19
Everything posted by wtdash
I'd need to see the top of the engine to tell specifically but it's a Phase 1 '90-'98 version, based on the valve (rocker) covers. The '97-'98 version had higher CR and may not like that turbo as much as the '90-'96 versions...assuming it's Stock internals?...but I see aftermarket or just newer-style top-feed fuel injectors, so maybe it's not much stock left.... That appears to be a good sized turbo (for a stock EJ22 anyway)....so another clue it's had some major engine upgrades? Cool rig...have fun.
Hi this LINK may be useful. I'd start w/the O2 sensor. I'd also clean the MAF sensor. ...use the MAF specific cleaner as I've read Brake Cleaner is too strong and the spray velocity can damage it. BTW, your MAF is the same as every other 2.2 (except turbo models) and 2.5 from '92-'98 (and '90-'91 Automatics). Injectors certainly may be getting old, but w/it running OK 'as is' I'm not sure. You can do a quick resistance test to verify they're around 11-12 ohms.
1996 was x-over to rollers w/the HLA's. Only year like that that I know of....and single-port exhaust as you likely know. This post has a pic of one, I believe: http://www.ultimatesubaru.org/forum/topic/127313-spring-washer-rocker-arms/ Hmm, can't post youtube links, but Search 'Subaru HLA oil' to find a DIY.
Tires
wtdash replied to Condor38's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Why do you need an All-Season in Las Vegas? Get a summer-specific tire: https://www.tirerack.com/tires/types/tiretype.jsp -
I wonder if you could buy the immobilizer and related bits from a Salvage/Used Auto Parts yard and swap them. I've read (i think) that the immobilizer somehow even 'communicates' w/the engine to keep it from working unless they all 'match'. But if you could buy the parts, swap it and then have the dealer program it ASSUMING you have a matched immobilizer, ECU and (chipped) key, maybe? Obviously, having all the paperwork verified for the used (NOT STOLEN) parts and checking w/the Dealer first, before 'trying this @ home'.
- 12 replies
- 2011 subaru legacy
- lost keys
(and 1 more)
Tagged with:
You've searched Nasioc? If it's happened it's covered there. Found this RE: torquing that nut. This is on the STi IHI VF39 and not a stock Mitsubishi TD04....different brands may be different specs: Those stock TD04's seem to last <150K miles, so likely the original was just old. I'd call PRE - if still around - and see what they think.
- 60 replies
- Forester XT
- VVT
(and 2 more)
Tagged with:
G'day...my wife is visiting family in Brisbane.....but I'm a Yank (or whatever you call us - thanks to +Rump it's likely not good). Sounds like the soldering has broken traces. Pull it out and if you've got the skills and tools may be able to DIY. I've only been Down Under once and don't recall, but do you have the 'pick and pulls' for used parts like we the USA? Or what about https://www.ebay.com.au/ for used parts?
1> '95 is 4.11 FD ratio, so you'll need the matching rear diff, as the '92 is 3.90. 2> Flexplate = Automatic; Flywheel = Manual 3> I'd get the flexplate from the '95 - just in case....but, Yes, since the '92 TC would match the '92 Flexplate - should be good. 3.5> Ensure you're VERY informed about re-installing the TC...it MUST be seated correctly....that is covered on here. 4> The bolt-pattern on the rear diff's pinion flange (part that connects to the driveline/driveshaft) changed around '95...so you'll need the fun task of swapping the pinion flange (may need a puller?) or possibly you can mix the '92's rear driveline portion to the '95. I'm pretty sure the full drivelines are different lengths and not interchangeable. Must be covered on here...somewhere.
IDO...it looks like the '98 is a 2-piece driveline (unlike the earlier(?)) all-in-ones. So removing the rear section should work? And the front section keeps the fluid 'contained'?
