19
Everything posted by wtdash
I didn't see it above, but usually a fluid change (not a flush) requires 3-4 'drains>>refills'. The fluid is in the tranny and the torque converter, so drain>>refill>>drive>>repeat. This procedure replaces the majority of the fluid. Also, the difference between a Low fluid level and Full is about a pint, so best to keep track of what you drain and refill w/same amount...if you started @ the Full mark. And just for the record, I (and maybe others on here) recommend against doing a FLUSH of the AT fluid on high mileage AT. It can dislodge stuff that is actually helping keep the tranny functioning. I know from personal experience.
Swapped the MAF and installed the Bosch Universal sensor..yeah, it's a PITA and I got it wrong the 1st time....car wouldn't even run. But the idle is much better, smoothest it's been in weeks. And NO CODES after a 15 minute drive. I'm guessing the injector codes were related to the failure of the MAF/O2? Thanks, TD
'90 Legacy w/a '93 EJ22T swapped in. I've had some recurring engine issues the last few weeks where the engine will just die. A couple times while idling, a couple times while accelerating, and 2 times when coming to a stop/slowing down @ an intersection. I've also had it cut-out for a brief second, but continue running. Car always starts right back up and NO CEL. After doing some driving last nite w/the car running well - didn't die once- the CEL comes on but the car continues to run fine. I pulled the codes and found: Error 14-17 for Injector #1-4 Error 23 - MAF Sensor Error 32 - O2 sensor I've read that the MAF could cause these symptoms?? I've got another MAF I can try. Also, the O2 sensor isn't working right as the voltage doesn't change...I'm using the Revscan software from Revtronix that can read multiple parameters..... but doubt it would cause the car to stall. Anyone think the Bosch O2 sensors are OK? They're avl. locally for $50 and I don't have time to order one....leaving for VACA tomorrow. Thanks for any feedback! Td
After reading this LINK about TB and this LINK (near the bottom) about someone else's experience, I decided to give it a go. I had just replaced the transmission and the used replacement had TB and delayed AWD...took 1-2 seconds for the rear wheels to kick on any slick surface. Since I still had the old 4EAT laying(lying?) around, I pulled the rear housing off, filed down the grooves, and waited for day off. That way I could just take it apart and put it back together w/out the delay of filing the grooves. The only new part I installed was the Duty C - I didn't mess w/the plates. In my case the Duty C wasn't bad (the FWD fuse still worked) but I didn't want to have to go back in there to fix it again. I'm no mechanic, but it wasn't too difficult. It fixed the delay 100% and the TB about 95%. TD
Won't start
wtdash replied to fatguide's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
2 things I can think of are the Ignitor/Igniter (?) - dead center on the engine side of firewall, and the coil pack, including the plug that connects by the throttle body. Not sure how to test either, but I know they'll keep it from firing. Checked for Codes (CEL)? - Instructions HERE. -
chech out this link...it'll give you a good idea on how to R&R the transfer clutches: http://www.ultimatesubaru.org/forum/showthread.php?t=55651&highlight=bad+gear+good+torque+bind I had a delay on my AWD engagement, followed the above info and it was 95% fixed. Still get torque bind (SEARCH) every once in awhile, but no delay. Good luck, TD
Hello, Found this ONLINE for a '95 Legacy - yours should be very similar: Automatic Transmision: Fluid capacity - 8.4 US qt SEARCH on here on about flushing/replacing the tranny fluid if the tranny is a 'high miler'. Also, it takes 3-4 drain/refills to replace all the fluid. The engine holds 4-5 quarts of oil. GL, TD
I'm going to expand on what Sir Nipper stated...hopefully live to tell about it. The green connectors are used for 'active' reading of CEL codes. On the Legacy from '90-94 (and maybe your '00) there's also a set of black connectors used for 'stored' codes. Both sets may or may not be next to each other, but usually on Legacys are under the driver's side of the dash, as in your pic. Here's a LINK about using them on older Subies, but I DO NOT Guarantee the results are the same on your '00. There is a recent post on this site about doing this on the OBD2 cars, and it includes the code #s and descriptions...but can't find it right now. However, my DISCLAIMER is that if/when you do have a CEL, take it to a place w/an OBD2 scanner to get it checked. Good luck, TD
Just to clarify on Olnick's informative post, the '99 Forester (and Impeza RS) had the SOHC 2.5 engine, not the DOHC. The DOHC was '98 only for the Forester. (The legacy outback used the DOHC thru the '99 model year.) The SOHC 2.5 also had issues but usually they could be resolved w/a coolant additive, so you might check the car's maintenance history to see if it was treated. Also, the Forester has an issue w/the rear wheel bearings, which are expensive to have replaced. Plus the Forester has air bags, ABS and a 5 year warranty....The '92 Legacy rec'd air bags midway thru '92 so it may/may not have them, and ABS wasn't standard, either. The legacy will have a bit more cargo room, if it matters. My suggestion is get the Forester (or maybe I will :-) ) Enjoy! TD
You said you were a 'rookie', so no offense if this is obvious! Raise the rear wheels off the ground, grab the top of the tire and see if there's any play in/out. That should tell you if it's the bearings...I've heard Foresters have 'bearing issues'; not sure about the OB. Also, fill the Rear diff (if you can get that darn top plug out!). Good luck, TD
Welcome to the board! Searching on here for 'swap' and 'conversion' will likely find you a lot of info. I also know there are dedicated sites for VWs that have swapped in Subaru engines. Personally, unless you're very familiar w/turbos/wiring/engine management/etc, I'd leave your '96 EJ22E AS IS - don't turbo it. Unless you run <5psi boost, install turbo-quality pistons, and other mods, you'll be looking for a new/replacement engine b4 too long. Otherwise, find an EJ22T from a '91-94 Legacy or a WRX EJ20 w/all the related bits to go turbo the safe way. Have fun! Td
'89-91 = Same (aka pre-facelift) '92-94 = Same (mostly - the GT had a raised roof in '94) (aka post-facelift) Yes, the shortblock is great...rumor it can handle 300+HP 'as is' w/supporting mods to fuel/ECU/etc. '92 Turbo TCU in a '94 NA? It'll work, but you may get some weird shifts on occasion...@ least I did. I'd match the transmission (turbo vs. NA) w/the same TCU; I think the year matters less. BTW, if the '91 Turbo is an Automatic it also has the same diff ratio as your '94 - 3.90 - and it should have a VLSD...buy that for sure!
Maybe I missed it, but buying Used can save a ton, and if you can replace them yourself, save even more. Buy the whole assembly and it's a pretty easy swap (remember to mark the top strut bolt). Over on SubaruForester.org they frequently have them for sale. Just get 'em w/lower miles <30K?? Good luck, Td
