19
Everything posted by wtdash
HI - and welcome to the USMB, Did you verify the 'original key' wouldn't work either? If it's also dead, I'd just call another dealer (or 3) and verify the facts. I'd also look online/Ebay to see if you can buy the parts there. BTW (and for others' reference), most any Subaru parts department can cut you a key from the VIN, in case your dupe was done elsewhere. That's what I did for my '04 FXT and '02 WRX when I upgraded their separate key + fob = all-in-one keyfob.
HI, MUST be bolted down. Don't go back to that mechanic, IMHO. The orientation probably matters, but I don't know for sure. Should be lots-o-pics online showing it. Also, if the CEL doesn't go off/Code go away, there may be a break in the wiring to the KS>.>>>>common enough. Do a search on KS WIre repair and some (me included) have used MIC (rophone) cable as a suitable replacement. TD
95 non-EGR EJ22 into 95 L w/ EGR question
wtdash replied to wakingtowinter's topic in Subaru Retrofitting
Hi, Suggest sending a PM my way for faster response. Can't see the pic @ work, but if the IAC has a hose that goes to the air intake (and is not a coolant line), that should work. I have no experience w/the EJ18. Edit: I don't see a hose off the IAC, but that 1.8 IAC is very different than the 2.2/2.5's. But all you need is a hose that runs into the intake to the throttle body, so you could 'make one' that plugs into it. Just don't use the PCV or Breather as you'll be blowing blue smoke out the exhaust. GL, TD -
Post on LC site. (8 years ago!)...doesn't 'help' much other than to confirm your experience. I'd go w/the hi-temp gasket maker, or you can take a template to a Auto parts or exhaust shop and see if they have an exhaust gasket that matches? Also, found this possible option but it's for NON-USA turbos: 14415aa010 Side-note: There were VF8, 10, 12, etc used around the world on the old EJ20G engines, which had the 90° inlet. The VF11 was only used on the EJ22T in the US and Canada. The '91-'94 Legacy turbos in the US/Canada were the only ones that didn't have an intercooler, so it had the unique 'clocked' turbo OUTlet direct to the throttle body. The # used for the VF series did NOT note size; it was related to age. The VF8 was OLDER but BIGGER/Flowed more than the VF11. Just like the VF39>43>48>? used on the STi since 2004+.
HI, What year is your "2.2 1st gen" ? Is this the '90-'94 or all the '90-'98 models or? Are you in Europe, per your Sig? If so, may not be the same as US. For US cars, Most 2.2's w/5-speeds from '95-'99 did NOT have EGR; ALL 2.2 Autos and 2.5's did. You'll get a CEL if EGR is missing. To add to Larry's comments above, reseal the rear separator plate and leave the MAIN seal alone if not leaking. TD
HI, Tangent: I suggest spending some time over on the Legacy Central site. Lots and lots (and lots) of info on the '90-'94 Legacy, including the '91-'94 turbo SS and TW models. I've got some good news and some bad news. If the piece that is cracked is the 90° elbow the FEEDS the turbo - between the airbox>>MAF>>silencer box, you can't buy that part anymore. Subaru stopped making it and the dealerships finally sold them all in the last few years. READ it HERE. I can't see pics @ work, so hopefully I'm wrong. People have come up w/workarounds but it's tough due to all the 'things' that multi-ported hose does. The good news is that the oil you're seeing is probably normal on a 20+ year old Legacy turbo. A couple other thoughts: - The turbos are usually pretty stout, if the engine is left stock. They're only pushing <9psi from the factory and seem to be reliable. And buying them used it's not as big a gamble as buying someone's over-boosted TD04 ('02 - '08 WRX, FXT, BAJA turbo).* Rebuilding is probably a waste of $$. - Most of the hoses/pipes/wiring will be brittle on that engine - lots of heat = hard plastic. Expect to get creative as things break and need repaired due to Subaru discontinuing many of the parts. Good/better news is some of the newer WRX stuff will work.* And don't forget to look in the Parts Shed on Legacy Central - post a WTB thread. - Expect the nipples/connections on the turbo's coolant tank - by the brake booster - will break when you look @ them funny...touch w/care. Assuming yours is still the stock plastic/composite tank and not the newer metal or composite tanks from a WRX, et al. - The oil pooling could be from the oil sender/sensor below the power steering pump and/or could be P/S fluid (ATF). Both of those have a leaky history. * The TD04 on the models listed above is a good replacement for the VF11 - IF you can find one that's not worn out....Look on NASIOC.com for those. IT REQUIRES FABRICATION to make it work, but it'll work w/the stock ECU, injectors, boost setting, etc. and provides a slight power boost w/out having to worry about blowing up the engine. Other WRX and newer turbo'd Subarus also have potential upgrade parts that can be used as replacments, plus you can still order them new from Subaru. GL, TD
Hi, Is this a Legacy? There was no Touring Wagon (in the USA) 'til the '92 TW w/the turbo. Search online - probably best on Legacy Central - about cleaning the IAC / ISC - Idle air control / idle speed control - valve. You can also replace just the top portion....read up on that too. GL, Td
- 1 reply
- funny idle
- running rough
(and 1 more)
Tagged with:
2001 legacy
wtdash replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
So, this doesn't create a 'Phase 2 / II ' Frankenstein / Franken Engine w/elevated CR? And since the HG needs to match the bore of the block, I'd look into using an '04-'07 STi HG....from what I've read online. TD -
HI, .02>>>>put the old one back on and/or use its 'setting' to compare to your replacement. Also, put the throttle/Cruise cables so there's no tension as the idle shouldn't be 'faked' w/the cable. The ecu handles it. Look for vacuum lines that are old/cracked/leaking. TD
- 11 replies
- forester
- throttle position sensor
(and 1 more)
Tagged with:
and no offense to the local experts, but there's even more STi-specific info on NASIOC. GL, TD
- 2 replies
- problem
- maintenance
(and 5 more)
Tagged with:
HI, Welcome from US to UK. You're describing symptoms of the classic, infamous, notorious, ubiquitious, well-detailed, Head Gasket failure. Find another garage. Very common the US 2.5 engines, aka EJ25D, EJ251/2/3, etc. I'm guessing yours may have an EJ20/2.0 variant? It COULD be air in the system but whomever did your Tbelt/WP should've 'burped' the cooling system to avoid this. Are Head Gaskets (HG) not a common failure on EDM/European Domestic Market Subarus? BTW, every time that engine overheats, it's 'over-cooking' the rod bearings on the crankshaft, and shortening the engine's life each time. If the HG's do get fixed there's a high likelihood the rod bearings will give out shortly thereafter. May be time to look for a different set of wheels....as in Sell It. Tangent: I understand the Ford Focus RS is avl.......although I also read it's already Sold-out. :-)
Forester brakes
wtdash replied to gator1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Hi, I'm not a mech/tech either, but did your shade-tree mech bleed the brakes? If not, I'd do that, and note the Subaru-approved pattern - RF, LR, LF, RR......It is NOT the standard "Start from the furthest point" . Also, verify your brake lines are still in good shape....I don't know why they wouldn't be, but maybe up north?? Edit: I've got no info on the MC failing....I thought most cars had a 'fail-safe' in case it does..so you can still stop.
