19
Everything posted by wtdash
Maybe I missed it, but why swap out a good, known engine? If the HG goes it'll likely give warning signs, and you'll have time to find an engine. I've read on here (I think) that the torque of the 2.2 and the 2.5 are comparable. So towing shouldn't be an issue. If you drive up into the mountains a lot, then the 2.5 may be better. Check out cars101.com....I believe the 2.5 was 155hp in '96; 165hp '97-'05?; and 170hp currently. Good luck.
The adjustment might be covered on here somewhere and I'm sure there's a 'procedure'... but I did it 'by feel'. Sorry, don't know. I've read pros/cons using the FWD mode, but mostly it's frowned upon. And wouldn't see how that would affect the transmission's shifting. Not sure we're on the same page re: the differentials: The front diff is built-in to the tranny (axles attach to the tranny) and would be geared for a 4.11 on the '91, which means the rear diff must also be 4.11. The '94 is 3.9 front and rear. So, you can't mix a '94 Tranny/front diff w/a '91 rear diff.
No offense to your mechanical aptitude, but are you sure the shift lever is adjusted correctly? I had to re-adjust mine when I replaced it. It sounds like it's slipping out of gear...not actually the tranny slipping. And your rear diff was swapped too, correct? The '91 is a 4.11; the '94 is 3.90. Good luck.
If your alignment is 'known good' now, mark the location of the FRONT Upper bolt (it's oval shaped) on the strut mount before touching it and put it back exactly, your alignment should be fine...Mine was when I put OB struts on my older Legacy....took it in just to check and they told me it was 'in spec'. Have fun w/it!
Hello, '90 Legacy AWD Automatic N/A 2.2 - 151K When engine is warm and I restart, the RPM bounces between 500 and 1000 for about 15 seconds, and then settles down. Recently started getting slight stumble/hesitation when engine's cold and I accelerate. Runs great otherwise and MPG is 22/28. Recent new plugs, Subie (!) wires, and O2 sensor....and the bouncing RPM did it b4 any of this was changed, too. ...I'm thinking IAC or temp sensor?? Thanks
Can't comment on replacing clutch plates...didn't get that far into it. My tool collection is incomplete, but was adequate for this job...I don't have any air tools. I got the solenoid seals and the big seal between the transmission and transfer case...no header gaskets. I dropped the entire exhaust...the cat bolts were heat-welded, and didn't want to fight 'em.
Just replaced the Duty C solenoid AND redid the transfer clutches on my '90 Legacy - fixed the binding and a 1-2 second delay before the AWD kicked in. Buy a NEW solenoid for <$100 - http://www.1stsubaruparts.com/ Item: PT040396 VLV AY TRF Price: $85.14 Repairing the transfer clutches is here: http://www.ultimatesubaru.org/forum/showthread.php?t=55651&highlight=bad+gear+good+torque+bind and here http://www.ultimatesubaru.org/forum/showthread.php?t=78467 Replacement does NOT require removing the trans from the car. Removing/installing info here: http://www.ultimatesubaru.org/forum/showthread.php?t=81591&highlight=transfer+clutch I'd get the transfer clutch out of JY, do the repair, and then do the swap. I did this (and I'm NOT a mechanic) in about 4 hours by myself. My car has very little rust underneath, so if your car came from the NE, expect some grief getting things loose. Good luck.
What did the mechanic do? Some on here have reported flushing the transmission fixed it. But Yes, replacing the rear transfer clutch assembly (removable rear section of the transmission) is likely needed. It is HIGHLY recommended that the Duty C solenoid, aka transfer case solenoid also be replaced when they are in there. Another option is if you or a mechanically inclined friend want to do this, there is a GREAT thread/post on doing this. I'm no mechanic, and I did this myself. Otherwise, it's in the $1000 range @ the dealer. Here's a link on another subie site: http://legacycentral.org/library/torquebind.htm Good luck!
Sounds like the the 'rack and pinion' weren't lined up when either it was made, or less likely installed as it should be 'set' from the factory. If you 100% trust the mech, then he should be your 'expert' source in getting it replaced by the factory. If he's just the closest wrench around, then get a 2nd opinion....go to the 'st(d)ealer' if you must. I'd think you'd notice a much tighter turning radius one way vs. the other, too. Compare it to the old one (or did it go back as a 'core'??)...kinda hard if it's installed...but may shed some light? Good luck.