- 18 replies
- Duty C
- clutch pack
(and 1 more)
Tagged with:
sounds good....if you're going to 'be in there anyway' I recommend reading up on the Oil Pump. It's also easy to do, but adds 30+ minutes to the job. - Pull the pump w/the crank seal - Scrape off the old RTV sealant on both faces (pump and block) - Tighten the Phillips head screws on back - likely loose. - Install the the NEW little Oring into the block - RTV as FSM shows - Install pump - DO NOT overtighten those 10mm (socket) bolts...snap easier than your fingers. - Install NEW crank seal Search on beer garage subaru for pics (PG13 site)....he goes into a mild tear down of the pump...I'm not sure that's needed.....others may 'flame' me for that!
High-Mileage w/out service history = Timing belt, pulleys/tensioner, WP and Tstat. - ASAP. As this is an INTERFERENCE engine, you must ensure your Tbelt is up-to-date cuz if it breaks, things from go from $>$$$. Kit is <$150; Labor depends on who does it. I'd say less than $500. These engines are super-easy to do, SOHC. You and a buddy could likely pull it off...Youtube it! Many times the Tbelt is done w/OUT replacing the water pump, but this is why NOT to do that. "...from a Friend" ??? :-( I've sold cars to NON-friends and helped fix repair$ that I missed...."CARMA"
Phase 1 vs. Phase 2 EJ-series 4-cylinder engines Phase 1 and Phase 2 (aka, Phase I and Phase II) refer to the Engines, Transmissions and Electronics used in Subarus. It does NOT refer to body styles or Generations of each model. See Wikipedia for more EJ-series info. https://en.wikipedia.org/wiki/Subaru_EJ_engine Note: This pertains to US Domestic Market (USDM) models only. Japanese Domestic Market (JDM) and other overseas markets had more engine choices, but generally the Phase 2 started the same time. The older JDM models were usually a year ahead of those available in the USA, at least for the Legacy model. Subaru established their USA assembly plant in 1989 in Indiana. Phase 1: All Subaru 1.8 (EJ181), 2.2 (EJ22E, EJ22EZ), 2.2T (EJ22T), and 2.5 (EJ25D) engines from 1989-1998, including the '91-'94 Legacy Turbo and '99 Legacy Outback, SUS and GT* *The 1999 Legacy OB, SUS and GT’s EJ25D used a Phase 2 shortblock BUT with the Phase 1 ’96-’98 2.5 pistons, DOHC heads, Intake Manifold and engine harness. It also had the Phase 2 4EAT Transmission. Note: The 3.3 (EG33) in the SVX is considered a Phase 1, I'd think. Side-note: The SVX's infamous 4EAT transmission can be upgraded w/the '96-'98 4EAT from the OB or GT as they can support the power of the 3.3 (probably), but they have a much shorter (?) 4.44 FD ratio so the rear differential must be swapped too. A 5-speed swap would be better yet! Either transmission will bolt-up the 3.3. Check out www.subaru-svx.net for the details. Phase 2: All Subaru 2.0 (EJ205), 2.2(EJ222, EJ223) and 2.5 (EJ251, EJ253, EJ252) engines (incl. turbo versions – EJ255, EJ257) from 1999-2010 (depends on model when the new FA/FB-series engine were 1st used). More info: - The Phase 1 EJ22E and EJ22EZ had at least 3 variations from ’89-’98. The ’89-’95 (EJ22E) were DUAL-port exhaust vs. SINGLE-port on the ’96-’98. (1996 was still the EJ22E, AFAIK). In ’97-’98 (EJ22EZ) Subaru changed to different piston for higher Compression Ratio and SLA on the valve lifters. Notes about swaps: - The Intake Manifolds (IM) on PHASE 1 2.2 and 2.5 do NOT interchange/swap with each other or Phase 2. - The IM on the PHASE 2 SOHC and DOHC ‘might’ interchange w/some slight modification – I’ve read conflicting reports on this. The ’99-’01 2.2 SOHC and ‘99+ 2.5 SOHC will interchange. Edit from RS25.com post: "All the turbo DOHC manifolds <assuming Phase 2/II> WILL bolt up to the Phase II SOHC heads. You have to use the TGVs, TGV deletes, or a long runner manifold, but they WILL work." - The sensors, IAC, Throttle body, injectors, ECUs, wiring harness plugs, etc are different between Phases, which prevents the easy