans from what I remember reading. 4 trans in 6 years???///WTH. These are not weak trans. And you '98 will run in 'limp' mode w/out the VSS hooked up....unless you're running a Megasquirt or similar EM? Not a direct swap, but some info: https://legacygt.com/forums/showthread.php/5mt-replacement-questionsiii-subaru-transmission-gurus-needed-262690.html Here's one I remembered on NASIOC for a '97 GT.....99% same as your '98 (GT has different gear ratios, but same FD ratio) : https://forums.nasioc.com/forums/showthread.php?p=22564870#post22564870
- 7 replies
- transmission
- speedometer
(and 5 more)
Tagged with:
Check the codes, because: power light flash - search on 'handshake' etc. to get the info. Or THIS> If the FWD fuse 'works' and TB goes away, it's just the clutches = Mechanical. If it doesn't - it's @ least the Duty C solenoid = Electrical.
- 1 reply
- 1
Hi, welcome to site. More searching here and online will get you an answer. But the short answer is No. Not 'drop in'. 2006+ had i-AVLS on the heads, so that means a no to. Also the wiring is different. And the intake manifold due to an older style...but technically it'll bolt up. I'd guess the shortblock might work, but I also just read on here that the 2009+ blocks may be different enough to cause issues. Best option is find 2009+ EJ2.5 - watch out for the PZEV versions as they're also different. And it depends on how much of the engine is toast - just the shortblock? Or the heads too. Remember the HG issue..any USED engine is susceptible.
No issues buying on ebait if buying name-brand (AND Seller's feedback). KYB is the best. There are lots of online installs for these. Unless yours are clunking, the tophats (strut mounts) may be fine. Depending on your shopping skills (and patience) I recently bought all new for a different car. All KYB and found better prices shopping around on Amazon and Rockauto (RA). RA 5% code: 8605686777408527 and KYB's have a rebate per their site.
Disclaimer: have not driven any Subaru this new w/the 4EAT or 5EAT. Assuming this is a NON-turbo? Not an XT, correct? I'd start w/the AT service - up to date? You're in the high country so you're down on power anyway you look @ it, but I wouldn't expect 2nd to be 'that' bad. I'm confused as to why it wouldn't shift to 3rd in the mtns...see attached shows that 3rd should be good to 99 MPH (assuming that's Redline). SOHC Boxers have a pretty flat torque band, so it shouldn't have a high RPM 'kick' like a DOHC or turbo. You could try resetting the ECU/TCU by unplugging the Neg battery for 30 minutes (NOTE: you'll lose your radio presets, MIGHT have to re-program your keyless fobs, etc.). This doesn't 'fix' anything but If it runs better/different initially then you may a problem....it'll revert back to the same behavior after a few miles. But these are generally reliable transmissions. Go test drive another Subaru w/the same trans for comparison?
Personally, I"d grab something from a '96-'99 OB/GT/Forester w/the EJ25D and 4EAT. The trans is likely plugnplay (get the TCU) + the rear diff swap is a 4.44 FD ratio which will increase your RPM's and make it quicker off the line. You'll lose the VLSD of the stock rear diff...but it's probably dead on the stock car anyway. Go checkout www.subaru-svx.net/ for specifics. If you want to tackle the 5-speed swap, that would elevate its performance even more.
