20
Everything posted by wtdash
^+1 Also, If it's moving while in Park I can think of 2 other options: 1. Parking pawl INside the rear of the trans is broken....not an easy fix (for most) and probably more than the car's worth. 2. One of the front CV axles is broken. When it happened on my '96, the car wouldn't go over 35mph, and would roll away w/out the parking brake on. Test it by putting in gear, w/foot on brake and have someone look to see if the axle is spinning on either side of the transmission....as the brakes will keep the tire-side from spinning. GL, TD
Go to opposedforces.com and drill down to your year/model and look under Train>>Differntial (trans) for some info. XS is 4.44 FD ratio and should be the same for '03-'08...but the site shows a different p/n for the '03-'04 model. The XS And use car-parts.com for interchange. The '04-'05 5-speeds used a 4.44 too, IIRC. The OB XT had a 4.44, too...not 100% sure on the years. The XS and XT models have rear axle limited slip differential...not on the X. Td
Hi, I can't help much other than to warn you that if you drive this on the highway, the 4.44 may get old - if it's going to be a DD. I've read- somewhere>Legacy Central?< that the RPM's were near 4K @ 60 MPH - in 5th. Seems too high, but might want to do more research. Also, be aware that Subaru changed the bolt pattern of the rear pinion flange of the rear diff in the mid-90's, which hopefully you're getting one newer, but I don't know if that's the only time it changed. I'd guess (!) the drive shaft will work, as Subaru's 5-speeds and matching rear diffs are the same size - end-to-end. And most of the pre-2006 (?) Subaru turbos had a PULL clutch vs. the PUSH used on NA versions....so you'll need a matching FW, etc. 300HP from 12 psi...seems ambitious....what's your setup? TD
The '02-'05 had the EJ205 - 2.0 liter. It's known to spin bearings, and also the tranny is supposedly weaker...but I'm of the opinion the trans last just fine if you don't drag race/side-step/dump the clutch @ every stoplight. The STi has the more durable 6-speed if needed. '06-'14 (?) had the EJ255 - 2.5 liter. It's the same that was used in the Baja turbo, Forester XT, Outback XT and Legacy GT. ...remember there's a lot of interchangeability between Subaru models. They have ringland issues (usually #4), and misfires due to ......well, lots of causes. Do some research on NASIOC for the WRX, and SubaruForester.org for the XT. Something else to consider - get a ProTune for the ECU. The stock Subaru tune can use some help...and you don't have to do this for more power (although it's a nice side-benefit), just for to keep the engine a little safer. Finding a good tuner is key, so ask around. And just to be extra clear, although I've modified a few Subaru turbos, I'm not a huge fan due to all the issues I've read about - and personally experienced (blown ringlands on a '04 Forester XT and HG issues on a '02 WRX, respectively).....obviously forums favor the 'issues' as people come to them to find answers, which doesn't account for all the happy drivers that didn't have issues....but still.... Td P.s. My uncle has a '69 440 Coronet - owned since new, and a friend is working on a '67 Dart.
Hi, I'm guessing that since you live in/near the Rocky Mtns in CO, Subaru's keep their value. $15K will probably get you into a 2010 or older Subaru Impreza WRX Sedan 4D, Mileage: 65,000, based on a KBB.com Private Party value. Expect to pay $1500+ more from a Dealer. But I'd recommend keeping $2K in reserve for unexpected repairs. My thoughts: The most important thing you want to do is get it thoroughly checked out - expect to spend a few HUNDRED DOLLARS to do this right.....yeah, sounds like a lot, but a blown engine, tranmission, etc. will be THOUSANDS to repair. - I recommend a Compression and Leak Down test to verify the engine and valves are healthy. - Do a hydrocarbon test to (hopefully) see if the head gaskets are leaking. - Over a 100K, the turbo's get tired and aren't cheap to replace -unless you do your own work. - Clutches are another maintenance item. If you're buying from a Private Party - Craigslist - make sure they have PROOF of any repairs done....word of mouth doesn't cut it. Assuming you know buying used from a dealer is no better than a private party -just more $$ (and generally easier paperwork, too...but not worth the extra cost). Get an Autocheck or Carfax to verify the # of owners. Unless it stayed 'in the family', more than 2 owners is getting risky, as one of them could've thought WRX = Rally Car! There are a # of recalls on certain years...if they're NOT done, that indicates a lack of maintenance, IMHO....keep looking. GL, Td
