wtdash
    19
Everything posted by wtdash
  1. NGK on the plugs/wires? Not sure if the '04 were as picky as the earlier models...but why tempt the fates. 2000-2004 Outback had NO MAF, so you're not blind. :-) It's an EJ251 vs EJ253 thing (kinda) Only the turbocharged models had a MAF in '04 - STI, WRX, FXT, Baja turbo...IIRC.
  2. For future reference and others...you can put some tape (or similar) on the bolt head to get it to stick / wedge into the socket to hold it. Then use an extension to reach down and reinstall the bolt. Once it's snug the socket should release. Just be extra careful not to cross-thread it! There's probably an even better way that Mech's know. :-)
  3. The '99 had an issues w/the gauges / dash cluster. Search on the fix, which I believe involves soldering. Also, the 5-speed may still use the same speedo sensor as older models that may wear out / break. It's on the passenger side near the gear oil dipstick. Looks like this and that tab on the end breaks off:
  4. Hi, Most of the JDM stuff 'seems' to need to use the USDM's crank/Cam sprockets(gears). Maybe Japan Direct knows, too. And does your '03 have EGR? If so, you'll need to either drill and tap the head on the EJ20 or try a workaround. Likely other stuff...but I've not done this swap, but it's been done a LOT so search online, too. Remember - that same engine was used on the Impreza, Outback and Forester so any of those Subaru forums would be relevant.
  5. Edit: What's your skill set and what's wrong w/the '05? If the heads are good on the '05 it should work on the '03 block. I'd do the HG on any used Subaru engine I bought regardless.
  6. I've read that the cheaper versions are OK, too. Just need a long extension and 12mm(?) socket. Note its orientation when removing to install same. And if there's been any work done on the car around the KS area, it could be unplugged or damaged wiring....and be careful with those wires as they are 20+ years old and getting brittle. p.s. ...the '95 and older were known to crack, but was supposedly fixed on newer models.....so a used one will work too. A KS from a 2.5/EJ25D should work too.
  7. Those LGT seats may sit really low since you'd sit extra high w/the reverse (Impreza>Legacy), but the LGT should have a height adjustment - on the Driver's seat. And for the generations of Subaru you're working on I've yet to see one that had bolted on rails...welded, I believe. But swapping seat belts isn't a big deal.....usually.
  8. And if your OBS has the Automatic, then your 2.2 has EGR. The '94 won't. Here's an easy workaround LINK.
  9. Also, the '96 was SINGLE-port exhaust; '94 was Dual...get the Exhaust header/y-pipe. And if the body is clean...that means the engine and/or trans are toast...but you likely knew that. :-)
  10. I agree w/GD, but if you 'insist' there is the Neon / Mopar coil pack that is swappable..also MSD. Links all over the subie forums. That is, as long as you're referring to something like this:
  11. Per the attached from opposedforces.com they should both be (G/R) 4.111. They're both running the EJ22 / 2.2. One thing is Subaru changed the rear diff's flange bolt spacing around '95, so that 'could' be a gotcha, too.
  12. Interesting, didn't know the Dex III was a no-no on these. I thought the 4EAT used the same as the earlier models. From the OM (w/my formatting):
  13. Quoted for truth: - Do Not take a dealer's/salesperson word. It means nothing after the sale. If the car needs a fix that they state they'll remedy it must be in writing in the PO (and good luck w/that). - 200-2004 4-cylinder - Any model really.. The 2005-2009 models have many more 'gotchas' - do your homework. NO USED SUBARU TURBOS. period. period. - Ensure HG were done; complete Timing belt kit and water pump- usually the pulleys fail, not the belt. - Get it inspected b4 you buy - preferably @ a Subaru non-dealer shop. - I'm a bigger fan of the '96-'98 Legacy / Impreza wagons/hatches with 2.2. But they are getting old and Subaru has officially (as of last year?) stopped supplying parts so fixing them could be a challenge.
  14. see attached for the Jeep - but Autocheck - not Carfax. And two options for $6.00 or less . Jeep GC AUTOCHECK.pdf
  15. "flashing AT oil temp light" means there's a code stored in the TCM (vs. ECU/PCM). Search on here for a DIY to pull the codes. Then you can decide the next step.
  16. HI, The driver's side and passenger sided (if equipped) are certainly MANUALLY adjustable. The 'mirror' portion will move left-right and up-down. I don't know what/how your wife was doing to break the glass? Also, on the '95 (and earlier) models the mirror housing - the plastic frame part that attaches to the car - is FOLDABLE - in or out only. If she was trying to adjust it up/down? maybe that was caused it to break.
  17. Hi, '92-'94 Legacy were 3.90 FD ratio. That's the most important part. However, if you replace the rear diff you can use any '90-'91 '95-'98 2.2 or 2.5 Legacy , Impreza, or Forester Auto transmission. .. >>Caveats: you'll need to change the pinion flange on the diff to match yours....different bolt spacing. >>>Flex plate needs to match up, too. The 'seating' of the Torque Converter is also very important - search on here, and there are are a couple of seals on input/output (?) shafts to replace. Also, if buying one from a used parts yard, it may have been sitting on the shelf - for a long time and the internal seals may leak once installed- and the shop may not warranty that.
  18. jdouglas@mikescarffsubaru.com Been a couple of years, but good prices and service - near Seattle.
  19. No Offense, we (USA) did get those as I've seen all of them, except the GX Sun sport, in person. The GT was a non-turbo w/the raised roof, which was rare. I apologize to the OP for the thread-jack. Edit: They were all '94s released @ the end of the 1st Gen Legacy run.
  20. First post states it's too $$...wait...states 'flatbed' tow, so maybe they don't have a tow vehicle?...but Yeah.
  21. Tangent: Alpine sport...I thought that was the one-year only model, along w/the following - from CARS101.com: These are One-year only models - 1994 - per Cars101.com.
  22. Look up using a tow dolly w/the front wheels on the dolly and rear wheels dragging. I've done it multiple times buy disconnecting the driveline @ the rear diff. There are 4 12mm bolts, so it's easy. Uhaul is <$100. if one-way 1/2 that if you return it to the same place. But since you're up north may be different. It's covered on here more than once. Of course, you need something big enough for the tow dolly + the WRX or Uhaul won't rent it. Do the WRX's brakes work? I don't know your road/route/rules but my dad towed a VW Bug behind his Chevy truck - w/just a chain - across WA state on I90 @ 60 MPH, w/my sister driving the bug....no problem. I'm sure that GT could handle that too.
  23. Just FYI. Stock size on the '96-'99 OB was the 205/70R15. The 215/60R16 is the same height, and was 1st used on the '98 Forester....if that's what you have. If the 5-speed dies, you could put in a GT trans as it's the same 4.11 FD ratio, and is geared differently.....as is the '98 Forester. Unless I got it backwards? OB: Model Range Trans. Code 1st 2nd 3rd 4th 5th 6th Rev. T.R. F.D. US Legacy Outback MY97 TY752VACCA 3.545 2.111 1.448 1.088 0.871 N/A 3.416 1.000 4.111 GT: US Legacy GT MY97 TY752VACBA 3.545 2.111 1.448 1.088 0.780 N/A 3.416 1.000 4.111 Found in the old Subaru Transmission Chart that was online. Subaru Transmission Chart.pdf
