20
Everything posted by wtdash
Quoted for truth: - Do Not take a dealer's/salesperson word. It means nothing after the sale. If the car needs a fix that they state they'll remedy it must be in writing in the PO (and good luck w/that). - 200-2004 4-cylinder - Any model really.. The 2005-2009 models have many more 'gotchas' - do your homework. NO USED SUBARU TURBOS. period. period. - Ensure HG were done; complete Timing belt kit and water pump- usually the pulleys fail, not the belt. - Get it inspected b4 you buy - preferably @ a Subaru non-dealer shop. - I'm a bigger fan of the '96-'98 Legacy / Impreza wagons/hatches with 2.2. But they are getting old and Subaru has officially (as of last year?) stopped supplying parts so fixing them could be a challenge.
CarFax
wtdash replied to billrigsby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
see attached for the Jeep - but Autocheck - not Carfax. And two options for $6.00 or less . Jeep GC AUTOCHECK.pdf -
HI, The driver's side and passenger sided (if equipped) are certainly MANUALLY adjustable. The 'mirror' portion will move left-right and up-down. I don't know what/how your wife was doing to break the glass? Also, on the '95 (and earlier) models the mirror housing - the plastic frame part that attaches to the car - is FOLDABLE - in or out only. If she was trying to adjust it up/down? maybe that was caused it to break.
Hi, '92-'94 Legacy were 3.90 FD ratio. That's the most important part. However, if you replace the rear diff you can use any '90-'91 '95-'98 2.2 or 2.5 Legacy , Impreza, or Forester Auto transmission. .. >>Caveats: you'll need to change the pinion flange on the diff to match yours....different bolt spacing. >>>Flex plate needs to match up, too. The 'seating' of the Torque Converter is also very important - search on here, and there are are a couple of seals on input/output (?) shafts to replace. Also, if buying one from a used parts yard, it may have been sitting on the shelf - for a long time and the internal seals may leak once installed- and the shop may not warranty that.
Look up using a tow dolly w/the front wheels on the dolly and rear wheels dragging. I've done it multiple times buy disconnecting the driveline @ the rear diff. There are 4 12mm bolts, so it's easy. Uhaul is <$100. if one-way 1/2 that if you return it to the same place. But since you're up north may be different. It's covered on here more than once. Of course, you need something big enough for the tow dolly + the WRX or Uhaul won't rent it. Do the WRX's brakes work? I don't know your road/route/rules but my dad towed a VW Bug behind his Chevy truck - w/just a chain - across WA state on I90 @ 60 MPH, w/my sister driving the bug....no problem. I'm sure that GT could handle that too.
Just FYI. Stock size on the '96-'99 OB was the 205/70R15. The 215/60R16 is the same height, and was 1st used on the '98 Forester....if that's what you have. If the 5-speed dies, you could put in a GT trans as it's the same 4.11 FD ratio, and is geared differently.....as is the '98 Forester. Unless I got it backwards? OB: Model Range Trans. Code 1st 2nd 3rd 4th 5th 6th Rev. T.R. F.D. US Legacy Outback MY97 TY752VACCA 3.545 2.111 1.448 1.088 0.871 N/A 3.416 1.000 4.111 GT: US Legacy GT MY97 TY752VACBA 3.545 2.111 1.448 1.088 0.780 N/A 3.416 1.000 4.111 Found in the old Subaru Transmission Chart that was online. Subaru Transmission Chart.pdf
My normal 1st thing to check (including the TPS and IAC) is the CTS/coolant temp sensor as it can exhibit these symptoms. Sounds like it's running rich? The CTS doesn't always throw a code. Note: Don't confuse the gauge sensor w/the actual CTS sensor that tells the ECU what's going on....Google it if unclear.