Hi, No offense to Matt, but pretty sure those will rub on the strut perches - right where the bottom of the strut spring is supported. The Xtrek tires are 2+ inches TAller. See attached. You COULD buy the set and either trade or sell>>buy some Shorter 17" tires that would fit....205-50-17? I think the 225 are too w-i-d-e, as well. Here's my new favorite tire size reference: https://tiresize.com/comparison/ Edit: Per cars101.com the '95 Impreza had the following options...from base>>Outback. So yours have been swapped out previously if they're 15", which came stock on the '97+: '92-'95: wheels/tires 175\70SR14 steel wheel 195/60HR14 with steel wheel 195/60HR14 with 5 spoke alloy wheel on sedan, steel on other models, O- alloy wheel 185/70HR14 Raised white letter all season. Steel wheel with hubcap. 5 spoke alloy wheel optional '97+ Wheels/tires 15" steel 195/60R15 87H 15" Alloy 205/60R 15 16" Alloy, Gold colored honeycomb 205 / 55R 16 89H GL, Td
Hi, You need to get your reSearch hat on- - Your leaks probably don't need a rebuild - but rather new (re)seals. Covered on here and other Subie sites. - Fuel smell could be a leaky injector....although they may be new-er, they may not be installed correctly. - Go look on RS25.com for adding a turbo.... FYI - Usually cheaper to find a lower-mileage 2.2 than rebuild it.... Remember to read the Stickies @ the top of most Forums. GL, TD
Plan on replacing the turbo inlet hose w/an aftermarket Silicone model - as I'd be VERY surprised if it's not already cracked....all that heat wears 'em out. Find 'em used (along w/a turbo) on NaSIOC and read up on install as the after market - not stock version - CAN be installed w/out removing the intake manifold - I've done it. TD
HI, 3 thoughts: 1: Do you get the steady blink when checking codes to verify the ECU diagnostics IS working? And you looked for both active and historical codes? 2. MAF sensors tend to fail on these....but usually it's a random failure that won't cause your 'no-start' condition. The car will die, but usually start right back up....but another used MAF may be worth a shot, if readily avl. (Every USA Subaru except the SVX and '91-'94 turbos used the same green label MAF from '92-'98-ish.) 3. Battery / Alternator condition? New and/or known good? Also, the fuel gauges are known to be erratic on the older Subies. My '96 is less than accurate below a 1/2 a tank, due to the sensors sensitivity (one on left and right) wearing out, I believe. Did you search the Legacy Central site, too? GL, TD
Hi, Just to clarify....'96-'99 Legacy OB/GT (2.5), '95-'98 Legacy L/Brighton (2.2), '95(2.2 only)-'98 Impeza, '98 Forester. You'll need your DUAL port exhaust y-pipe off the heads (header), but it'll bolt up to any of the other exhausts. The '99 Legacy L, and Impreza had a Phase 2, 2.2 and are not (easily) compatible w/your engine electronically. You could put it in the earlier models, but you'll need use the intake manifold that matches the car. And '95 Autos were EGR-equipped, which is a GOOD thing as it'll work in cars with or w/out EGR. There are some gotchas so keep searching to find more info. Your brother should know what you'll need to add to your engine to use it w/a 5-speed (FW, pilot bearing, etc.). GL, TD
1990 2.2
wtdash replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I believe the difference in Cam/Crank sensors is the older style were all one piece - sensor+wire/harness+plug? Newer style had a plug connector on the sensor....I don't know if they're interchangeable.....Edit...No..see below. And if the '90 has a KS it's likely cracked so reuse the Forester's. It should plug in to the '98 intake's harness (you got one w/the wiring harness attached? If not, I'm fairly sure the Forester's will work). -
1990 2.2
EGR - link...non-issue, unless your '98 intake doesn't have it either....then you'll have a CEL. -
Throwing this out there..... there are differences between the '98 and '01, due the mild face-lift in '01: From cars101.com: "The 2001 model was introduced early, in February 2000. The front end, rear end, dashboard, lower body cladding was all mildly redesigned, with new colors, cloth, and the introduction of a new top of the line S Premium model including side air-bags and a factory sunroof". I know the '01+ have lights in the hatch that the earlier models don't....and Car-part.com shows only 1998-'00 and '01-02 interchange.
