19
Everything posted by wtdash
Battle of the 2.2's: 83mm stroker EJ205 vs. built EJ22
wtdash replied to 4URABUS's topic in Turbo Engine Tech ('91 and newer)
Hi, Since $ is not an 'object' and you're much more knowledgeable about engine internals than I, this is probably not your 1st choice, but putting your 205 heads on a '90-'98 Phase 1 EJ22e has been done w/a fair amount of success, too. If you're not allergic to NASIOC there are threads/posts about its good/bad qualities. I'd also suggest replacing the TD04...not for more power but before it decides to contribute extra metal to your engine. There are still a few low mileage ones from an '04-'08 Forester, BAJA, in addition to your WRX, on ebay, NASIOC, etc. GL, TD p.s. and the off-boost torque was even worse w/the 4EAT I had on my '02 WRX EVEN WITH the IPT TC and VB upgrades. :-( -
The stock air intake on a Subaru is a CAI, and most mods just move the power band UP, but doesn't make noticeable power. If he wants some noise, look up doing the 'snorkus delete'. No chips or other easy ECU/ECM upgrades for the '95-'99+ models. And the WRX engine only makes more power due to the turbo which requires a lot of wiring, time and $$ to make it work in a '96. Unless this kid has raced go karts, e.g.every F1 driver, handling and braking upgrades are more important to a new(er) driver than power. Maybe he needs a new hobby that uses up some of that energy..that doesn't involve cars? :-)
+1 And not being condescending, just take it or leave it : Anything above 60 decreases MPG (except a good tail wind or downhill). Math/physics for the day: "drag should be proportional to the square of speed" FuelEconomy.gov states 25 Auto/26 5-speed on the highway, but 27-28 should be doable. Roof-top carrier? They're not so good for MPG either.
Hi, There are a couple other posts on this same topic posted recently (you should all form a group! :-) ), they may have more info. I'd think you'd need the ECU to match the trans - @ least. Also, seems to me I read that some Subies around year 2000 started using trans-specific ABS units which would make this even tougher. Going from 5-speed to Auto is much harder, due to the extra 'stuff', electronics-wise, IMHO. If you and your friend are mech Wiz, then maybe no issue. i'd go search on RS25.com and NASIOC.com as the Impreza bunch like to do this stuff more often, and 99% of the info is transferable - year to year. GL, Td
HI, I don't have any experience w/the 2000+ EGR systems and IAC and converting to NON-EGR. The main idea is to find an intake hose that is NOT a breather hose coming off the heads or PCV hose coming off the block. It'll suck in the oil fumes and you'll be known as the 'blue bomber' in your 'hood.....Yes, matter of fact I DID do that. :-) It does sound like your referring to fuel lines or possibly vacuum lines. I would 'think' you could put a hole in the intake - after the air filter - put in one of those plastic hose barbs w/a rubber grommet sized to fit the hole, and run a line to the EGR hard line that normally goes to the head???? Make sense? Or if there's another port on the intake, just "T" off of it. GL, TD
Hi, I might not be following what you mean by 'gusset', but there are 4 screws that hold on the mirror assembly....one is almost under the door card...easier to probably remove it to gain access, but been awhile since I've done one. Should all be bronze colored Phillips head screws. i can't search images @ work but Google it for pics. LINK1 GL, TD
Hi, Yes...more the better. It doesn't need to be expensive ATF either....the Walmart DEXIII compatible works OK, IMHO. And if you notice an improvement you can go back and do the 'drain/refill/drive/repeat x 3' routine w/better stuff. In addition, ensure you MANUALLY SHIFT thru all the gears when driving it..including Reverse (if not obvious). And it's noted in the Owner's Manual, too, that after an ATF change the trans has to 'recalibrate/relearn/something' for the new fluid, so give it a few drive cycles AFTER you've done the drain/refill/drives to shift normally. And from my personal experience, Do NOT power flush a higher mileage Subaru trans....it may actually cause the trans' internal seals to leak, which will result in a dead trans....Just do the drain/refills. If you do have leaks around the pan, grab a 10mm wrench and LIGHTLY snug up the multiple bolts that hold it on....it helped mine. TD
Hi, Actually, I'd be concerned about the rod bearings. They wear out when OH and if you're 'lucky' you'll get rod knock warning you it's 'End of Life' time, rather than a rod that decides to break free and bust thru the block...real bad. If your options include a used 2.2 vs. 2.5, the 200K isn't as scary, but buying another EJ25D w/those miles is more of a gamble. But in either case, i wouldn't install anything w/out doing new HG's anyway.......cheap(er) insurance. GL, TD
Hi, Yes.....smaller, is probably correct. I know I did the 'ghetto' fix on my '90 Wagon when I installed '97 OB struts. I just enlarged/moved the rear bolt holes to accomodate the OB's bolt pattern....FWIW, I suggest Only messing w/the two outer bolt holes as it's a tight fight up in there and if you move the inner-most bolt hole the strut/spring will likely rub the body.
Hi, That depends on your commitment to the project, space to work on it (and a warm garage, esp. if Eastern WA) and avl. time. :-) There are still a lot '95-'99 Legacys on the road, but they're getting their miles on. So, you could probably pick up one that's worn but not trashed for $1K, and swap your good parts over. Have Fun, Td
1. Is the AT light blinking 16 times @ startup? Yes? There's a code stored in the TCU - trans computer. Search on here. 2. Check your ATF level. The difference between L and F on the dipstick is about 1/2 Qt, so doesn't take much. 3. Is the CEL light on? Check the Codes. Search on here. 4. Trans may be dead....it's acting like the ones I've had/seen that failed. 5. Due the "3 Drain ATF/Refill/Drive thru all gears" cycle. May get lucky. GL, TD
Hi and Welcome, Not the expert, but there's a AT Shift Lock sensor under the dash that that requires the brake pedal to be depressed to shift and is somehow connected to the ignition - it could be broken, but that's (really) rare. Disconnecting the NEGative battery terminal may reset it...but not sure. Also, you could try accessing the shift lock override button under the cover console for the AT shifter - it's shown in the Owner's Manaul, IIRC. It may be 'hung up' causing similar issues. GL, Td
What is this 'fan crack pop' of which you speak? I'm confused too. You're actually pulling the timing covers off, and doing what amounts to a timing belt job each time b4 you start it again? Since the XT is the DOHC engine, it's a PITA to do the t-belt so this must be getting old.... And pull the codes from the ECU....I'd imagine there's 1 or 10 stored. Let us know... Td
HI, I was always under the impression that on Subarus prior to 2004-ish, if the OIL light comes on, it's too late?? It's not there to tell you to add oil, but that it's OUT OF OIL. Overheating = head gaskets. Low oil and knocking = rod bearing failue. These two are usually connected, @ least on the 2.5 engine. That's my 'devil's advocate' opinion. GL, TD