1990 Legacy L Wagon, 4EAT, Lifted, running 205/70R-15 studded snows, w/a '91 (?) turbo tranny and 3.9 rear LSD. 22.5 MPG* City 20%/Highway80% - 65-70MPH Highway Running 205/60R-16: 25.5 MPG* City 20%/Highway80% - 65-70MPH Highway * This is the 'corrected' amount by using the http://www.1010tires.com/TireSizeCalculator.asp
'03 2.5 (per your 1st post) is PN: 11810AA040 11810AA040 Outback 2002-2008 Engine PCV PCV VALE FOR ALL 2002-2008 LEGACY OUTBACK 2.5 (NON H6) (NON TURBO) '03 3.0-Here's a pic of the P/N: http://www.scoobymods.com/forums/attachment.php?attachmentid=3166&d=1097973143 Here's pic of the comparison: http://www.scoobymods.com/forums/attachment.php?attachmentid=3123&d=1096256188
UPDATE: Thanks to USMB members (again ), I determined this was the clutches in the rear transfer case. As a interim fix -and because it sounded cool :cool: - I installed the 4WD diff lock switch this fall and it made the 4WD work great, esp. since we've had near record snowfall this winter. Here's a link to the switch: http://www.ultimatesubaru.org/forum/showthread.php?t=50264 Since I still had my old tranny, I used its parts to fix the one I installed last summer. I took my old tranny apart and its output hub had the grooves that this and other posts showed: http://www.ultimatesubaru.org/forum/showthread.php?t=78467&page=6 I filed down the grooves. I bought a new Duty C and gaskets and installed in the housing of my old tranny. Finally had an above freezing day (unheated garage) and tore it all apart....here's another post w/instructions: http://www.ultimatesubaru.org/forum/showthread.php?t=81591&highlight=transfer+clutch This was not as tough a job as I feared, BUT many of these items were removed last summer when I swapped trannies, so the nuts/bolts were easy to remove. This car also has very little rust, which makes it much easier. Took about 4 hours, since I'd already 'prepped' the rear housing and Duty C, and just swapped parts. The output hub had grooves worse than the original, so I thought I was on the right path. The result? So far, so good. I found some snow and when I punched it had instant traction @ both ends. NO DELAY!! Before, I had a 1-2 second delay before the rear-end would kick in, which was a real drag (pun intended ). Suggestion to anyone swapping in a used tranny, or even a rebuilt one, is to check the rear transfer clutches/hub and replace the Duty C....sure wish I had read up on it before I'd swapped mine!....Live and learn! Thanks again USMB!
Condition Value Excellent $5,855 Good $5,330 Fair $4,650 This if for Private Party in Portland, OR (no offense to Bigbusa). If the car is good to go for another 60K (except gas and oil changes), which it appears it is, then $6K is on the high end.....but what's it worth to you to have all the maintenance done? One thing I continue to see is that West Coast cars are more than East Coast. Don't know if it's the lack of rust or just higher demand for Subies out here. Is 115K on the original clutch low (I drive an AT)? If so, was it driven hard or just a lot of stop-n-go city driving? Sounds like a good deal, if you can get it for $5500 or less.
I (and a lot of help from friends) replaced my tranny and a left front axle this summer on my '90 Leg. Due to finding out on Sunday afternoon that the front left boot was torn, and that only (N)Autozone had mine available I bought one. As it was my 1st big time mechanical repair, I was borrowing a friend's garage and tools, and I needed it for work the next day, I 'fixed' it then and there. Less than 6,000 miles later it was creaking/groaning when accelerating (but not clicking :-\ ), vibrating thru the steering wheel, and felt like my tires were out of balance on the freeway! Thanks to this site I was able to swap it out w/another one in about 30 minutes (amazingly simple). I'll return the bad one for credit if possible, but if I have to take another one, it's going to Ebait. It now makes no weird noises and rides almost smooth on the highway (I'm still on studded snows that may be due for a balance). One thing I'm unsure of is whether running Outback struts may have caused more stress due the angle, leading to premature failure??....but I had the right/passenger side replaced (b4 I realized how easy it is!) about a year ago and it's still going strong. Anyway, Thanks USMB members!
I'm not going to pretend to know more than 3 mechanics who said it's rod-knock, but I had a mechanic tell me the same thing, and after I sold an OB (for a loss) I'm pretty sure it was actually 'piston-slap'...after reading about it on USMB. Is it loud @ start-up but goes away after it's warmed up? That's what piston-slap does and it's not a big deal...other than disconcerting as heck. The CRV and RAV4s are pretty good @ holding their value...If you can find one. In Co. Springs, I'd say you're in 'prime Subie/4WD' land, which explains the inflated values...the good news is that if the OB is clean (not rusted) and reasonable miles you may get your money back. $2500 for a clean OB may be just the ticket for someone there who is willing to do the swap. Plus, CCR isn't too far away (Denver) and they can put in a 2.2 for $3750 (last I read). If you haven't put any $$ into it and are not able to swap in a 2.2, then I suggest selling it and getting the <96 Legacy. Sounds like it will fit your budget and should be as reliable as anything else for the money. Sorry you got a bum deal - been there done that, too.
Forester or OBW
wtdash replied to Mugs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The link 'johnc' supplied is a good one. From my experience, my speed wasn't off by much, if @ all.......using my buddy's GPS, the MPH shown on the GPS matched my speedometer. 'Though I don't know how accurate GPS' are 'sposed to be. If the GPS was correct it's a letdown, as I thought I was getting better MPG since my bigger tires should be off by about 8%. But as my car is a '90 Legacy, it could use a different VSS. -
For what it's worth...I plugged an 02 WRX 6-CD/Cassette into my (old) '97 Outback - totally plug and play. Only neg was I lost the clock..and I could live w/that. I'm leaning toward a bad replacement....'though 2 bad is hard to believe, but no - power/lights/etc....makes me wonder if you've got a bad ground or such? Good luck.