Hi, Just clarifying....you have 2005 Legacy Limited NON-GT (GT is Turbo'd), correct? And you want to put a 2.0 from an '02-'05 WRX, correct? (the only 2.2 turbo in Subaru's lineup were the EJ22T in the '91-'94 Legacy SS/TW and -rare as they come- 22B WRX from '97-'98-ish). As someone who's swapped turbos into NON-turbo cars (that didn't have a comparable turbo model for their year) , I'd be a hypocrite to say 'don't bother', but --- 'don't bother'. Yes, it's cool to have a 'one-off', but unless your swappers/converters are very good and have done MANY swaps before, there's a (very) good chance it'll never run right, and if you have strict emissions/inspections in PA, you may be making a trailer queen. And eventually you'll want/have to sell it...and that may be a struggle. Remember, it'll take twice as much time AND twice the $$ to complete this, IMHO. Expect to upgrade brakes, suspension (ALL of it), steering rack(maybe), exhaust, tires, etc...and you'll still not quite have the same quality of car that rolled out of the factory. RE: the crossmember - I know all Subaru Crossmembers (between models and turbo versions) were interchangeable up 'til about 2002....so I don't know for sure if the '05+ 4th (?) Gen Legacy changed that or not. But I DO know the EJ205/EJ255/EJ257 are all interchangeable from '02+, so not sure what 'modifying' you're doing. I'd not NOTCH the crossmember, if that's in the consideration bin, as you'll be putting more power to it...even if you weld a brace. Devil's advocate - over and out.
2002 wrx
Hmmm...didn't finish this. Hoping she means NA / Non-turbo engines. Although I'm not the one w/the expertise to dispute this, there are more than a few that will in the below links. Backpressure is created by the turbo, so no other back pressure is required after the turbo. Exhaust velocity - discussed in the links, is what is @ issue, and that comes from the header/exhaust manifold and up pipe. Link1 Link2 Link3 -
Hi, Please don't double-post the same request for info. This info is common all Subie forums....Google will help you out, too. '96 uses a stock 205-70-15, which = 205-55-17. All about 26" tall and won't rub anything. You might go as tall as 27", but probably rub spring perches. use this to type in 17" sizes... https://tiresize.com/comparison/ (and make sure it's a 'real' tire size by clicking the Tire Results tab)
2002 wrx
The Uppipe is a potential turbo killer as they wear out internally and send their contents....lots of places it ain't 'sposed to go. But to answer your question. You can get a Tactrix Cable ($100), download free ECUFlash and ROMRAIDER software and tune it yourself via the OBD2 port, get a Cobb AccessPort (AP)$300(used)-600 (new) , or do nothing and probably be fine......but I wouldn't risk it as these 2.0/EJ205 are known to spin bearings even on the stock tune. You can also get those 'anti-fouler' plugs for the O2 sensor which usually work to eliminate the CEL. And not sure just a DP will get him the noise he's after....new muffler? -
^+1 Move the pass. seat all the way forward. I'd bet the CD player is DOA anyway...they weren't known for their life-span. Welcome to the Forum, TD
- 2 replies
- Cd Changer
- cd player
(and 2 more)
Tagged with:
Google found THIS on NASIOC....Remember, Baja = 2006+ WRX/STI engine....actually the 2004-2005 Baja have the same exact engine as the 2004-2007 STi - different turbo and TMIC on the STi for more POWer. So NASIOC is a great resource for these issues. Personally, I'd check those oil line filters- to the turbo and camshafts. There was a TSB on 'em years ago now . They should be replaced or removed and make sure you're changing the oil every 3K. But 209K miles on Subaru turbo engine is getting up there. TD
And as noted above the '00-'04 Legacy OB and GT Driver's seats are electric and have height adj. Installed in my '96 L. I tapped in to a 12V directly under the seat (key-on power only), and haven't had any issues and they're pretty comfy. BTW, All Impreza/WRX/STi and Forester '92-'2007 will fit, too. I believe height adj. was avl. starting on the '98+ Imp RS. FWIW, the '02-'06 WRX seats sit HIGH in the Legacy, so if you're not too tall they may work well for your wife...but be aware the passenger seat does NOT have height adj. and tall passengers will be either leaning the seat way back or craning their necks. As a side-note, some of the newer stuff uses a different mounting type - some use a threaded stud, others a bolt - to attach the belt buckle....make sure yours comes w/the existing buckle attached and you should have what u need. TD
4EAT in SVX
wtdash replied to briankk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
There should be tag on top of the bell housing of the transmission. Subaru Autos typically start w/TZ... you can then just Google that # for applications. - Make sure it's an AWD, if yours is also, as they did make 2WD SVX's - Assuming you know the SVX is infamous for its 4EAT failures - usually due to heat.... - ...Install an ATF cooler, ASAP. And the trick to seating the TC is covered on here...please Search for that important info. TD