swaps. The shortblocks (no cylinder heads or IM) can be used across phases in 'most' cases. - The '99 Legacy OB/GT/SUS EJ25D can be swapped for the earlier Phase 1 SOHC EJ22e engines from '95-'98 (and even the '89-'94 2.2, w/more work). Remember there will be EGR issues if you use a NON-EGR equipped 2.2 (usually 5-speeds), but HERE IS A WorkAround. Also, you'll need the single-port exhaust manifold / header for the '96-'98 2.2. The AUTOMATIC 4EAT transmission can NOT be swapped for an earlier year. -The Phase 2 EJ25x NON-turbo engines include the PZEV variants. I've read - no proof - that these are unique and should not be used as a source for a short block in NON-PZEV cars. Info on the Phase 1 EJ22E used from ’89-98: http://sl-i.net/FORUM/archive/index.php/t-16437.html From Wikipedia: Changes in the 2.2-litre Phase 2 engines are as follows (most if not all of these updates were applied to the 2.5 engines as well): • The engine and transmission are fastened with six bolts and two studs. • The thrust bearing has been moved to the number 5 position. • The oil groove in the number 1 and 3 have been changed to supply additional lubrication to the crank journal. • Many changes to the cylinder head and camshafts (specifics on Wikipedia) • Different pistons with a Compression Ratio of 10:1 • Different Camshaft gears / sprockets - Additional Phase 2 transmission info: • Transmissions acquired an external spin-on filter. Designed to last the life of the transmission. • Different internal electronics • 2-4 brake band from Phase 1 was replaced with a 2-4 clutch pack • The valve body went from using five solenoids to seven solenoids • From here: http://www.searchautoparts.com/motorage/powertrain-pro/many-changes-subaru-4eat • Note that starting about 2004 in the Forester XT, the Phase 2, Version 2 came out. Extra info: EJ 2.5 = EJ25D, EJ251, EJ253 NOTE: I can't verify this as it was pulled from online info. 1998 .. DOHC ... same as in the 97-99 Legacy Outback .... MAF 1999 .. SOHC ... with MAF and only year for these engine controls ... unique MAF and O2 sensors 2000/01.. SOHC MAP ... put these alone as they are identical 2002/04 .. SOHC MAP ... moved PCV to rear bell housing .. other minor changes, some with electronic EGR 2005 ... SOHC .... similar to previous, but unique like 1999, first year for NA Drive by wire and unique engine controls again (NO i-AVLS cams) 2006-2008 ... MAF controls ..... Changes also to exhaust, water pump and some timing components, Valve timing added to intake (i-AVLS), oil controlled, different than Turbo 1999-200X ....The Camshaft and Crankshaft sprockets (that the Tbelt runs on ) may need swapped out depending on year AND whether it's Manual or Automatic transmission. Search on here/online. The EJ25x shortblocks from 1999 thru 2005 (excluding EJ25D-see above) were different from the 2006 thru 20010/11. Separated by the i-AVLS heads used on '06+ models.
I know 'not much' about working on the H6, but I do know it won't just 'drop in' to your '99. FYI: There were 2 different versions of the 2.5 in '99. One for the Legacy Outback/GT/SUS model that still used the Phase 1 EJ25D (2.5 DOHC) and the EJ253 in the Forester and Impreza RS (2.5 SOHC). '99 was a transition year, so you'll have to keep that in mind. And that JEBA trans is an oddball as it works w/the '99 OB/GT/SUS (I think) but it's a Phase 2 transmission. So....it 'might' work w/the H6, but I doubt it as those had the VDC and/or VTD versions. I doubt the TCU/TCM would communicate or even plug-in correctly. Search online about phase 1 vs. phase 2...there's info to learn there, too.
Take a real close look @ those wires where they go into the IAC connector- the actual harness wires.....on a 27 year 'young' vehicle they may be frayed, cracked, etc. There's another post on here (or online) showing that issue. This is for a TPS but same idea:
- 11 replies
- 1
- Check Engine Light
- Idle Issue
- (and 3 more)
